Hello,this is my first post, hope i'm on the right section, and that someone can point me in the right direction.
Can i connect my project components with a single external power supply like on the image?
common power supply
Re: common power supply
I assume each block is a module or devboard? Then, as long as all modules you have drawn are capable of running off 5V, it should work.
