I followed some guide online on setting up the Arduino IDE up for the ESP32, however, I am not sure which board to select as there are a lot of types of ESP32 boards to choose from. I have the ESP32-WROOM-32, and do not see that specific one.
In the guide I used, the person has a "DOIT ESP32 DEVKIT V1."
The example I tried partially seems to function, but the guide states to "Press the ESP32 on-board Enable button." There is no "enable" button on the ESP32-WROOM-32.
I am not seeing anything in a search of the forum, nor in the documentation here on site.
Thanks!
Which board to select in Adruino IDE?
Re: Which board to select in Adruino IDE?
You can use the generic board by selecting the "ESP32 Dev Module" and change the configuration according to your board, like flash size.
Users browsing this forum: YisouSpider and 1 guest
