espidftools setup online 2.3.5 fail multiple time
striderheng
Postby striderheng » Mon Sep 08, 2025 9:39 am
I been trying to install espidftools using the onlline 2.3.5 exe and also the v5.5 offline and it keeps failing at the same point. I even launch it using adminstrator privilege. I done this several times after uninstalling. I tried pretty much everything I can find online.
The end snippet of the setup log. All previous setup attempt logs shows identical point where it failed after waiting several minutes during installation process.
2025-09-08 11:25:10.707 Running command: C:\temp\Espressifstuff\tools\idf-python\3.11.2\python.exe "C:\temp\Espressif\frameworks\esp-idf-v5.5.1\tools\idf_tools.py" "--idf-path" "C:\temp\Espressif\frameworks\esp-idf-v5.5.1" install --targets=esp32,esp32-c3,esp32-c6,esp32-s3,esp32-s2,esp32-p4
Updating C:\temp\Espressifstuff\idf-env.json
Selected targets are: esp32, esp32s3, esp32c3, esp32s2, esp32p4, esp32c6
Current system platform: win64
Installing tools: xtensa-esp-elf-gdb, riscv32-esp-elf-gdb, xtensa-esp-elf, riscv32-esp-elf, esp32ulp-elf, cmake, openocd-esp32, ninja, idf-exe, ccache, dfu-util, esp-rom-elfs
Installing xtensa-esp-elf-gdb@16.2_20250324
Using GitHub assets mirror for URL: https://github.com/espressif/binutils-g ... ingw32.zip => https://dl.espressif.com/github_assets/ ... ingw32.zip
Downloading https://dl.espressif.com/github_assets/ ... ingw32.zip
Destination: C:\temp\Espressifstuff\dist\xtensa-esp-elf-gdb-16.2_20250324-x86_64-w64-mingw32.zip.tmp
Done
Extracting C:\temp\Espressifstuff\dist\xtensa-esp-elf-gdb-16.2_20250324-x86_64-w64-mingw32.zip to C:\temp\Espressifstuff\tools\xtensa-esp-elf-gdb\16.2_20250324
Installing riscv32-esp-elf-gdb@16.2_20250324
Destination: C:\temp\Espressifstuff\dist\riscv32-esp-elf-gdb-16.2_20250324-x86_64-w64-mingw32.zip.tmp
Done
Extracting C:\temp\Espressifstuff\dist\riscv32-esp-elf-gdb-16.2_20250324-x86_64-w64-mingw32.zip to C:\temp\Espressifstuff\tools\riscv32-esp-elf-gdb\16.2_20250324
2025-09-08 11:25:10.707 --------
2025-09-08 11:25:10.707 Message box (OK):
The installation process has encountered an error (which may not be critical). Exit code: -1
2025-09-08 11:25:15.773 User chose OK.
2025-09-08 11:25:15.773 Message box (Yes/No):
Installation log has been created, it may contain more information about the problem.
Display the installation log now?
2025-09-08 11:25:17.416 User chose Yes.
2025-09-08 11:25:17.470 CurStepChanged raised an exception.
2025-09-08 11:25:17.825 Need to restart Windows? No
2025-09-08 11:25:17.825 Exception message:
2025-09-08 11:25:17.825 Message box (OK):
Out Of Range.
2025-09-08 11:25:17.849 User chose OK.
2025-09-08 11:25:17.849 Deinitializing Setup.
2025-09-08 11:25:17.852 Failed to remove temporary directory: C:\Users\test\AppData\Local\Temp\is-B3MI4.tmp
2025-09-08 11:25:17.864 Log closed.
striderheng
Re: espidftools setup online 2.3.5 fail multiple time
Postby striderheng » Thu Oct 02, 2025 9:12 am
I tried a clean install again with the online exe program. Fails again. I include the log from today attempt.
This frustrating as before the current failed esp-idf installation, it is very slow using vscode insider with the esp-idf extension as it takes a long time(more than 20mins) scanning for kits when I start vscode and when I try to build.
