I do have a board as mentioned above. This board is not the same as showing on https://docs.espressif.com/projects/esp ... -kit.html#. Is there a updated version of this documentation available?
The functionswitch has 4 positions. What are the switch positions?
What are the menuconfig Example Configuration settings?
Ethernet PHY Device (IP101)
Ethernet PHY Address?
Ethernet PHY Clock Mode?
Use PHY Power enable / disable) pin?
PHY Power GPIO?
SMI MDC Pin Number?
SMI MDIO Pin Number?
Can you share the latest hw-reference with me?
Thanks.
Joop
ESP32 Ethernet kit V1.1
Re: ESP32 Ethernet kit V1.1
What is the PHY chip on your Ethernet board? Would you take a photo of your board?
Joop
Hi Joop,
Documentation for ESP32-Ethernet-Kit V1.1 should be released soon. In the meantime please refer to https://dl.espressif.com/dl/schematics/ ... 190711.pdf. The PoE board is the same as in ESP32-Ethernet-Kit V1.0 you liked to.
HilverinkJ
- IMG_1265.jpg (728.25 KiB) Viewed 7052 times
- IMG_1260.jpg (807.02 KiB) Viewed 7052 times
Hi HilverinkJ,
Thanks for the updates. But the first attachment seems to be broken, would you please help check? Thanks.
Alvin
Alvin
