Hello everyone,
I use Espressive IDE (Eclipse CDT) for my projects. I've installed a ready-to-use component from the ESP-IDF. How do I remove this component from the project?
Thank you!
Nikolai
How to remove a component from project
NikolaiBaschinski
- Screenshot 2026-04-28 125418.png (8.32 KiB) Viewed 91 times
nopnop2002
- Contact:
Re: How to remove a component from project
I'm not using Eclipse CDT, so this might not be correct, but if your project have an idf_component.yml file, Try deleting it.
NikolaiBaschinski
I removed the component from the yml file. But the build fails with compiler errors after that.
The managed component information is emdedded everywhere in the build system.
I expect a Remove button in the GUI, if there is a Add button.
Thank you!
Thank you!
Users browsing this forum: Bing [Bot], meta-externalagent, Qwantbot, YisouSpider and 2 guests
