我使用ESP32 S3R8 搭配 16M FLASH设计了一块PCB.
但按下BOOT上电后电脑检测不到串口.
BOOT和EN均上拉.
供电全部测过都有.
通过电压档测量晶振,两端对地电压约0.8V左右.
VDD_SPI引脚电压不足0.1V,可以认为是没有电.
求回复,ESP32S3检测不到串口的问题
- 222.png (112.19 KiB) Viewed 9173 times
- 111.png (290.02 KiB) Viewed 9173 times
wanglong126
AllenCoder
Re: 求回复,ESP32S3检测不到串口的问题
请问你有解决问题嘛?我也遇到类似的问题,我可以识别到板端的uart端口,但是固件数据传输的过程中出现的了问题(Invalid head of packet (0x45)),烧录失败。这边提供电路设计,怀疑需要添加USB转uart自动下载电路,还请帮忙check下,谢谢啦
esptool.py v4.10.0
Serial port COM3
Connecting....
Chip is ESP32-S3 (QFN56) (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 10:51:db:40:2b:b4
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
A fatal error occurred: Invalid head of packet (0x45): Possible serial noise or corruption.
FAILED: CMakeFiles/flash D:/esp32s3Proj/sample/build/CMakeFiles/flash
cmd.exe /C "cd /D D:\Espressif\frameworks\esp-idf-v5.1.2\components\esptool_py && D:\Espressif\tools\cmake\3.24.0\bin\cmake.exe -D IDF_PATH=D:/Espressif/frameworks/esp-idf-v5.1.2 -D SERIAL_TOOL=python;;D:/Espressif/frameworks/esp-idf-v5.1.2/components/esptool_py/esptool/esptool.py;--chip;esp32s3 -D SERIAL_TOOL_ARGS=--before=default_reset;--after=hard_reset;write_flash;@flash_args -D WORKING_DIRECTORY=D:/esp32s3Proj/sample/build -P D:/Espressif/frameworks/esp-idf-v5.1.2/components/esptool_py/run_serial_tool.cmake"
esptool.py v4.10.0
Serial port COM3
Connecting....
Features: WiFi, BLE
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
- ESP32-S3 V0.5(1).pdf
- 电路图
- (947.96 KiB) Downloaded 26 times
