I followed some guide online on setting up the Arduino IDE up for the ESP32, however, I am not sure which board to select as there are a lot of types of ESP32 boards to choose from. I have the ESP32-WROOM-32, and do not see that specific one.
In the guide I used, the person has a "DOIT ESP32 DEVKIT V1."
The example I tried partially seems to function, but the guide states to "Press the ESP32 on-board Enable button." There is no "enable" button on the ESP32-WROOM-32.
I am not seeing anything in a search of the forum, nor in the documentation here on site.
Thanks!
Which board to select in Adruino IDE?
Re: Which board to select in Adruino IDE?
You can use the generic board by selecting the "ESP32 Dev Module" and change the configuration according to your board, like flash size.
