ESP-WROOM-32 AT commands firmware
klteng
Re: ESP-WROOM-32 AT commands firmware
Postby klteng » Sat Feb 25, 2017 4:24 pm
I tried to follow the steps to flash the ESP32-AT but seem doesn't work. I am quite confuse on the UART1 Tx and Rx pin number. Which pin number does it refer to? Is it the UART1 pin number on the ESP32 chipset?
Is there any full instruction on flashing the ESP32-AT and able to work?
Postby rudi ;-) » Mon Feb 27, 2017 10:33 am
.. I am quite confuse on the UART1 Tx and Rx pin number.
hi
it work's fantastic :)
chaning from
UART1 Tx
UART1 Rx
to UART0
pin list are here
http://espressif.com/sites/default/file ... ist_en.pdf
short view:
and you can use your own pins, that you have to select then in component config -> AT
hope this helps
wind_energy
Postby wind_energy » Tue Feb 28, 2017 7:27 am
hi,
If there is any solution to refresh joined devices IP? When I`m using AT+CWLIF as soon as I connect to station my smartphone it display IP address but it still appears whenever the smartphone is disconected.
ready
AT
OK
AT+CWMODE=3
OK
AT+CWDHCP=1,1
OK
AT+CWSAP="ESP_MAIN_W","",10,0
OK
AT+CWSAP?
+CWSAP:"ESP_MAIN_W","",10,0,10,0
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
0.0.0.0,5c:af:06:45:e0:21
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
192.168.4.2,5c:af:06:45:e0:21
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF    // here I`m disconected first time it works OK
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
192.168.4.2,5c:af:06:45:e0:21 // conected again
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
192.168.4.2,5c:af:06:45:e0:21 // disconected
OK
AT+CWLIF
192.168.4.2,5c:af:06:45:e0:21 // still apears IP of the smartphone
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
OK
AT+CWLIF
OK
Many thanks for any ideas :)
wind_energy
Postby wind_energy » Tue Feb 28, 2017 7:33 am
I have another problem and I don`t have any idea what I`m doing wrong. I can`t conect to the STATION from another ESP32 configured as a CLIENT.
STATION
ready
AT
OK
AT+CWMODE=3
OK
AT+CWDHCP=1,1
OK
OK
AT+CWSAP?
OK
CLIENT
AT
OK
AT+CWMODE=1
OK
AT+CWDHCP=1,1
OK
AT+CWLAP
+CWLAP:(0,"ESP_MAIN_W",-31,"24:0a:c4:02:ed:99",10)
OK
AT+CWJAP="ESP_MAIN_W","",
ERROR
Regards,
Pawel
Postby rudi ;-) » Tue Feb 28, 2017 1:05 pm
hi pawel,
i am on the road just in time
see on first view a mistake last character
try without the last
cause you use no pwd
try this too
let me know
wind_energy
Postby wind_energy » Tue Feb 28, 2017 2:26 pm
hi rudi,
When I`m using the terminal, everything works better.
OK
AT+CIPMUX=0
OK
AT+CIPSTART="UDP","192.168.4.1",909,909,0
CONNECT
OK
+IPD,7:wertyui
+IPD,7:wertyui
AT+CIPSEND=7
OK
Recv 7 bytes
SEND FAIL
AT+CIPSEND=7
OK
Recv 7 bytes
SEND FAIL  // SEND FAIL, why?? receiving works good, transmitting occurs the fail reports
AT+CIPSEND=7
OK
busy p...
Recv 7 bytes
SEND FAIL
AT+CIPSEND=7
OK
Recv 7 bytes
SEND FAIL
+IPD,7:wertyuiCLOSED
CONNECT
OK
AT+CIPSEND=7
OK
Recv 7 bytes
SEND FAIL
AT+CIPSEND=7
OK
Recv 7 bytes
SEND FAIL
When I`m using the AVR couple of things dosen`t work properly.
Most times I`m loosing the reception. Can`t find SSID name of the station on my celphone and another ESP32 modules.
As soon as I make communication through the terminal, most things works better. I`ve added the low ESR capacitor of 3300uF and ceramic 100nF but it doesn`t fix the problems.
I enclousure the picture of soldered modules.
Postby rudi ;-) » Tue Feb 28, 2017 5:42 pm
hi pawel
how looks your line in AVR to send msg over UART to esp?
AVR_Uart_printf("AT+.......\r\n");
how you send the "
wind_energy
Postby wind_energy » Tue Feb 28, 2017 7:40 pm
I`ve changed the ground and 9600 baudrate - at the moment works brilliant :D
Luca_Guazzaroni
Postby Luca_Guazzaroni » Wed Mar 01, 2017 11:35 am
Hello Rudi! thank you very much for your help.
In my las post i wrote twice that i've used the uart1. Actually in the second time i used the uart0 just like you do it.
Component Config -> AT (using a usb-serial adapter)
*uart port number for AT command = 0
*uart rx pin for AT command = 3
*uart tx pin for AT command = 1
After reading your answer, i tried using the same serial program with the same configuration that you use.
and also not works :(
Can you send me your bin files? to check if i am making some mistake at compilation or is another problem.
regards
Luca_Guazzaroni
Postby Luca_Guazzaroni » Wed Mar 01, 2017 2:45 pm
I think that the problem is the version of the esp-idf and esp-at-master example. the monitor console shows me:
E (1826) wifi: esp_wifi_set_storage 1230 wifi is not init
W (1832) wifi: wifi nvs_open fail ret=4353
E (1835) wifi: wifi_init 1191 ret=4353
assertion "0 && "esp_wifi_init(&cfg)"" failed: file "/home/xcg/workspace/esp_iot_at/esp-at-application/components/esp-at-core/./at_port.c", line 560, function: initialise_wifi
abort() was called at PC 0x400f732f
Guru Meditation Error: Core 0 panic'ed (abort)
And from what i could read in https://github.com/espressif/esp32-at/issues/6 and https://github.com/espressif/esp-idf/co ... a27e5bbdc7, a update may cause the problem. That's right?
Users browsing this forum: Applebot, Bytespider, Semrush [Bot] and 3 guests
