cmsis-rtos
maxzen
cmsis-rtos
Postby maxzen » Mon Jun 11, 2018 9:16 am
Hello all,
we would like to use cmsis-rtos to interface with freertos
For every XXX() api freertos has also the XXXFromISR() version: so we need to know if there is an intrinsic that tell us if we are inside an interrupt handler, something like __get_IPSR() for cortex processors
Thank you
Max
WiFive
Re: cmsis-rtos
Postby WiFive » Mon Jun 11, 2018 9:53 am
maxzen
Re: cmsis-rtos
Postby maxzen » Wed Jun 13, 2018 9:56 am
Thank you WiFive,
what about __BKPT()? Does esp32 have a similar instruction?
igrr
Re: cmsis-rtos
Postby igrr » Thu Jun 14, 2018 7:50 am
__asm__ ("break 0,0");
should break into debugger if OCD is enabled, and raise DebugException if not.
maxzen
Re: cmsis-rtos
Postby maxzen » Thu Jun 14, 2018 8:03 am
Thank you ESP_igrr,
now I can complete my macros:
#ifdef NDEBUG
#   define CHECK_IT(a)      (void)(a)
#   define BPOINT
#else
#   define CHECK_IT(a)     assert(a)
#   define BPOINT             __asm__("break 0,0")
#endif
michprev
Re: cmsis-rtos
Postby michprev » Thu Jun 14, 2018 8:37 am
By the way is there any support in OpenOCD / gdb to step over break instruction once reached?
EDIT:
Found https://github.com/espressif/openocd-esp32/issues/2
