Low Rate WIFI Protocol LR
Re: Low Rate WIFI Protocol LR
Postby rudi ;-) » Wed Mar 29, 2017 8:52 pm
@ivan
how does this looks to you ;-)
will test on weekend the thing outside.
txs for allways teaching us in the right position!
SoftAp: DevKitC V 2
Station: ESP32 Demo Board V2
Postby rudi ;-) » Thu Mar 30, 2017 12:58 am
Could not wait and not sleep
think it looks good..
the world's first "hello world" with low rate on esp32 ;-)
done!
left tcp server with low rate
listen
after client connect , send hello world
right tcp client with low rate
connect and receive data
Postby rudi ;-) » Thu Mar 30, 2017 3:49 am
ok, ready now for walking/flying
will add ping response time and GPS :)
asfakrahman86
Postby asfakrahman86 » Thu Aug 17, 2017 12:28 pm
what is the working distance did you get?
Valerii
Postby Valerii » Thu Jan 18, 2018 5:47 pm
Hi, I tried this code with present version of ESP-IDF and it fails. What could went wrong?
The debug console returns
"I (91) wifi: wifi firmware version: 403db1d
I (91) wifi: config NVS flash: enabled
I (91) wifi: config nano formating: disabled
I (91) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (101) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (131) wifi: Init dynamic tx buffer num: 32
I (131) wifi: Init data frame dynamic rx buffer num: 32
I (131) wifi: Init management frame dynamic rx buffer num: 32
I (131) wifi: wifi driver task: 3ffc02bc, prio:23, stack:4096
I (141) wifi: Init static rx buffer num: 10
I (141) wifi: Init dynamic rx buffer num: 32
I (151) wifi: wifi power manager task: 0x3ffc4efc prio: 21 stack: 2560
W (151) wifi: [b]ap start fail[/b]"
If I comment line with
esp_wifi_set_protocol
it works.
Please help
Valerii
Postby Valerii » Mon Jan 22, 2018 4:52 pm
Hello, all
I've prepared LR protocol demo based on 2 esp-wroom32 dev boards. I used esp-idf's tcp-perf example as base to prepare RX and TX nodes. I set up channel and protocol (
WIFI_PROTOCOL_LR
) and during the test I've got about 0.23Mbits/s throughput but the link range is similar to the same setup but using 802.11B protocol. The minimal RSSI level I've got was -92dBm.
Any advice to make the link range wider?
StijnVerhelst
Postby StijnVerhelst » Sun Feb 17, 2019 11:06 am
done!
listen
For my end-project for school I'm also exploring the world of the ESP32 LR mode. The distance I could get with this was around 140 meter. This was when sending only the character 'b' with this code I've found on the internet: https://github.com/jnogues/ESP32-Long-Range-WiFi.
1. Do you know how I can expand this distance (more than 140 meter), I'm using the doit esp32 devkit v1 without external antenna.
2. Do you still have the code that you were using at Thu Mar 30, 2017. With the "world's first "hello world" with low rate on esp32"?
Kind regards,
Stijn Verhelst
Users browsing this forum: ChatGPT-User, PerplexityBot, Semrush [Bot] and 7 guests
