"EXAMPLE CONIGURATION OPTION" not showing in menuconfig of ESP-IDF
please help !!! I need to set WIFI SSID AND PASSWORD FOR ESP32 to get frames over the wifi but the option of 'EXAMPLE CONFIGURATION' is not appearing in menuconfig of ESP-IDF...
- unknown.png (46.92 KiB) Viewed 7792 times
Re: "EXAMPLE CONIGURATION OPTION" not showing in menuconfig of ESP-IDF
Are you trying to use the ESP-IDF example? Can you give more details about it?
I am using the code in this repo, following readme to acquire camera frames over the WIFI
https://github.com/luxonis/esp32-spi-me ... aming_wifi
- dsdsd.PNG (35.12 KiB) Viewed 7763 times
try to build the example project first and then open menuconfig again.
Best wishes
Ralph
Best wishes
Ralph
Ralph build hello_world from examples folder. "idf.py menuconfig" again not showing "Example Configuration"...
please help
- add.PNG (43.89 KiB) Viewed 7761 times
Have you tried to ask help on the GitHub repo? You can open an issue there directly.
If you are trying to build "hello_world" example then you should read README from that example and not from some external repository.Ralph build hello_world from examples folder. "idf.py menuconfig" again not showing "Example Configuration"...please help
In "hello_world" example there is no wifi used, so you wont find menu to configure anything in menuconfig.
Very good point, obviously you should work on a sample project using WiFiIf you are trying to build "hello_world" example then you should read README from that example and not from some external repository.Ralph build hello_world from examples folder. "idf.py menuconfig" again not showing "Example Configuration"...please help
[1] Under the project directory create a file at "main/Kconfig.projbuild"
[2] Add the following to the Kconfig.projbuild file:
[3] idf.py menuconfig
menu "Example Configuration"
orsource "$IDF_PATH/examples/common_components/env_caps/$IDF_TARGET/Kconfig.env_caps"
config I2C_MASTER_SCL
int "SCL GPIO Num"
range ENV_GPIO_RANGE_MIN ENV_GPIO_OUT_RANGE_MAX
default 19 if IDF_TARGET_ESP32 || IDF_TARGET_ESP32S2 || IDF_TARGET_ESP32S3
default 0
help
GPIO number for I2C Master clock line.
config I2C_MASTER_SDA
int "SDA GPIO Num"
default 18 if IDF_TARGET_ESP32 || IDF_TARGET_ESP32S2 || IDF_TARGET_ESP32S3
default 1
help
GPIO number for I2C Master data line.
endmenuWho is online