I notice this error keeps cropping up
Cannot find: "${env:IDF_PATH}/components/"
which goes away after the 20mins+ of scanning.
I don't see this in settings.json either. I assume its because the esp-idf has not installed properly and IDF_PATH is not set in win11 enviroment variables either
Anyone can help getting this solved???
Setup Log 2025-10-02 #003.txt
(40.52 KiB) Downloaded 31 times
Minatel
Postby Minatel » Thu Oct 02, 2025 1:28 pm
We are close to announcing the replacement of this installer.
Can you give it a try and share your experience?
https://dl.espressif.com/dl/eim/
Roland
Postby Roland » Fri Oct 03, 2025 11:25 am
I don't see any error message in the logs. What did it print in the message box? "The installation process has encountered an error (which may not be critical). Exit code: -1"?
Roland
Postby Roland » Fri Oct 03, 2025 11:28 am
I think this command failed:
C:\Espressif\tools\idf-python\3.11.2\python.exe "C:\Espressif\frameworks\esp-idf-v5.5.1\tools\idf_tools.py" "--idf-path" "C:\Espressif\frameworks\esp-idf-v5.5.1"   install --targets=esp32,esp32-c3,esp32-c6,esp32-s3,esp32-s2,esp32-p4
Could you try to run it manually and share the output?
striderheng
Postby striderheng » Mon Oct 06, 2025 7:23 am
yes to that error message.
yesterday evening from vscode
Screenshot 2025-10-05 235515.png (30.32 KiB) Viewed 3181 times
tries your cmdline with some changes to point to the correct directories
C:\Users\test\AppData\Local\Programs\Python\Python313\python.exe: can't open file 'C:\\users\\test\\esp\\frameworks\\esp-idf-v5.5.1\\tools\\idf_tools.py': [Errno 2] No such file or directory
PS C:\users\test\.espressif\tools\idf-python\3.11.2> C:\users\test\.espressif\tools\idf-python\3.11.2\python.exe "C:\users\test\esp\v5.5.1\esp-idf\tools\idf_tools.py" "--idf-path" "C:\Users\test\esp\v5.5.1\esp-idf" install --targets=esp32,esp32-c3,esp32-c6,esp32-s3,esp32-s2,esp32-p4
Updating C:\Users\test\.espressif\idf-env.json
Selected targets are: esp32s3, esp32c6, esp32s2, esp32p4, esp32c3, esp32
Skipping xtensa-esp-elf-gdb@16.2_20250324 (already installed)
Skipping riscv32-esp-elf-gdb@16.2_20250324 (already installed)
Skipping xtensa-esp-elf@esp-14.2.0_20241119 (already installed)
Skipping riscv32-esp-elf@esp-14.2.0_20241119 (already installed)
Skipping esp32ulp-elf@2.38_20240113 (already installed)
Skipping cmake@3.30.2 (already installed)
Skipping openocd-esp32@v0.12.0-esp32-20250707 (already installed)
Skipping ninja@1.12.1 (already installed)
Skipping idf-exe@1.0.3 (already installed)
Skipping ccache@4.11.2 (already installed)
Skipping dfu-util@0.11 (already installed)
Skipping esp-rom-elfs@20241011 (already installed)
I haven't started up vscode yet after the cmdline. Will do that today and see what it reports for startup
As for the unreleased installer, do I try after removing everything????
