extern "C" void spi_task(void *pvParameters)
spi_transaction_t t;
esp_err_t ret;
int16_t k = 0;
uint16_t sendbuf[64] = {0};
uint16_t recvbuf[64] = {0};
uint16_t valorreal;
uint16_t aux2 = 0;
long start = 0;
long stop = 0;
memset(recvbuf, 122, 128);
memset(&t, 0, sizeof(t));
t.length= sizeof(sendbuf)*8;
t.rxlength = sizeof(recvbuf)*8;
t.rx_buffer=recvbuf;
t.tx_buffer = NULL;
gpio_set_level(GPIO_ERROR,1); // Sincronizar na inicialização o envio do FPGA
uint16_t aux;
printf("spi_task rodando no core: ");
printf("%u\n",xPortGetCoreID());
while(1)
xSemaphoreTake(rdySem, portMAX_DELAY); //Wait until slave is ready
ret=spi_device_transmit(handle, &t);
transf++;
start = xTaskGetTickCount();
for(int i = 0; i<64; i++ )
aux = recvbuf[i]; // Inserindo dados recebidos na fila
xQueueSend(xQueue, &aux, portMAX_DELAY);
stop = ((xTaskGetTickCount()-start)*portTICK_PERIOD_MS);
}Code: Select all
spi_bus_config_t buscfg={
.mosi_io_num=GPIO_MOSI,
.miso_io_num=GPIO_MISO,
.sclk_io_num=GPIO_SCLK,
.quadwp_io_num=-1,
.quadhd_io_num=-1
spi_device_interface_config_t devcfg={
.command_bits=0,
.address_bits=0,
.dummy_bits=0,
.mode=0,
.duty_cycle_pos=128,
.cs_ena_pretrans=10,
.cs_ena_posttrans=10, //Keep the CS low 3 cycles after transaction, to stop slave from missing the last bit when CS has less propagation delay than CLK
.clock_speed_hz=5000000,
.input_delay_ns=10,
.spics_io_num=GPIO_CS,
.flags = SPI_DEVICE_NO_DUMMY,
.queue_size=1
//Configuration for the handshake line
gpio_config_t io_conf={
.pin_bit_mask=(1<<GPIO_HANDSHAKE),
.mode=GPIO_MODE_INPUT,
.pull_up_en= GPIO_PULLUP_ENABLE,
.intr_type=GPIO_INTR_POSEDGE,
