I have a ESP32 Thing from Sparkfun. I'm able to flash example hello world programs using the Arduino IDE and the espressif-IDF framework (e.g. examples given by both sparkfun and espressif).
The problem I'm running into is that when I run "make monitor" the output is all garbled. It seems like the serial line rate is incorrect. This doesn't make a lot of sense since I can flash the device successfully , i.e. there are no errors reported by the make flash command. As well, when running the arduino hello world sketch I can see the "hello world" text being written to the console.
Any suggestions as to what the issue may be or where I can look for more information?
Kind regards
David
IDF Monitor output is garbled
Re: IDF Monitor output is garbled
The Sparkfun Thing has a 26MHz crystal, while esp-idf is by default configured for an 40MHz crystal. In 'make menuconfig', if memory serves under components -> esp32 specific, you can change the crystal frequency.
gartnerd@gmail.com
In my scenario:
After flashing my Dev-Board by another computer, My spiffs partition popout only garbage now. So I erase the whole SPI-Flash chip with command "make erase_flash" and then manually select the speed of my XTAL as here descript. And everything works again!
Component_config -> ESP32-specific -> Main_XTAL_frequency So I change the speed manually
P.s:
What I still not clear is: Why this happened at all! Strange!
Cheers
Gfast2
P.s:
Cheers
Gfast2
I had the same problem with an ESP32+OLED https://www.allnet.de/lp/iot-wlan-display/
I've set the Main XTAL frequency to Autodetect and it works.
This fixed the issue I had with my TTGO LORA32 868/915Mhz SX1276 ESP32. Thank you:)!
WJCarpenter
Even after all this time, this posting helped solve this problem for me. Thanks!The Sparkfun Thing has a 26MHz crystal, while esp-idf is by default configured for an 40MHz crystal. In 'make menuconfig', if memory serves under components -> esp32 specific, you can change the crystal frequency.
Users browsing this forum: Semrush [Bot] and 1 guest