striderheng
Postby striderheng » Mon Oct 06, 2025 8:36 am
error messages today
----------------------------------------------------------- Logfile -----------------------------------------------------------------
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473563\n\tat yt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473749)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474159)\n\tat et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469514)\n\tat Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488269)\n\tat new Wt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1484822)\n\tat Wt.init (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1484771)\n\tat gd (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1884643)\n\tat Py.kb (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:15303)\n\tat Py.jb (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:15048)\n\tat file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:13206\n\tat async Gb.n (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:13382)\n\tat async Gb.m (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:13345)\n\tat async Gb.l (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:12801)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-04T16:17:48.202Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474173)\n\tat async et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469508)\n\tat async Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488263)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-04T16:17:48.212Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473563\n\tat yt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473749)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474159)\n\tat et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469514)\n\tat Bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1481146)\n\tat async Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488321)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-04T16:17:48.603Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474173)\n\tat async et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469508)\n\tat async Bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1481140)\n\tat async Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488321)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-04T16:17:48.603Z"}
{"message":"Cannot access filePath: C:<HOMEPATH>\\Desktop\\esp-idf\\tools\\idf.py","stack":"Error: ENOENT: no such file or directory, access 'C:<HOMEPATH>\\Desktop\\esp-idf\\tools\\idf.py'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat od.value (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1569294)\n\tat $.C (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:27:2373)\n\tat $.fire (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:27:2591)\n\tat UV.$onMessage (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:142:92663)\n\tat U4.S (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:29:120964)\n\tat U4.Q (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:29:120744)\n\tat U4.M (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:29:119833)\n\tat U4.L (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:29:119071)\n\tat od.value (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:29:117735)\n\tat $.C (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:27:2373)\n\tat $.fire (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:27:2591)\n\tat Ao.fire (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:29:9458)\n\tat od.value (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:393:8616)\n\tat $.C (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:27:2373)\n\tat $.fire (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:27:2591)\n\tat Ao.fire (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:29:9458)\n\tat MessagePortMain.<anonymous> (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:393:6908)\n\tat MessagePortMain.emit (node:events:519:28)\n\tat MessagePortMain._internalPort.emit (node:electron/js2c/utility_init:2:2949)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-04T16:18:03.448Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\sdkconfig","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\sdkconfig'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474173)\n\tat async et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469508)\n\tat async Bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1481140)\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1563017\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1562927\n\tat async Ao (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1561309)\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1571344","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-04T16:19:54.638Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\sdkconfig","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\sdkconfig'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474173)\n\tat async et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469508)\n\tat async Bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1481140)\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1563531\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1563441\n\tat async Ao (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1561309)\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1571344","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-04T16:19:56.221Z"}
