Programming of ESP32 over JTAG
AmirHadi
Postby AmirHadi » Wed Nov 07, 2018 7:24 am
Hi ESpressif,
I am using the uBlox NINA-W101 Wi-Fi module in my design. It's datasheet outlines that the built in Wi-Fi chip is ESP32. I am wondering if it could be programmed using its JTAG interface?
I searched different forums and it appears that the JTAG programming of this Wi-Fi module is not possible. I also have a microprocessor on the board and I am wondering if it is possible to use the MCU as a USB-UART bridget to flash the firmware of the built in ESP32 through its UART interface. Because of space limitation on my PCB, I cannot add a FTDI USB-UART chip. I appreciate if you can send me any documentation/tutorial/sample code that I can use.
Thanks,
-Amir
igrr
Re: Programming of ESP32 over JTAG
Postby igrr » Wed Nov 07, 2018 7:59 am
Hi Amir,
It is possible to upload an application over JTAG using OpenOCD, provided that the application running on the module has not reconfigured JTAG pins (GPIOs 12-15) for some other function.
See this documentation page:
https://docs.espressif.com/projects/esp ... -app-debug
OpenOCD with support for ESP32 can be downloaded here:
https://github.com/espressif/openocd-esp32/releases
AmirHadi
Postby AmirHadi » Wed Nov 07, 2018 8:12 am
Thanks for your quick response. How can I make sure that the module (uBlox NINA-W101) I am going to purchase does not have its JTAG pins reconfigured? Is it possible to change the configuration again using the UART interface? Sorry if my questions are dumb. I am quite new in working with the ESP products. I appreciate any help.
Thanks,
-Amir
loboris
Postby loboris » Wed Nov 07, 2018 9:14 am
Hi ESpressif,
I'm just wondering why did you choose to use uBlox NINA-W101 in you design.
It is just repacked ESP32-D2WD with only 2MB Flash and offers less than ESP32-PICO-D4 in smaller package and 4 MB Flash.
It looks NINA-W101 was designed just to confuse the users about what it realy is...
igrr
Postby igrr » Wed Nov 07, 2018 11:12 am
Of course, you can erase or upload new firmware over UART0. For this, pins GPIO0, GPIO1 and GPIO3 (also known as U0TXD and U0RXD) need to be accessible.
AmirHadi
Postby AmirHadi » Wed Nov 07, 2018 5:05 pm
Great. It was very helpful. As the last question, Do you know if I can use the MCU ( STM32F446RE) as a USB to UART bridge to flash the firmware of the ESP32 module? Due to space limitations on the board, I cannot afford putting a FTDI USB to UART chip on the board.
Thanks foe being super helpful on this issue.
-Amir
AmirHadi
Postby AmirHadi » Wed Nov 07, 2018 7:16 pm
I got confused with the image below in the link on JTAG Documentation: https://docs.espressif.com/projects/esp ... w-it-works
JTAG Adapter.png (117.17 KiB) Viewed 21794 times
I do not have space on the board to add in the FTDI chip. I would like to use an external JTAG Adapter instead (and do not add in the UART interface) to program and debug both the MCU (STM32F446RE) and the Wi-Fi module.
In particular, by only having the section highlighted in yellow, is it possible to have the programming and debugging capability.
Regards,
-Amir
Users browsing this forum: Amazon [Bot], Baidu [Spider], Qwantbot, Semrush [Bot] and 4 guests
