You can take GPIO32..39 as Input. That's right!
But I need an 8-bit Output for the ILI9325 (ucg-lib) and the pseudo-Input for CAM at the same pins..
p.s.:
Have you found the missing Vsync ?
Use you the VSPI for your ILI9341?
At Prgr.3 I display the contents of the SD-card(not included-->see
http://esp32.com/viewtopic.php?f=19&t=702).
It is slow in VSPI (but right for slideshow)..
i build with DevKitC/Nano32 again and the OV7670, prinzipal works now.
must study the shematic from wRover kit V2,
there was a change on few pins,
one thing ,more, the QV7670 need pullups on SCL and RST must be pulled up ( 3.3 ) , the PWRDWN must pulled down ( GND ).
then OV7670 is talking SCCB, this result comes from "long night" testing,
for flashing with OV7670, break short RST from 3.3
http://esp32.com/viewtopic.php?f=12&t=344
- compare.png (77.16 KiB) Viewed 17940 times
btw the lcd D/C is same like Xclk.
rudi
( from SPI Flash )
"animated help service with audio"
on right side comes a live vid frame later.
- NoArduinoCode - its bareCode -
- FastPic.jpg (152.05 KiB) Viewed 17940 times