{"command":"c:<HOMEPATH>\\.espressif\\tools\\idf-git\\2.39.2\\cmd\\git.exe","message":"Updating files: 2% (462/17666)\rUpdating files: 2% (464/17666)\rUpdating files: 3% (530/17666)\rUpdating files: 4% (707/17666)\rUpdating files: 5% (884/17666)\rUpdating files: 6% (1060/17666)\rUpdating files: 6% (1066/17666)\rUpdating files: 7% (1237/17666)\rUpdating files: 7% (1300/17666)\rUpdating files: 8% (1414/17666)\rUpdating files: 9% (1590/17666)\rUpdating files: 10% (1767/17666)\rUpdating files: 10% (1804/17666)\rUpdating files: 11% (1944/17666)\rUpdating files: 12% (2120/17666)\rUpdating files: 13% (2297/17666)\rUpdating files: 14% (2474/17666)\rUpdating files: 15% (2650/17666)\rUpdating files: 16% (2827/17666)\rUpdating files: 17% (3004/17666)\rUpdating files: 18% (3180/17666)\rUpdating files: 19% (3357/17666)\rUpdating files: 20% (3534/17666)\rUpdating files: 21% (3710/17666)\rUpdating files: 22% (3887/17666)\rUpdating files: 22% (3958/17666)\rUpdating files: 23% (4064/17666)\rUpdating files: 24% (4240/17666)\rUpdating files: 25% (4417/17666)\rUpdating files: 26% (4594/17666)\rUpdating files: 27% (4770/17666)\rUpdating files: 28% (4947/17666)\rUpdating files: 29% (5124/17666)\rUpdating files: 29% (5169/17666)\rUpdating files: 30% (5300/17666)\rUpdating files: 31% (5477/17666)\rUpdating files: 32% (5654/17666)\rUpdating files: 33% (5830/17666)\rUpdating files: 34% (6007/17666)\rUpdating files: 35% (6184/17666)\rUpdating files: 36% (6360/17666)\rUpdating files: 37% (6537/17666)\rUpdating files: 37% (6706/17666)\rUpdating files: 38% (6714/17666)\rUpdating files: 38% (6888/17666)\rUpdating files: 39% (6890/17666)\rUpdating files: 39% (7027/17666)\rUpdating files: 40% (7067/17666)\rUpdating files: 41% (7244/17666)\rUpdating files: 41% (7311/17666)\rUpdating files: 42% (7420/17666)\rUpdating files: 43% (7597/17666)\rUpdating files: 44% (7774/17666)\rUpdating files: 45% (7950/17666)\rUpdating files: 46% (8127/17666)\rUpdating files: 47% (8304/17666)\rUpdating files: 48% (8480/17666)\rUpdating files: 48% (8627/17666)\rUpdating files: 49% (8657/17666)\rUpdating files: 50% (8833/17666)\rUpdating files: 51% (9010/17666)\rUpdating files: 52% (9187/17666)\rUpdating files: 53% (9363/17666)\rUpdating files: 54% (9540/17666)\rUpdating files: 55% (9717/17666)\rUpdating files: 56% (9893/17666)\rUpdating files: 57% (10070/17666)\rUpdating files: 57% (10079/17666)\rUpdating files: 58% (10247/17666)\rUpdating files: 59% (10423/17666)\rUpdating files: 60% (10600/17666)\rUpdating files: 61% (10777/17666)\rUpdating files: 62% (10953/17666)\rUpdating files: 63% (11130/17666)\rUpdating files: 64% (11307/17666)\rUpdating files: 65% (11483/17666)\rUpdating files: 66% (11660/17666)\rUpdating files: 67% (11837/17666)\rUpdating files: 68% (12013/17666)\rUpdating files: 69% (12190/17666)\rUpdating files: 70% (12367/17666)\rUpdating files: 71% (12543/17666)\rUpdating files: 71% (12599/17666)\rUpdating files: 72% (12720/17666)\rUpdating files: 73% (12897/17666)\rUpdating files: 74% (13073/17666)\rUpdating files: 75% (13250/17666)\rUpdating files: 76% (13427/17666)\rUpdating files: 77% (13603/17666)\rUpdating files: 78% (13780/17666)\rUpdating files: 79% (13957/17666)\rUpdating files: 80% (14133/17666)\rUpdating files: 81% (14310/17666)\rUpdating files: 82% (14487/17666)\rUpdating files: 83% (14663/17666)\rUpdating files: 84% (14840/17666)\rUpdating files: 85% (15017/17666)\rUpdating files: 86% (15193/17666)\rUpdating files: 87% (15370/17666)\rUpdating files: 88% (15547/17666)\rUpdating files: 89% (15723/17666)\rUpdating files: 90% (15900/17666)\rUpdating files: 90% (16041/17666)\rUpdating files: 91% (16077/17666)\rUpdating files: 92% (16253/17666)\rUpdating files: 93% (16430/17666)\rUpdating files: 94% (16607/17666)\rUpdating files: 95% (16783/17666)\rUpdating files: 96% (16960/17666)\rUpdating files: 97% (17137/17666)\rUpdating files: 98% (17313/17666)\rUpdating files: 99% (17490/17666)\rUpdating files: 100% (17666/17666)\rUpdating files: 100% (17666/17666), done.