ULP global variables
urbanze
Postby urbanze » Tue Oct 03, 2017 7:38 pm
Hi guys! I tried to change any global variable with ULP, but doesnt work. What I do wrong?
(The code simply read the variable before, and after the ULP to check if the variable has changed.)
C code
Assembly code
krzychb
Contact:
Re: ULP global variables
Postby krzychb » Tue Oct 03, 2017 8:35 pm
Hi urbanze,
I can't read anything on these screen shoots :shock: I will be guessing then :D
Maybe you are missing the "ulp_" prefix?
Ref. https://esp-idf.readthedocs.io/en/lates ... -variables
EDIT: If this is not the case, then try a classic example https://github.com/espressif/esp-idf/tr ... system/ulp.
This example is using global variables and it works for me.
urbanze
Postby urbanze » Wed Oct 04, 2017 1:43 am
Hi urbanze,
Thanks for reply krz!. I know about "ulp_" variables, and yes, I using this and doenst work... I think is anything about load or store, but need help...
Why you cant view screen shots?
ESP_igrr
Postby ESP_igrr » Wed Oct 04, 2017 3:12 am
ULP code seems to be missing a store after the increment.
krzychb
Contact:
Postby krzychb » Wed Oct 04, 2017 6:12 am
I can view the screen shots but not the tiny font :)
Copy and paste of code would work better for me in this case.
Also a plan text is easier for anybody to copy back for testing instead of retyping.
@ESP_igrr, thank you for help with this one!
urbanze
Postby urbanze » Wed Oct 04, 2017 6:16 am
.global x
x: .long 0
.global entry
entry:
move r0, x
ld r0, r0, 0
add r0, r0, 1
st r0, r0, 0
halt
//or this
move r0, x
move r2, 10
ld r0, r0, 0
st r2, r0, 0
halt
Anyone doenst work, how can I do this simples process?¿
urbanze
Postby urbanze » Wed Oct 04, 2017 6:21 am
Code in C have:
variable: extern uint32_t ulp_x = 1;
and load/run to ulp.
Code in ulp
.global x
x: .long 0
.global entry
entry:
move r0, x
ld r0, r0, x
add r0, r0, 1
halt
I comment before with another two tests, and anyone doenst worked
krzychb
Contact:
Postby krzychb » Wed Oct 04, 2017 6:41 am
Code in C have:
How do verify whether "ulp_x" is changing its value or not?
tomtor
Postby tomtor » Wed Oct 04, 2017 8:56 am
Code in ulp
.global x
x: .long 0
.global entry
entry:
move r0, x
ld r0, r0, x
add r0, r0, 1
halt
Should be e.g.:
.global x
x: .long 0
.global entry
entry:
move r1, x // load address of x in r1
ld r0, r1, 0 // load data from x in r0
add r0, r0, 1 // increment r0
st r0,r1,0 // store r0 as new content of x
halt
urbanze
Postby urbanze » Wed Oct 04, 2017 12:39 pm
Code in C have:
void ulp()
	Serial.printf("\nULP_X: %d", ulp_x & UINT16_MAX);
	delay(100);
	ulp_load_binary(0, ulp_main_bin_start, (ulp_main_bin_end - ulp_main_bin_start) / sizeof(uint32_t));
	ulp_run((&ulp_entry - RTC_SLOW_MEM) / sizeof(uint32_t));
	delay(100);
Users browsing this forum: ChatGPT-User, PerplexityBot, Semrush [Bot] and 2 guests
