ESP12-S and ESP07-S having problems to wake from sleep
Hasenradball
Postby Hasenradball » Sun Dec 14, 2025 12:57 pm
Dear Espressif Team,
i used ESP12-F module since years without having prolems getting up from deep sleep.
Now I bought some ESP07-S and ESP12-S modules and connected it with the same external circuit than I did for the ESP12-F since years.
See https://esp8266-01-adapter.de/wp-conten ... ter_v2.pdf
But if I test the deep sleep the chip does not wake up as normal, it seems if woke up it is in bootloader/flash mode.
This behaviour I did not see in the ESP12-F modules before.
My impression is that the S-modules have problems to wake from deep sleep mode.
Dear Espressif Team I need help here.
Best Frank
lichurbagan
Re: ESP12-S and ESP07-S having problems to wake from sleep
Postby lichurbagan » Wed Dec 17, 2025 2:14 pm
You may get some help from this thread. https://www.reddit.com/r/esp8266/commen ... eep_sleep/
Hasenradball
Postby Hasenradball » Fri Dec 19, 2025 7:06 am
Probably not the discussion is about the PullUps and PullDown at GPIO 0, 2, 15.
But thats not the problem.
It must be an other issue.
Is there a specification what has to be done for the robust wake from sleep?
Hasenradball
Postby Hasenradball » Fri Dec 19, 2025 7:34 pm
Found this post which shows the that the S-modules has a missing resistor:
https://www.esp8266.com/viewtopic.php?f=6&t=17975
Can anybody explain?
Hasenradball
Postby Hasenradball » Sat Dec 20, 2025 12:16 pm
Here I did some comparison of different modules:
a) ESP01 - wake OK!
ESP01 OK
b) ESP Wemos D1 mini with 12-F module - wake ok:
Wemos D1 mini with old ESPmodule OK
c) ESP07-S - wake NOT OK:
ESP07-S NOTOK
Hasenradball
Postby Hasenradball » Sat Dec 20, 2025 12:17 pm
Here the 12-S module - wake NOT OK:
ESP12-S NOTOK
Hasenradball
Postby Hasenradball » Sat Dec 20, 2025 12:19 pm
It shows the ESP12-S has the shortest pulse of all but also the ESP07-S does not wake up.
It is difficult to extend the pulse with by adding some resisors or else.
So there has been some schematic changes with result is this issues!
