How to achieve stable sampling rate (1 kHz) when reading IMU data and sending over Serial on ESP32?
theluciansm
Postby theluciansm » Thu Oct 02, 2025 7:45 pm
Hello everyone,
I am working with an ESP32 and an ICM-45686 IMU.
My goal is to acquire accelerometer and gyroscope data at 1.024 kHz and send it to a PC via serial. On the PC side, I have a Python script that receives the data and saves it.
I would like to evaluate whether the sampling rate of the ESP32 is actually stable. To check this, I compared the ESP32 data with a commercial data acquisition system, both synchronized by a trigger.
In the figure attached:
Black: measurement from the commercial system
Red: measurement from the ESP32
Blue: difference between the two signals
The signal is a measurement of a periodic movement of an object with 10 Hz of frequency.
We can observe that the difference (blue) is not just a fixed offset, but varies over time: the ESP32 signal starts slightly delayed and then seems to get ahead of the reference signal.
๐Ÿ‘‰ How should I interpret this behavior?
๐Ÿ‘‰ Does this variation in the blue residual indicate that the ESP32 sampling rate is not stable (jitter), or could there be another explanation?
I accept any suggestions.
THanks!
The esp32 code is below (using arduino IDE):
 *  ICM-45686 โ€“ 1 kHz Acquisition + Laser Trigger                                         *
 *  FEATURES:        *
 *   โ€ข Reads accelerometer and gyroscope signals from the ICM-45686 IMU at 1 kHz          *
 *   โ€ข Sends the data over serial in tabular format                                       *
 *   โ€ข Activates the laser (GPIO 17) immediately after button detection (GPIO 33)         *
 *  Author: Lucian Ribeiro da Silva โ€“ Jun/2025                                            *
#include <Arduino.h>
#include <SPI.h>
#include "ICM45686.h"
#include "soc/gpio_reg.h"  // For direct register manipulation (if needed)
#include "driver/gpio.h"
#include "soc/io_mux_reg.h"
#include "soc/soc.h"
/* โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€
 *  Application pin definitions
 * โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€ */
constexpr int CS_PIN        = 5;    // IMU Chip Select on the SPI bus
constexpr int INT1_PIN      = 4;    // IMU interrupt pin (not used)
// constexpr int PINO_BOTAO    = 17;   // <-- REMOVED
constexpr int PINO_TRIGGER  = 33;   // Digital output to activate the laser
constexpr int PINO_TRIGGER_SCADAS  = 27;   // Digital trigger output for SCADAS
constexpr int DEBUG_PIN     = 2;    // On-board LED for debugging (optional)
constexpr int tempoHIGH = 15000;
constexpr int Fs_loop = 1024; // frequency of signal transmission via serial (not the sensor ODR, be careful)
int Ts = 0;
 *  Global variables
int32_t off_ax, off_ay, off_az;     // Acceleration offsets
int32_t off_gx, off_gy, off_gz;     // Gyroscope offsets
ICM456xx IMU(SPI, CS_PIN);          // IMU object connected via SPI
volatile int triggerAtivado = 0;    // <-- MODIFIED: renamed from 'botaoPressionado'
unsigned long tempoAcionamento = 0; // Moment when the button was pressed
char buffer[512];                   // Buffer for serial output formatting
 *  Button interrupt // <-- REMOVED
// void handleBotao() {
//     if (botaoPressionado == 0) {       // Ensures only the first click is registered
//         botaoPressionado = 1;
//         tempoAcionamento = millis();   // Saves the activation timestamp
 *  System initial setup
void setup() {
    Serial.begin(1500000);
    while (!Serial) {}
    // pinMode(PINO_BOTAO, INPUT_PULLDOWN); // <-- REMOVED
    // attachInterrupt(digitalPinToInterrupt(PINO_BOTAO), handleBotao, RISING); // <-- REMOVED
    pinMode(PINO_TRIGGER, OUTPUT);
    digitalWrite(PINO_TRIGGER, LOW);
    pinMode(PINO_TRIGGER_SCADAS, OUTPUT);
    digitalWrite(PINO_TRIGGER_SCADAS, LOW);
    pinMode(DEBUG_PIN, OUTPUT);
    digitalWrite(DEBUG_PIN, LOW);
    SPI.begin(18, 19, 23, CS_PIN);
    pinMode(CS_PIN, OUTPUT);
    digitalWrite(CS_PIN, HIGH);
    pinMode(INT1_PIN, INPUT_PULLUP);
    if (IMU.begin() != 0) {
        Serial.println("# ERROR: IMU did not initialize");
        while (true) delay(1000);
    IMU.startAccel(1600, 2);    // ยฑ2g
    IMU.startGyro (1600, 15);   // ยฑ15.625 ยฐ/s
    delay(50);
    int64_t sum[6] = {0};
    inv_imu_sensor_data_t d;
    for (int i = 0; i < 500; ++i) {
        IMU.getDataFromRegisters(d);
        sum[0] += d.accel_data[0];
        sum[1] += d.accel_data[1];
        sum[2] += d.accel_data[2];
        sum[3] += d.gyro_data[0];
        sum[4] += d.gyro_data[1];
        sum[5] += d.gyro_data[2];
        delayMicroseconds(1000);
    off_ax = sum[0] / 500;
    off_ay = sum[1] / 500;
    off_az = sum[2] / 500;
    off_gx = sum[3] / 500;
    off_gy = sum[4] / 500;
    off_gz = sum[5] / 500;
    Serial.println("trigger\tax\tay\taz\tgx\tgy\tgz"); // <-- MODIFIED: updated header
    Ts = (1000000UL / Fs_loop);
 *  Main loop โ€“ runs at 1 kHz
