Schematic Review (Seems like a problem to me!)
MCUism
Postby MCUism » Sun May 03, 2020 10:57 am
Hi team,
I have attached my schematic here. I sense some problems with my strapping pins. I want to directly upload the code from the Rx and Tx pins. Som for this did I configure my strap pins correctly? Shall I proceed with my Layout?
https://photos.app.goo.gl/ZQi6PmXs7GNxj5Rz8
mikemoy
Re: Schematic Review (Seems like a problem to me!)
Postby mikemoy » Sun May 03, 2020 11:36 am
You missed IO0. This is the pin that puts it in bootstrap mode.
MCUism
Postby MCUism » Sun May 03, 2020 12:21 pm
Hi mikemoy, how should I strap that pin? Should I pull down it? I think i wanna strap both GPIO0 and GPIO2 pulled down. Anyways IO2 is pulled down and IO0 must be pulled down for downloading the code using Rx and Tx?
Please do help me out on this. Thank you so much in advance.
mikemoy
Postby mikemoy » Sun May 03, 2020 12:26 pm
The same way you strapped EN. But you wont need the cap.
Taken from the data sheet.
Annotation 2020-05-03 072917.jpg (97.7 KiB) Viewed 5944 times
MCUism
Postby MCUism » Sun May 03, 2020 5:59 pm
Hi mikemoy, can you also suggest me what care can I take while routing my RF trace to antenna. I am using this https://www.snapeda.com/parts/2450AT18B ... datasheet/ antenna and having a 4 layer stack up.
Top -> RF Layer
Second -> GND Plane
Third-> VCC Plane
Bottom-> Signal layer
Please do suggest me what guidelines should I follow for this type of antenna
mikemoy
Postby mikemoy » Mon May 04, 2020 12:48 am
I cannot. Routing the antenna takes real special care for impedance matching. This is not something one can just try, you MUST know what you are doing.
Users browsing this forum: Bing [Bot], Bytespider and 2 guests
