I do have a board as mentioned above. This board is not the same as showing on https://docs.espressif.com/projects/esp ... -kit.html#. Is there a updated version of this documentation available?
The functionswitch has 4 positions. What are the switch positions?
What are the menuconfig Example Configuration settings?
Ethernet PHY Device (IP101)
Ethernet PHY Address?
Ethernet PHY Clock Mode?
Use PHY Power enable / disable) pin?
PHY Power GPIO?
SMI MDC Pin Number?
SMI MDIO Pin Number?
Can you share the latest hw-reference with me?
Thanks.
Joop
ESP32 Ethernet kit V1.1
Re: ESP32 Ethernet kit V1.1
What is the PHY chip on your Ethernet board? Would you take a photo of your board?
Joop
Hi Joop,
Documentation for ESP32-Ethernet-Kit V1.1 should be released soon. In the meantime please refer to https://dl.espressif.com/dl/schematics/ ... 190711.pdf. The PoE board is the same as in ESP32-Ethernet-Kit V1.0 you liked to.
HilverinkJ
- IMG_1265.jpg (728.25 KiB) Viewed 7055 times
- IMG_1260.jpg (807.02 KiB) Viewed 7055 times
Hi HilverinkJ,
Thanks for the updates. But the first attachment seems to be broken, would you please help check? Thanks.
Alvin
Alvin
Users browsing this forum: Perplexity-User and 2 guests
