Hi igrr,
Thanks for your reply, The crash backtrace is shown below.
[2021-07-20 11:35:39 337]Guru Meditation Error: Core 0 panic'ed (Interrupt wdt timeout on CPU0)
[2021-07-20 11:35:39 337]Core 0 register dump:
[2021-07-20 11:35:39 337]PC : 0x400915d2 PS : 0x00060b34 A0 : 0x800903ed A1 : 0x3ffd4e80
[2021-07-20 11:35:39 337]A2 : 0x3ffd3598 A3 : 0x3ffd4ff0 A4 : 0x00000c9f A5 : 0x3f408990
[2021-07-20 11:35:39 337]A6 : 0x3ffbf580 A7 : 0x00060023 A8 : 0x3ffd4ff0 A9 : 0x0000000f
[2021-07-20 11:35:39 338]A10 : 0x3ffd4ff0 A11 : 0x0000000f A12 : 0x00060b20 A13 : 0x00000001
[2021-07-20 11:35:39 373]A14 : 0x3ffeddf0 A15 : 0x3ffea57c SAR : 0x00000018 EXCCAUSE: 0x00000005
[2021-07-20 11:35:39 373]EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffffe
[2021-07-20 11:35:39 373]ELF file SHA256: eadf38922e335ed1
[2021-07-20 11:35:39 373]Backtrace: 0x400915cf:0x3ffd4e80 0x400903ea:0x3ffd4ea0 0x4008f514:0x3ffd4ec0 0x400ffb91:0x3ffd4f00 0x40136612:0x3ffd4f30
I used the add2line print the backtrace.
0x400915cf
vListInsert
/arm/esp-idf/components/freertos/list.c:205
0x400903ea
vTaskPlaceOnEventList
/arm/esp-idf/components/freertos/tasks.c:2901 (discriminator 2)
0x4008f514
xQueueGenericReceive
/arm/esp-idf/components/freertos/queue.c:1596
0x400ffb91
arch_os_mbox_fetch
/arm/miio_project/components/miio_sdk/arch/esp32/arch_os.c:352 (discriminator 4)
0x40136612
msg_fetch_block
/arm/miio_project/components/miio_sdk/miio_common/libs/d0/delayzero.c:631
Using backtrace, I traced the code to the following.
- code1.png (48.63 KiB) Viewed 7673 times
This code is just a loop waiting for the data, which is triggered by the mbedTLS to read the data.
So my question is why backtrace prints these information. If according to your condition of triggering the interrupt watchdog, I don't think it should print this task, because context switch has been prohibited.
