common power supply
nunocv
common power supply
Postby nunocv » Sun Sep 06, 2020 5:31 pm
arduino project external power supply.png (8.23 KiB) Viewed 2134 times
Hello,this is my first post, hope i'm on the right section, and that someone can point me in the right direction.
Can i connect my project components with a single external power supply like on the image?
Re: common power supply
Postby Sprite » Mon Sep 07, 2020 7:40 am
I assume each block is a module or devboard? Then, as long as all modules you have drawn are capable of running off 5V, it should work.
