ESP-WROOM-32 AT commands firmware
WiFive
Re: ESP-WROOM-32 AT commands firmware
Postby WiFive » Wed Feb 08, 2017 11:12 pm
It might be configured to UART1 pins 16 & 17
https://github.com/espressif/esp32-at/b ... faults#L44
Postby rudi ;-) » Thu Feb 09, 2017 6:24 pm
hi
only a thinking, have not tested just in time ( later time )
can we use uart0 as AT command port, too ?
does it be enough to set it in the sdkconfig ?
Postby rudi ;-) » Thu Feb 09, 2017 7:48 pm
https://github.com/espressif/esp32-at/b ... ask.c#L363
fast and dirty custom at :mrgreen:
wind_energy
Postby wind_energy » Thu Feb 09, 2017 8:05 pm
rudi can you send me yours bin files? I still have now working at all ... I made connection to UART1 with no results ...
Postby rudi ;-) » Thu Feb 09, 2017 8:50 pm
hi
can you not compile too?
will prepair this next step.
checkt this steps:
- ? gnd connect between the esp32 modul and the "terminal usb adapter/uart1 brigde"
- ? Rx, Tx not swapped
- ? CR+LF at and of AT Command
- ? after boot, the log is on UART0, the ready for AT Command comes on UART1
fyi:
why you connect to the pins of modul and not to the pinheader 16,17, GND?
have a look:
tested with DevKitC and FTDI 232 ( bridge the uart1 out for AT Commands..)
wind_energy
Postby wind_energy » Thu Feb 09, 2017 9:09 pm
rudi - many thanks !!!! all works fine !! :) :)
thank you :)
Postby rudi ;-) » Thu Feb 09, 2017 9:15 pm
edit:
fine!
so you do not need the bin files any more?
ok - have phun!!
:mrgreen:
wind_energy
Postby wind_energy » Thu Feb 09, 2017 9:31 pm
at the moment don`t need it :) thanks any way :)
Postby rudi ;-) » Thu Feb 09, 2017 9:33 pm
ok Pawel - have phun! ;-)
Postby rudi ;-) » Fri Feb 10, 2017 12:24 am
hi
yes we can
( fine with make flash monitor too )
you do not need any more USB Adapter or others.
simple flash over the usb cable ( uart0 )
simple monitor over the usb cable ( uart0 )
"only one thing": uart_wait_tx_done(703): uart driver error
Users browsing this forum: Qwantbot, trendictionbot and 2 guests
