W (287) spi_flash: Detected size(4096k) larger than the size in the binary image
header(2048k). Using the size in the binary image header.Code: Select all
header(2048k). Using the size in the binary image header.Default flash size configuration is 2 MByte which you need to change as per your flash size of hardware which you are using like 4 MByte or 16 MByte.When the chip boots I receive the following warning:What does it mean?Code: Select all
W (287) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
Great. Thanks for update.I had already selected the correct option and flashed the app multiple times. Reflashing the bootloader fixed the issue.
Hello,Hello again guys.. I found where to configure the
Flash Size ->menuconfig->Flash size, Select the value that the device has available...
