使用NVS Partition Generator Utility nvs读取不到key值
ChiShaoJun
Postby ChiShaoJun » Fri Apr 19, 2019 7:32 am
https://docs.espressif.com/projects/esp ... n_gen.html
我这边是按照上面的流程进行操作
要生成的test.csv
Code: Untitled.c Select all
key,type,encoding,value
namespace_name,namespace,,
key1,data,u8,1
转.bin指令
python ~/esp/esp-idf/components/nvs_flash/nvs_partition_generator/nvs_partition_gen.py --input test.csv --output test.bin --size 0x6000
分区表也进行了修改
# Espressif ESP32 Partition Table
# Note: if you change the phy_init or app partition offset
# make sure to change the offset in Kconfig.projbuild
nvs, data, nvs, 0x9000, 0x6000,
phy_init, data, phy, 0xf000, 0x1000,
factory, app, factory, 0x10000, 1200000,
读取的函数
#define TEST_STORAGE_NAMESPACE "namespace_name"    //nvs测试名字空间
uint8_t test_data = 0;
* 函数名称:get_nvs_csv_data
* 作 者:Kyle
* 日 期:20190419
* 描 述:测试nvs
* 输入参数:无
* 返 回 值:无
esp_err_t get_nvs_csv_data(void)
esp_err_t ret = ESP_FAIL;
esp_err_t err = ESP_FAIL;
nvs_handle read_nvs_handle;
size_t required_size = 1;
ESP_LOGI(SPP_TAG, "required_size:%d\n",required_size);
// Open
ESP_ERROR_CHECK(nvs_open(TEST_STORAGE_NAMESPACE, NVS_READWRITE, &read_nvs_handle));
// Read
err = nvs_get_blob(read_nvs_handle, "key1", &test_data, &required_size);
ESP_LOGI(SPP_TAG, "[ test data ]:%d\n",test_data);
if(err == ESP_OK)
ret = ESP_OK;
else if(err == ESP_ERR_NVS_NOT_FOUND)
ESP_LOGI(SPP_TAG,"ESP_ERR_NVS_NOT_FOUND\n");
// Commit
ESP_ERROR_CHECK(nvs_commit(read_nvs_handle));
// Close
nvs_close(read_nvs_handle);
return ret;
但是得到的日志出来是
I (264) SPP_ACCEPTOR_DEMO: required_size:1
I (274) SPP_ACCEPTOR_DEMO: [ test data ]:0
I (274) SPP_ACCEPTOR_DEMO: ESP_ERR_NVS_NOT_FOUND
if the requested key doesn't exist,key值不存在,请问下我是哪一步出现问题呢?
ChiShaoJun
Re: 使用NVS Partition Generator Utility nvs读取不到key值
Postby ChiShaoJun » Sun May 05, 2019 7:51 am
问题找到了,把read的函数换成nvs_get_u8就好了
I (262) SPP_ACCEPTOR_DEMO: required_size:1
I (272) SPP_ACCEPTOR_DEMO: [ test data ]:1
日志打印
