What is the difference between ESP32-wroom-32 and ESP- Wroom-32?
alsiavash1633
What is the difference between ESP32-wroom-32 and ESP- Wroom-32? Can they be used interchangeably?
alsiavash1633
Re: What is the difference between ESP32-wroom-32 and ESP- Wroom-32?
Some chips are ESP32-wroom-32 and some are ESP-Wroom-32. What is the difference between them? please reply .
Do you have links to the two? Those things aren't chips but modules btw.
alsiavash1633
Those are both different revisions of the same module; aside from potentially some RF changes there's not much difference between them. Be advised that you're likely to get a newer version of the module, however, as both modules were deprecated a fairly long time ago. As far as programming them goes, they're still exchangable (unless you use the GPIOs that are occupied by flash; they are NC in newer versions)
Users browsing this forum: Amazon [Bot] and 7 guests
