How to remove a component from project
NikolaiBaschinski
Postby NikolaiBaschinski » Tue Apr 28, 2026 2:51 pm
Hello everyone,
I use Espressive IDE (Eclipse CDT) for my projects. I've installed a ready-to-use component from the ESP-IDF. How do I remove this component from the project?
Thank you!
Nikolai
Screenshot 2026-04-28 125418.png (8.32 KiB) Viewed 93 times
nopnop2002
Contact:
Re: How to remove a component from project
Postby nopnop2002 » Thu Apr 30, 2026 5:30 am
I'm not using Eclipse CDT, so this might not be correct, but if your project have an idf_component.yml file, Try deleting it.
NikolaiBaschinski
Postby NikolaiBaschinski » Thu Apr 30, 2026 6:02 pm
I removed the component from the yml file. But the build fails with compiler errors after that.
The managed component information is emdedded everywhere in the build system.
I expect a Remove button in the GUI, if there is a Add button. :roll:
Thank you!
Users browsing this forum: Bing [Bot], ChatGPT-User and 1 guest