\n","stack":"Error: Updating files: 2% (462/17666)\rUpdating files: 2% (464/17666)\rUpdating files: 3% (530/17666)\rUpdating files: 4% (707/17666)\rUpdating files: 5% (884/17666)\rUpdating files: 6% (1060/17666)\rUpdating files: 6% (1066/17666)\rUpdating files: 7% (1237/17666)\rUpdating files: 7% (1300/17666)\rUpdating files: 8% (1414/17666)\rUpdating files: 9% (1590/17666)\rUpdating files: 10% (1767/17666)\rUpdating files: 10% (1804/17666)\rUpdating files: 11% (1944/17666)\rUpdating files: 12% (2120/17666)\rUpdating files: 13% (2297/17666)\rUpdating files: 14% (2474/17666)\rUpdating files: 15% (2650/17666)\rUpdating files: 16% (2827/17666)\rUpdating files: 17% (3004/17666)\rUpdating files: 18% (3180/17666)\rUpdating files: 19% (3357/17666)\rUpdating files: 20% (3534/17666)\rUpdating files: 21% (3710/17666)\rUpdating files: 22% (3887/17666)\rUpdating files: 22% (3958/17666)\rUpdating files: 23% (4064/17666)\rUpdating files: 24% (4240/17666)\rUpdating files: 25% (4417/17666)\rUpdating files: 26% (4594/17666)\rUpdating files: 27% (4770/17666)\rUpdating files: 28% (4947/17666)\rUpdating files: 29% (5124/17666)\rUpdating files: 29% (5169/17666)\rUpdating files: 30% (5300/17666)\rUpdating files: 31% (5477/17666)\rUpdating files: 32% (5654/17666)\rUpdating files: 33% (5830/17666)\rUpdating files: 34% (6007/17666)\rUpdating files: 35% (6184/17666)\rUpdating files: 36% (6360/17666)\rUpdating files: 37% (6537/17666)\rUpdating files: 37% (6706/17666)\rUpdating files: 38% (6714/17666)\rUpdating files: 38% (6888/17666)\rUpdating files: 39% (6890/17666)\rUpdating files: 39% (7027/17666)\rUpdating files: 40% (7067/17666)\rUpdating files: 41% (7244/17666)\rUpdating files: 41% (7311/17666)\rUpdating files: 42% (7420/17666)\rUpdating files: 43% (7597/17666)\rUpdating files: 44% (7774/17666)\rUpdating files: 45% (7950/17666)\rUpdating files: 46% (8127/17666)\rUpdating files: 47% (8304/17666)\rUpdating files: 48% (8480/17666)\rUpdating files: 48% (8627/17666)\rUpdating files: 49% (8657/17666)\rUpdating files: 50% (8833/17666)\rUpdating files: 51% (9010/17666)\rUpdating files: 52% (9187/17666)\rUpdating files: 53% (9363/17666)\rUpdating files: 54% (9540/17666)\rUpdating files: 55% (9717/17666)\rUpdating files: 56% (9893/17666)\rUpdating files: 57% (10070/17666)\rUpdating files: 57% (10079/17666)\rUpdating files: 58% (10247/17666)\rUpdating files: 59% (10423/17666)\rUpdating files: 60% (10600/17666)\rUpdating files: 61% (10777/17666)\rUpdating files: 62% (10953/17666)\rUpdating files: 63% (11130/17666)\rUpdating files: 64% (11307/17666)\rUpdating files: 65% (11483/17666)\rUpdating files: 66% (11660/17666)\rUpdating files: 67% (11837/17666)\rUpdating files: 68% (12013/17666)\rUpdating files: 69% (12190/17666)\rUpdating files: 70% (12367/17666)\rUpdating files: 71% (12543/17666)\rUpdating files: 71% (12599/17666)\rUpdating files: 72% (12720/17666)\rUpdating files: 73% (12897/17666)\rUpdating files: 74% (13073/17666)\rUpdating files: 75% (13250/17666)\rUpdating files: 76% (13427/17666)\rUpdating files: 77% (13603/17666)\rUpdating files: 78% (13780/17666)\rUpdating files: 79% (13957/17666)\rUpdating files: 80% (14133/17666)\rUpdating files: 81% (14310/17666)\rUpdating files: 82% (14487/17666)\rUpdating files: 83% (14663/17666)\rUpdating files: 84% (14840/17666)\rUpdating files: 85% (15017/17666)\rUpdating files: 86% (15193/17666)\rUpdating files: 87% (15370/17666)\rUpdating files: 88% (15547/17666)\rUpdating files: 89% (15723/17666)\rUpdating files: 90% (15900/17666)\rUpdating files: 90% (16041/17666)\rUpdating files: 91% (16077/17666)\rUpdating files: 92% (16253/17666)\rUpdating files: 93% (16430/17666)\rUpdating files: 94% (16607/17666)\rUpdating files: 95% (16783/17666)\rUpdating files: 96% (16960/17666)\rUpdating files: 97% (17137/17666)\rUpdating files: 98% (17313/17666)\rUpdating files: 99% (17490/17666)\rUpdating files: 100% (17666/17666)\rUpdating files: 100% (17666/17666), done.\n\n\tat
striderheng
Postby striderheng » Mon Oct 06, 2025 8:37 am
\\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-04T16:20:13.029Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473563\n\tat yt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473749)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474159)\n\tat et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469514)\n\tat Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488269)\n\tat new Wt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1484822)\n\tat Wt.init (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1484771)\n\tat gd (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1884643)\n\tat Py.kb (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:15303)\n\tat Py.jb (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:15048)\n\tat file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:13206\n\tat async Gb.n (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:13382)\n\tat async Gb.m (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:13345)\n\tat async Gb.l (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:12801)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-05T09:36:10.488Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474173)\n\tat async et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469508)\n\tat async Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488263)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-05T09:36:10.498Z"}
