spi_flash size warning
raldone01
Postby raldone01 » Thu Jul 18, 2019 5:30 pm
When the chip boots I receive the following warning:
W (287) spi_flash: Detected size(4096k) larger than the size in the binary image
 header(2048k). Using the size in the binary image header.
What does it mean?
Re: spi_flash size warning
Postby Sprite » Mon Jul 22, 2019 3:54 am
It means that your software setup assumes you have a 2MiB chip (as indicated under make menuconfig, serial flasher settings, iirc), but your actual board is lucky enough to have a 4MiB one. The warning is just that, a warning to show you your software won't be able to use the other 2MiB that exists on your board.
Ritesh
Contact:
Postby Ritesh » Mon Jul 22, 2019 7:23 pm
What does it mean?
Default flash size configuration is 2 MByte which you need to change as per your flash size of hardware which you are using like 4 MByte or 16 MByte.
So, Please check by updating it and let us know if still same issue.
Regards,
Ritesh Prajapati
raldone01
Postby raldone01 » Wed Jul 24, 2019 1:01 pm
I had already selected the correct option and flashed the app multiple times. Reflashing the bootloader fixed the issue.
Ritesh
Contact:
Postby Ritesh » Thu Jul 25, 2019 5:13 am
Great. Thanks for update.
Let us know if any issue into future for same.
Regards,
Ritesh Prajapati
acsoprana
Postby acsoprana » Wed Nov 27, 2024 11:10 pm
Hello, I have the same problem, I have two devices, an esp32c6 with 8 mb of memory and the h2 with 4 mb, but in the terminal it informs that it will only use what is in the header of the binary image (2048k). Even setting in the ESP-IDF settings it only maintains the use of 2048k. How can I configure it to use the memory in its entirety?
acsoprana
Postby acsoprana » Thu Nov 28, 2024 8:13 pm
Hello again guys.. I found where to configure the
Flash Size ->menuconfig->Flash size, Select the value that the device has available...
Ritesh
Contact:
Postby Ritesh » Tue Dec 10, 2024 11:01 am
So you issue has been resolved? or still looking for support for your queries?
Regards,
Ritesh Prajapati
