I2S ADC triggered with CAN data frame message
alega77
Postby alega77 » Fri Dec 18, 2020 3:34 pm
Hi All,
I am using a fast sampling ADC toghether with I2S. The goal is sampling the CAN bus (CAN_L) once a new data frame is incoming in the queue.
To get kind of syncronization I just do the i2s_adc_enable if there is a message in CAN message incoming, like reported below:
if(xQueueReceive(CAN_cfg.rx_queue,&rx_frame, 3*portTICK_PERIOD_MS)==pdTRUE){
      i2s_adc_enable(I2S_NUM_0);
      i2s_read(I2S_NUM_0, &buffer1, sizeof(buffer1), &bytes_read, 10);
      i2s_adc_disable(I2S_NUM_0);
By doing so, I get bit of ACK sometimes around 80 sample (over 100) (see CAN01.jpg), sometimes around 60/100 sample (see CAN02.jpg).
The question is: Is there a way to trigger the ADC with the SOF (start of frame bit) of the CAN frame on the CAN bus?
I set the ADC to obtain a sample per bit (500kpbs since the CAN network is configured with a data rate of 500kbps).
// i2s init function
void i2sInit(){
   i2s_config_t i2s_config = {
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_ADC_BUILT_IN),
    .sample_rate =  500000,              // The format of the signal using ADC_BUILT_IN
    .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, // is fixed at 12bit, stereo, MSB
    .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
    .communication_format = I2S_COMM_FORMAT_I2S_MSB,
    .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,      //ESP_INTR_FLAG_LEVEL1
    .dma_buf_count = 2,
    .dma_buf_len = 100,
    .use_apll = false,
    .tx_desc_auto_clear = false,
    .fixed_mclk = 0
   i2s_set_adc_mode(ADC_UNIT_1, ADC_INPUT);
   //i2s_adc_enable(I2S_NUM_0);
// CAN init funcion
void canInit(){
  CAN_cfg.speed=CAN_SPEED_500KBPS;    //can set speed
  CAN_cfg.tx_pin_id = GPIO_NUM_5;     // can set TX to pin 5
  CAN_cfg.rx_pin_id = GPIO_NUM_4;     // can set RX to pin 4
  CAN_cfg.rx_queue = xQueueCreate(1,sizeof(CAN_frame_t));  // mod queue size 1
  //start CAN Module
  ESP32Can.CANInit();
Thanks to everyone :D
Dazza0
Re: I2S ADC triggered with CAN data frame message
Postby Dazza0 » Mon Dec 21, 2020 1:48 pm
Currently no, the CAN controller will only generate an interrupt once a CAN message has been confirmed valid (i.e., Acknowledged and CRC is checked).
If you need an interrupt on the SOF, I think you might be better of routing the RX signal of your to a GPIO interrupt.
alega77
Postby alega77 » Tue Dec 22, 2020 5:45 pm
Many thanks for the suggestion.
I connected Pin 26 to the RX of the transceiver (sn65hvd230), so once the SOF rising is incoming it runs the ISR that do the i2s_adc_enable (see code below). In this way I can get a better syncronization (even if i loose some bit at beginning).
At least it seems something that it is replicable, as shown in CANsamples01 & 02. Same packet is sent but at different time.
Any other suggestion to improve the code? Thanks again a lot. :D
void IRAM_ATTR isr_sampling() {
    if(i2read){
      i2s_adc_enable(I2S_NUM_0);    //enable reading on ADC
      i2read = 0;
void setup() {
    // initialize pin 26 of ISR as input
    pinMode(pin_isr, INPUT);
    // Set pin 26 as interrupt, assign isr_sampling function and set RISING mode
    attachInterrupt(digitalPinToInterrupt(pin_isr), isr_sampling, RISING);
    //create a task that will be executed in the Task1code() function, with priority 1 and executed on core 0
    xTaskCreatePinnedToCore(
                    Task1CANcode,   /* Task function. */
                    "TaskCAN",     /* name of task. */
                    10000,       /* Stack size of task */
                    NULL,        /* parameter of the task */
                    3,           /* priority of the task - 3 highest, 0 lowest prioriy*/
                    &Task1CAN,      /* Task handle to keep track of created task */
                    0);          /* pin task to core 0 */
  delay(500);
void Task1CANcode( void * pvParameters ){
  Serial.print("TaskCAN running on core ");
  Serial.println(xPortGetCoreID());
  Serial.println("CAN demo");
  CAN_frame_t rx_frame;
  for(;;){
    //receive next CAN frame from queue
      if (bytes_read == sizeof(buffer1)&& !i2read) {  // if i2read == 0
        for(int i=0; i<buffer_len; i+=1){
          Serial.printf("%d,", offset - buffer1[i]);
        Serial.println();
        i2read = 1;
      printf("MSG from 0x%03x, DLC %d\n",rx_frame.MsgID,  rx_frame.FIR.B.DLC);
Users browsing this forum: DuckDuckGo [Bot] and 1 guest