{"command":"xtensa-esp-elf-gdb-no-python","message":"spawn xtensa-esp-elf-gdb-no-python ENOENT","stack":"Error: spawn xtensa-esp-elf-gdb-no-python ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.725Z"}
{"command":"riscv32-esp-elf-gdb-no-python","message":"spawn riscv32-esp-elf-gdb-no-python ENOENT","stack":"Error: spawn riscv32-esp-elf-gdb-no-python ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.726Z"}
{"command":"xtensa-esp-elf-gcc","message":"spawn xtensa-esp-elf-gcc ENOENT","stack":"Error: spawn xtensa-esp-elf-gcc ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.726Z"}
{"command":"riscv32-esp-elf-gcc","message":"spawn riscv32-esp-elf-gcc ENOENT","stack":"Error: spawn riscv32-esp-elf-gcc ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.726Z"}
{"command":"esp32ulp-elf-as","message":"spawn esp32ulp-elf-as ENOENT","stack":"Error: spawn esp32ulp-elf-as ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.726Z"}
{"command":"openocd","message":"spawn openocd ENOENT","stack":"Error: spawn openocd ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.726Z"}
{"command":"ninja","message":"spawn ninja ENOENT","stack":"Error: spawn ninja ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.726Z"}
{"command":"idf.py.exe","message":"spawn idf.py.exe ENOENT","stack":"Error: spawn idf.py.exe ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"command":"ccache.exe","message":"spawn ccache.exe ENOENT","stack":"Error: spawn ccache.exe ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"command":"dfu-util","message":"spawn dfu-util ENOENT","stack":"Error: spawn dfu-util ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"utils execChildProcess","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking xtensa-esp-elf-gdb version","stack":"Error: spawn xtensa-esp-elf-gdb-no-python ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking riscv32-esp-elf-gdb version","stack":"Error: spawn riscv32-esp-elf-gdb-no-python ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking xtensa-esp-elf version","stack":"Error: spawn xtensa-esp-elf-gcc ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking riscv32-esp-elf version","stack":"Error: spawn riscv32-esp-elf-gcc ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking esp32ulp-elf version","stack":"Error: spawn esp32ulp-elf-as ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking openocd-esp32 version","stack":"Error: spawn openocd ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking ninja version","stack":"Error: spawn ninja ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking idf-exe version","stack":"Error: spawn idf.py.exe ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking ccache version","stack":"Error: spawn ccache.exe ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"message":"Error checking dfu-util version","stack":"Error: spawn dfu-util ENOENT\n\tat ChildProcess._handle.onexit (node:internal/child_process:285:19)\n\tat onErrorNT (node:internal/child_process:483:16)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:90:21)","category":"IdfToolsManager checkBinariesVersion","level":"error","timestamp":"2025-10-05T09:36:20.727Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T09:57:10.201Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473563\n\tat yt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473749)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474159)\n\tat et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469514)\n\tat Bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1481146)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:105:5)\n\tat async Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488321)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-05T09:57:10.201Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474173)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:105:5)\n\tat async et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469508)\n\tat async Bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1481140)\n\tat async Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488321)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-05T09:57:10.201Z"}