void loop() {
    static uint32_t nextSampleTime = micros() + Ts;
    // Busy-wait until the exact sampling moment
    while (micros() < nextSampleTime) {
        // Small pause to reduce CPU usage
        __asm__ volatile("nop");
    // Update the next sample time WITHOUT accumulating error
    nextSampleTime += Ts;
    // Check if we are behind schedule (drift protection)
    if (micros() > nextSampleTime) {
        // If we are too late, resynchronize
// --- ADDED: Python command "listener" ---
if (Serial.available() > 0 && triggerAtivado == 0) {
    int comando = Serial.parseInt();
   if (comando == 1) {
        triggerAtivado = 1;
        digitalWrite(PINO_TRIGGER, HIGH);
        digitalWrite(PINO_TRIGGER_SCADAS, HIGH);
        //REG_WRITE(GPIO_OUT_W1TS_REG, (1ULL << PINO_TRIGGER) | (1ULL << PINO_TRIGGER_SCADAS));
    // IMU reading
    int32_t ax = d.accel_data[0] - off_ax;
    int32_t ay = d.accel_data[1] - off_ay;
    int32_t az = d.accel_data[2] - off_az;
    int32_t gx = d.gyro_data[0]  - off_gx;
    int32_t gy = d.gyro_data[1]  - off_gy;
    int32_t gz = d.gyro_data[2]  - off_gz;
    snprintf(buffer, sizeof(buffer),
             "%d\t%ld\t%ld\t%ld\t%ld\t%ld\t%ld",
             triggerAtivado, ax, ay, az, gx, gy, gz);
    Serial.println(buffer);
Screenshot 2025-10-02 165711.png (854.34 KiB) Viewed 4123 times
Re: How to achieve stable sampling rate (1 kHz) when reading IMU data and sending over Serial on ESP32?
Postby Sprite » Fri Oct 03, 2025 9:13 am
The error is fairly small - I'm eyeballing that at the end the amplitude is about 1/3rd of the actual waveforms, meaning it leads or lags by (sin-1(0.333)/2*pi=)0.04 cycles. On a total of 80 cycles, that's about 0.05%. That is probably be explained by the fact that you're using ints for Ts, nextSampleTime etc - your Ts should be (1000000/1024)=976.562 but because you store it as an int, it's 976. That leads to an actual frequency of (1000000/976)=1024.59Hz, which indeed is off by 0.05%.
theluciansm
Postby theluciansm » Fri Oct 03, 2025 2:27 pm
Hi @Sprite, thanks a lot for your explanation.
That was a very good observation โ€” I hadnโ€™t considered the effect of using int for Ts and nextSampleTime. Iโ€™ll update the code to use the correct precision and then come back here to share the new results.
theluciansm
Postby theluciansm » Fri Oct 03, 2025 3:20 pm
I changed for the following code
 *  ICM-45686 โ€“ Aquisiรงรฃo a 1 kHz + Disparo de Laser
 *  Correรงรฃo: uso de double para Ts e uint64_t para temporizaรงรฃo,
 *  evitando truncamento (976 vs 976.562 ยตs) que gerava drift.
 *  Autor: Lucian Ribeiro da Silva โ€“ Rev. Out/2025
#include <SPI.h>
 *  Definiรงรตes de pinos da aplicaรงรฃo
constexpr double Fs_loop = 1024.0;   // Frequรชncia de envio (Hz)
double Ts;                           // Perรญodo em microssegundos (preciso)
char buffer[128];
 *  Setup
void setup() {
    while (!Serial) {}
        Serial.println("# ERRO: IMU nรฃo inicializou");
    IMU.startGyro (1600, 15);   // ยฑ15,625ยฐ/s
    delay(50);
    // Agora Ts รฉ armazenado com precisรฃo em double
    Ts = 1000000.0 / Fs_loop; // ~976.562 ยตs
 *  Loop principal โ€“ executa a 1 kHz
void loop() {
    static uint64_t nextSample = micros();  // uint64_t para evitar overflow
    // espera atรฉ o tempo exato
    while (micros() < nextSample) {}
    nextSample += (uint64_t)Ts;  // incremento com precisรฃo em double
    // --- Ouvinte de comando via Serial ---
        if (comando == 1) {
            triggerAtivado = 1;
    // Leitura da IMU
But Iโ€™m still observing a phase shift between the signals.
I attached a screenshot from the beginning and the end of the measurement.
Could the error be due to sending a large amount of data through the serial interfaceโ€”in other words, could the serial communication be bottlenecking the system? The sensorโ€™s ODR is set to 1600, since it cannot be configured to 1024. Could this also be causing some delay or advance in the signals?
Postby Sprite » Sat Oct 04, 2025 12:37 am
No real use making Ts a double if you then go cast it to an int anyway:
Suggest you make nextSample a double as well.
esp_man
Postby esp_man » Mon Oct 06, 2025 11:23 am
If the sensor is sample rate generator itself, it may cause errors. But not delay or advance, but the sample rate variations. The delay or advance is only a further consequence.
It is typical for many MEMS devices that the Output Data Rate is generated by internal RC oscillator. Therefore, it is inherently of low accuracy.
theluciansm
Postby theluciansm » Mon Oct 06, 2025 12:45 pm
Hi @Sprite,
Thanks again for your help.
Iโ€™ve modified my code, and now Iโ€™m able to synchronize both signals (ESP vs. commercial system).
Iโ€™m attaching the signals below.
Thank you very much for your support!
Screenshot 2025-10-06 094415.png (1.26 MiB) Viewed 4069 times
Postby Sprite » Tue Oct 07, 2025 1:12 am
Glad to hear you made it work!
Return to โ€œESP32 Arduinoโ€
