"EXAMPLE CONIGURATION OPTION" not showing in menuconfig of ESP-IDF
Wajeeha77
Postby Wajeeha77 » Mon Apr 11, 2022 7:32 am
please help !!! I need to set WIFI SSID AND PASSWORD FOR ESP32 to get frames over the wifi but the option of 'EXAMPLE CONFIGURATION' is not appearing in menuconfig of ESP-IDF...
Minatel
Re: "EXAMPLE CONIGURATION OPTION" not showing in menuconfig of ESP-IDF
Postby Minatel » Mon Apr 11, 2022 7:59 am
Are you trying to use the ESP-IDF example? Can you give more details about it?
Wajeeha77
Postby Wajeeha77 » Mon Apr 11, 2022 8:08 am
I am using the code in this repo, following readme to acquire camera frames over the WIFI
https://github.com/luxonis/esp32-spi-me ... aming_wifi
RalphD
Postby RalphD » Mon Apr 11, 2022 8:28 am
try to build the example project first and then open menuconfig again.
Best wishes
Ralph
Wajeeha77
Postby Wajeeha77 » Mon Apr 11, 2022 9:08 am
Ralph build hello_world from examples folder. "idf.py menuconfig" again not showing "Example Configuration"... :( please help
Minatel
Postby Minatel » Mon Apr 11, 2022 9:22 am
Have you tried to ask help on the GitHub repo? You can open an issue there directly.
chegewara
Postby chegewara » Mon Apr 11, 2022 9:27 am
If you are trying to build "hello_world" example then you should read README from that example and not from some external repository.
In "hello_world" example there is no wifi used, so you wont find menu to configure anything in menuconfig.
RalphD
Postby RalphD » Mon Apr 11, 2022 12:57 pm
Very good point, obviously you should work on a sample project using WiFi :lol:
Wajeeha77
Postby Wajeeha77 » Mon Apr 11, 2022 8:00 pm
got it! thankyou so much!
siva4esp
Postby siva4esp » Fri Aug 18, 2023 4:38 am
[1] Under the project directory create a file at "main/Kconfig.projbuild"
[2] Add the following to the Kconfig.projbuild file:
menu "Example Configuration"
    orsource "$IDF_PATH/examples/common_components/env_caps/$IDF_TARGET/Kconfig.env_caps"
    config I2C_MASTER_SCL
        int "SCL GPIO Num"
        range ENV_GPIO_RANGE_MIN ENV_GPIO_OUT_RANGE_MAX
        default 19 if IDF_TARGET_ESP32 || IDF_TARGET_ESP32S2 || IDF_TARGET_ESP32S3
        default 0
        help
            GPIO number for I2C Master clock line.
    config I2C_MASTER_SDA
        int "SDA GPIO Num"
        default 18 if IDF_TARGET_ESP32 || IDF_TARGET_ESP32S2 || IDF_TARGET_ESP32S3
        default 1
        help
            GPIO number for I2C Master data line.
endmenu
[3] idf.py menuconfig
Users browsing this forum: Baidu [Spider], Google [Bot] and 1 guest