{"user":true,"message":"C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf already exists. Delete it or use another location. (ERROR_EXISTING_ESP_IDF)","stack":"Error: C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf already exists. Delete it or use another location. (ERROR_EXISTING_ESP_IDF)\n\tat \\dist\\extension.js:2:1561628\n\tat async Ao (\\dist\\extension.js:2:1561309)\n\tat async \\dist\\extension.js:2:1571344","category":"SetupPanel error handler","level":"error","timestamp":"2025-10-05T11:23:00.764Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\CMakeLists.txt'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473563\n\tat yt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1473749)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474159)\n\tat et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469514)\n\tat Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488269)\n\tat new Wt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1484822)\n\tat Wt.init (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1484771)\n\tat gd (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1884643)\n\tat Py.kb (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:15303)\n\tat Py.jb (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:15048)\n\tat file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:118:13206\n\tat async Gb.n (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:13382)\n\tat async Gb.m (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:13345)\n\tat async Gb.l (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:114:12801)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-05T11:26:49.667Z"}
{"message":"Cannot access filePath: c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig","stack":"Error: ENOENT: no such file or directory, access 'c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\sdkconfig'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474173)\n\tat async et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469508)\n\tat async Wt.configureWithDefaultValues (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1488263)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-05T11:26:49.676Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T12:01:48.357Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n","stack":"Error: non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n\n\tat ChildProcess.<anonymous> (\\dist\\extension.js:2:1471625)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:293:12)","category":"src utils spawn","level":"error","timestamp":"2025-10-05T12:50:37.186Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n","stack":"Error: non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n\n\tat ChildProcess.<anonymous> (\\dist\\extension.js:2:1471625)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:293:12)","category":"src utils spawn","level":"error","timestamp":"2025-10-05T12:50:45.054Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T13:06:19.827Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T13:23:05.593Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T15:15:15.618Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T15:17:11.338Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n","stack":"Error: non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n\n\tat ChildProcess.<anonymous> (\\dist\\extension.js:2:1471625)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:293:12)","category":"src utils spawn","level":"error","timestamp":"2025-10-05T15:32:11.097Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n","stack":"Error: non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n\n\tat ChildProcess.<anonymous> (\\dist\\extension.js:2:1471625)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:293:12)","category":"src utils spawn","level":"error","timestamp":"2025-10-05T15:32:34.099Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T15:36:00.091Z"}
{"message":"Cannot access filePath: f:\\temp\\ESP32\\projects\\hello_world\\sdkconfig","stack":"Error: ENOENT: no such file or directory, access 'f:\\temp\\ESP32\\projects\\hello_world\\sdkconfig'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat bt (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1474173)\n\tat async et (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1469508)\n\tat async od.value (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1888983)","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-05T15:36:01.916Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T15:53:27.509Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T15:56:56.967Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T16:00:26.388Z"}
{"user":true,"message":"Failed to flash because of some unusual error. Check Terminal for more details","stack":"Error: Task ESP-IDF Flash exited with code 2\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1653619\n\tat od.value (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:201:103122)\n\tat $.C (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:27:2373)\n\tat $.fire (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:27:2591)\n\tat uA.$onDidEndTaskProcess (file:///c:<HOMEPATH>/AppData/Local/Programs/Microsoft%20VS%20Code%20Insiders/resources/app/out/vs/workbench/api/node/extensionHostProcess.js:123:13396)","category":"flashCommand unknown error","level":"error","timestamp":"2025-10-05T16:00:27.894Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T16:08:10.601Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T16:23:39.154Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n","stack":"Error: non zero exit code null\r\n\r\nesptool.py v4.10.0\r\nSerial port COM9\r\nConnecting....