Help need, I made custom PCB using ESP32 bare chip in which I am facing issue in Bluetooth range
Please anyone assist me how to solve, and What type of data here I need to post for solve my problem ?
Re: Help need, I made custom PCB using ESP32 bare chip in which I am facing issue in Bluetooth range
You did proper RF design and matching or just hoped for the best?
It will help if you provide some more details about like:
Antenna layout/type
Antenna matching circuit (as mentioned before)
Schematic
Some PCB pictures
PCB layout (keep out zones) and stack-up
Case type (if applicable)
This is a typical issue in designs using the bare SoC without a proper antenna selection and matching circuit.
Antenna layout/type
Schematic
Some PCB pictures
Below is screenshot of schematicand pcb layout
- Screenshot from 2021-08-20 15-07-11.png (52.35 KiB) Viewed 6069 times
- Screenshot from 2021-08-20 15-02-54.png (61.68 KiB) Viewed 6069 times
We suggest you to send your design files to sales@espressif.com, we will provide a hardware review service. Design files include schematic ( pdf ) and layout ( we support AD, PADS and allegro ).
Please clarify your problems, issue in Bluetooth range is kindof ambiguous.
And please be noted that we upload reference designs of our modules and hardware design guidelines on our websites: https://www.espressif.com/en/support/do ... -documents, you could refer to them when you design.
@ESP_Minatel what is problem you have any solution ?
There are so many different issues you can find in RF designs.
As ESP_LJH said, send your files to our sales team and they will help to review your design.
Some of the common mistakes in RF designs are regarding the 50R impedance line (including trace thickness), matching circuit not tuned, traces/planes/components behind the antenna and many others.
It's hard to say the issue root cause without testing and checking if your antenna tuning was done correctly.
Hello
Actually I had sent. How much time take to get reply ?
