Is there any documentation for the above?
Particularly looking for any info on the LCD: https://github.com/loboris/ESP32_TFT_library with ESP WROVER KIT preconfig settings doesn't show anything but a white screen even with DIO and 40MHz SPI speed and PSRAM disabled.
The application it arrived with just outputted "debug", flashed the LED on the back, a quarter of the screen had monochrome lines and the other three quarters had colour.
Documentation for ESP WROVER KIT 4.1
Re: Documentation for ESP WROVER KIT 4.1
// ** Set the correct configuration for ESP32-WROVER-KIT v4.1
#define DEFAULT_DISP_TYPE DISP_TYPE_ILI9341
#define DEFAULT_TFT_DISPLAY_WIDTH 240
#define DEFAULT_TFT_DISPLAY_HEIGHT 320
#define DISP_COLOR_BITS_24 0x66
#define DEFAULT_GAMMA_CURVE 0
#define DEFAULT_SPI_CLOCK 26000000
#define TFT_INVERT_ROTATION 0
#define TFT_INVERT_ROTATION1 0
#define TFT_RGB_BGR 0x08Re: Documentation for ESP WROVER KIT 4.1
esp-wrover_kit 4.1
arduiono ide 1.8.2
Used library "WROVER_KIT_LCD.h"
Project "spitftbitmap.ino"
If the SD card is removed, the LCD works normally, if inserted, the screen is white. The Internet does not know the problem
. Can developers or experienced professionals tell me what the problem is?
arduiono ide 1.8.2
VerusLogic
I am seeing this same issue. The SD card initializs successfully but the display is blank. The jpegtest example works but only when the SD card is out.
Mike.
Mike.
VerusLogic
I found the problem here. The TFT uses GPIO21 for the DC pin. The SD card uses GPIO21 for the CD pin. If you remove R167 - which is at the bottom left corner of the WROVER module - it will disconnect GPIO21 from the SD card detect line and allow the LCD interface to function.
Mike.
Mike.
Hi Mike,
Nice tip, thank you for documenting it!
I will include this information in ESP-WROVER-KIT Getting Started Guide.
