I wrote a captive portal script to capture WiFi credentials, a custom NTP server name, and custom Timezone parameter from a dropdown list to be saved to the NVS. Everything works as expected except the selected timezone parameter is returned as a blank and is not being saved. I am using an ESP32-DevKitC-32E Development Board. The script is compiled with an arduino ide 1.8.19 and an espressif systems core version 2.0.17. The complete script file is attached as a .zip file and as shown.
Any help would be most appreciated
#include <WiFi.h>
#include <WiFiManager.h> // https://github.com/tzapu/WiFiManager
#include <Preferences.h>
#include "RTClib.h"
#include "time.h"
RTC_DS3231 rtc;
Preferences prefs;
WiFiManager wm;
// GPIO for reset button
#define RESET_PIN 33
// POSIX TZ dropdown HTML
const char* tz_html =
"<label for='tz'>Timezone</label>"
"<select name='tz' id='tz'>"
"<option value='UTC0'>UTC</option>"
"<option value='EST5EDT,M3.2.0/2,M11.1.0/2'>US Eastern</option>"
"<option value='CST6CDT,M3.2.0/2,M11.1.0/2'>US Central</option>"
"<option value='MST7MDT,M3.2.0/2,M11.1.0/2'>US Mountain</option>"
"<option value='PST8PDT,M3.2.0/2,M11.1.0/2'>US Pacific</option>"
"</select>";
// Custom parameters
WiFiManagerParameter ntpParam("ntp", "NTP Server", "pool.ntp.org", 40);
WiFiManagerParameter tzParam(tz_html);
String ntpServer;
String timezone;
int last_second = 100;
void setup() {
Serial.begin(115200);
WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP
rtc.begin();
pinMode(RESET_PIN, INPUT_PULLUP);
prefs.begin("config", false);
// Check reset button
if (digitalRead(RESET_PIN) == LOW) {
Serial.println("Reset button pressed — clearing WiFi & config");
prefs.clear();
WiFiManager wm;
wm.resetSettings();
// Load saved defaulted values
ntpServer = prefs.getString("ntp", "pool.ntp.org");
timezone = prefs.getString("TZ", "UTC");
std::vector<const char *> wm_menu = {"wifi"}; // only need Configure WiFi bar
// Add custom fields
ntpParam.setValue(ntpServer.c_str(), 40);
wm.setMenu(wm_menu);
wm.addParameter(&ntpParam);
wm.addParameter(&tzParam);
wm.setShowInfoUpdate(false);
wm.setShowInfoErase(false);
wm.setConfigPortalTimeout(180);
// Start captive portal if needed
if (!wm.autoConnect("EPS32 Wifi Setup")) {
Serial.println("Failed to connect — restarting");
delay(1000);
ESP.restart();
// Save updated values
prefs.putString("ntp", ntpParam.getValue());
prefs.putString("tz", tzParam.getValue());
ntpServer = ntpParam.getValue();
timezone = tzParam.getValue();
Serial.print("Length of Timezone field selected: ");Serial.println(timezone.length());
Serial.println("Connected!");
Serial.print("NTP: ");Serial.println(ntpServer);
Serial.print("Timezone: ");Serial.println(timezone);
// Next 2 lines commented out until timezone not saving issue is resolved
//configTzTime(timezone.c_str(), ntpServer.c_str());
//syncRTC();
void loop() {
DateTime now = rtc.now();
if(last_second != now.second())
Serial.printf("%04d-%02d-%02d %02d:%02d:%02d\n",
now.year(), now.month(), now.day(),
now.hour(), now.minute(), now.second());
last_second = now.second();
void syncRTC() {
struct tm timeinfo;
if (!getLocalTime(&timeinfo)) {
Serial.println("Failed to obtain NTP time");
return;
rtc.adjust(DateTime(
timeinfo.tm_year + 1900,
timeinfo.tm_mon + 1,
timeinfo.tm_mday,
timeinfo.tm_hour,
timeinfo.tm_min,
timeinfo.tm_sec
Serial.println("RTC updated from NTP");
Captive Portal HTML timeszone dropdown not returning selected parm
Hexter48044
- TimeZone.zip
- (1.59 KiB) Downloaded 48 times
MicroController
Re: Captive Portal HTML timeszone dropdown not returning selected parm
Pretty sure you'll want to 'bind' the parameter to an 'id' by using one of the other constructors, like you do withCode: Select all
Hexter48044
I've added the statement to bind the TZ timezone per your suggestion as shown:
WiFiManagerParameter tzParam("tz","Timezone", "UTC0", 50, tz_html);
The Captive Wifi shows 2 TimeZone selection bars
when I press save, the time zone returned is UTC0 (Which I set as the default in the bind) not the US Central one I selected
I have attached a photo of the situation
regards
regards
- Bind.jpg (225.27 KiB) Viewed 54 times
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
