LyraT 4.3 records peak noise with rare chance in repeating recording
donaldzeng
Postby donaldzeng » Wed May 29, 2019 1:13 pm
I am testing with a LyraT 4.3 board, and running example pipeline_wav_sdcard. Firstly the origin example was running great and record one .wav file each time I ran it.
Then I wrapped it to record repeatedly with an increasing number as .wav filename. Something strange was discovered that with a small chance, the L or R channel data may be corrupted with pike noise. Say I ran for 1000 recording files, I might get 20 to 25 files with corrupted data, either L or R. I never see L and R corrupted at the same time.
Some investigation has been done. I am pretty sure the whole modification is just for wrapping recording into a separate task, and not relative to pipeline itself. Looking into the .wav data, it seems the corrupted voice data caused by slipping 1 bit, and then LSB of one is regarded as MSB of the next.
Did someone ever see this phenomenon, or even have an answer/solution in place? Thanks a lot.
donaldzeng
Re: LyraT 4.3 records peak noise with rare chance in repeating recording
Postby donaldzeng » Wed May 29, 2019 2:44 pm
with some corrupted .wav diagrams.
the diagram of L channel data corrupted
the diagram of R channel data corrupted
the diagram of zoom-in detail data corrupted
jason.mao
Postby jason.mao » Thu May 30, 2019 1:27 am
Hi donaldzeng,
Could you post you wav file at here? Does continuous recording different file can be reproduced?
donaldzeng
Postby donaldzeng » Thu May 30, 2019 1:51 am
Thanks for your quick reply. The problem, yes, can be reproduced in every long-time run, perhaps 1 or 2 time out of 100 times recording. I linked a wav file here: http://120.25.201.118/lotus/files/espbin/1304.wav.
CyprienAmigon
Postby CyprienAmigon » Tue Dec 05, 2023 5:42 pm
I'm facing exactly the same issue. I'm recording audio in several .wav files and some of them are randomly getting corrupted.
Just like the author, in some of my records (like 1 on 50 files) there are plenty of pikes at a maximum amplitude. I'm running a custom software, but the recording task is very similar to the example "pipeline_recording_to_sdcard" of ESP-ADF.
Did you find a solution ?
CyprienAmigon
Postby CyprienAmigon » Mon Jan 08, 2024 3:58 pm
No news ? :? :(
Minatel
Postby Minatel » Tue Jan 09, 2024 4:15 pm
Can you share more details?
