Having problems with spiffs not mounting anymore
Minatel
Re: Having problems with spiffs not mounting anymore
Postby Minatel » Wed May 05, 2021 7:45 am
Can you test it using the "idf.py -p <PORT> flash monitor" in order to test without the VS Code IDF Extension? Can you also confirm your IDF version?
edouardreg
Postby edouardreg » Wed May 12, 2021 8:05 am
Same problem here since 1.0.3 esp-idf vscode extension.
What I have notice is that now when I use the extension Flash command, only the application is flashed and the storage.bin file is no more flashed into storage partion. So it seems to be a bug in the vs-code esp-idf extension v1.03 ?
bignacio
Postby bignacio » Wed May 12, 2021 8:24 am
We're very sorry for the issue.
We have made a fix here https://github.com/espressif/vscode-esp ... n/pull/406
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], PetalBot, Qwantbot and 5 guests