\r\nDetecting chip type... ESP32-S3\r\nChip is ESP32-S3 (QFN56) (revision v0.1)\r\nFeatures: WiFi, BLE\r\nCrystal is 40MHz\r\nMAC: 7c:df:a1:e2:e9:e4\r\nUploading stub...\r\n\n\tat ChildProcess.<anonymous> (\\dist\\extension.js:2:1471625)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:293:12)","category":"src utils spawn","level":"error","timestamp":"2025-10-05T19:07:48.127Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T19:23:41.650Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T19:46:31.351Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T20:02:33.436Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T21:49:32.754Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-05T22:12:05.546Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-06T07:53:10.956Z"}
{"command":"c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe","message":"Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n","stack":"Error: Not using an unsupported version of tool cmake found in PATH: 3.11.1. To use it, run 'c:<HOMEPATH>\\.espressif\\python_env\\idf5.5_py3.11_env\\Scripts\\python.exe C:<HOMEPATH>\\esp\\v5.5.1\\esp-idf\\tools\\idf_tools.py export --prefer-system'\r\n\n\tat \\dist\\extension.js:2:1475262\n\tat ChildProcess.exithandler (node:child_process:411:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1101:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:304:5)","category":"utils execChildProcess stderr","level":"error","timestamp":"2025-10-06T08:10:11.080Z"}
{"message":"Cannot access filePath: ${env:ADF_PATH}","stack":"Error: ENOENT: no such file or directory, access 'C:<HOMEPATH>\\AppData\\Local\\Programs\\Microsoft VS Code Insiders\\${env:ADF_PATH}'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1695963\n\tat $a (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1697104)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:105:5)\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1944004","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-06T08:10:11.081Z"}
{"message":"Cannot access filePath: ${env:MDF_PATH}","stack":"Error: ENOENT: no such file or directory, access 'C:<HOMEPATH>\\AppData\\Local\\Programs\\Microsoft VS Code Insiders\\${env:MDF_PATH}'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1696141\n\tat $a (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1697104)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:105:5)\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1944004","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-06T08:10:11.081Z"}
{"message":"Cannot access filePath: ${env:ESP_MATTER_PATH}","stack":"Error: ENOENT: no such file or directory, access 'C:<HOMEPATH>\\AppData\\Local\\Programs\\Microsoft VS Code Insiders\\${env:ESP_MATTER_PATH}'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1696233\n\tat $a (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1697104)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:105:5)\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1944004","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-06T08:10:11.081Z"}
{"message":"Cannot access filePath: ${env:HOMEKIT_PATH}","stack":"Error: ENOENT: no such file or directory, access 'C:<HOMEPATH>\\AppData\\Local\\Programs\\Microsoft VS Code Insiders\\${env:HOMEKIT_PATH}'\n\tat Object.accessSync (node:fs:244:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9395)\n\tat ct (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1471825)\n\tat c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1696329\n\tat $a (c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1697104)\n\tat process.processTicksAndRejections (node:internal/process/task_queues:105:5)\n\tat async c:<HOMEPATH>\\.vscode-insiders\\extensions\\espressif.esp-idf-extension-1.10.2\\dist\\extension.js:2:1944004","category":"src utils canAccessFile","level":"error","timestamp":"2025-10-06T08:10:11.081Z"}
{"message":"ENOENT: no such file or directory, open 'f:\\temp\\ESP32\\projects\\hello_world\\.vscode\\launch.json'","stack":"Error: ENOENT: no such file or directory, open 'f:\\temp\\ESP32\\projects\\hello_world\\.vscode\\launch.json'","category":"extension DoctorCommand","level":"error","timestamp":"2025-10-06T08:21:03.089Z"}
{"user":true,"level":"warn","message":"Extension configuration report has been copied to clipboard with errors","timestamp":"2025-10-06T08:21:03.089Z"}
striderheng
Re: espidftools setup online 2.3.5 fail multiple time
Postby striderheng » Mon Oct 06, 2025 9:02 am
Screenshot 2025-10-06 110125.png (62.82 KiB) Viewed 3176 times
also when I clicked on the install drivers, it say lack admin privileges
Minatel
Postby Minatel » Wed Oct 22, 2025 6:47 pm
Hi @striderheng,
Do you still have this issue with the EIM?
