i2c read three segments error
sarah.frei
Postby sarah.frei » Mon Jul 29, 2019 4:10 pm
Hey,
I'm working on an ESP32-WROOM-32D, in which I have a bootloader.
in my bootloader, I do not use OS and I use an i2c.
the write on my i2c is not a problem, but I can not read in three segments.
the command for segments read are the following:
  • Segment0
    • RSTART
    • WRITE
    • READ
    • END
  • Segment1
    • READ
    • READ
    • END
  • Segment2
    • STOP
Here is the code for my reading:
	    // Segment 0
            p_i2c->rx_cnt = cmd->byte_num > p_i2c->rx_fifo_remain ? p_i2c->rx_fifo_remain : cmd->byte_num;
            cmd->byte_num -= p_i2c->rx_cnt;
            clear_int_status(i2c_num);
            I2C[i2c_num]->command[g_cmd_index_use].byte_num = p_i2c->rx_cnt;
            I2C[i2c_num]->command[g_cmd_index_use].ack_val = cmd->ack_val;
            I2C[i2c_num]->command[g_cmd_index_use+1].val = 0;
            I2C[i2c_num]->command[g_cmd_index_use+1].op_code = I2C_CMD_END;
            ESP_LOGI(I2C_TAG, "I2C_STATUS_READ");
            p_i2c->status = I2C_STATUS_READ;
            ESP_LOGI(I2C_TAG, "begin static start transfert");
            I2C[i2c_num]->int_clr.end_detect = 1;
            I2C[i2c_num]->int_ena.end_detect = 1;
            I2C[i2c_num]->ctr.trans_start = 0;
            I2C[i2c_num]->ctr.trans_start = 1;
            ets_delay_us(10);
            ESP_LOGI(I2C_TAG, "rx_cnt %d", p_i2c->rx_cnt);
            uint8_t readValue = 0;
            uint8_t readIndex = 0;
            while (p_i2c->rx_cnt-- > 0) {
                readValue = READ_PERI_REG(I2C_DATA_APB_REG(i2c_num));
                rx_data[readIndex] = readValue;
                readIndex++;
                ESP_LOGI(I2C_TAG, "-----------------read value %d----------------", readValue);
            // Segment 1
            i2c_master_read(cmdlink, &rx_data[1], 2, 0x0);
            i2c_master_read_byte(cmdlink, &rx_data[3], 0x1);
            i2c_master_stop(cmdlink);
            cmd = &g_cmd_desc[g_cmd_index_use];
            ESP_LOGI(I2C_TAG, "g_cmd_index_use %d, g_cmd_index %d, op_code %d", g_cmd_index_use,  g_cmd_index, cmd->op_code );
            I2C[i2c_num]->command[g_cmd_index_use].val = 0;
            I2C[i2c_num]->command[g_cmd_index_use].ack_en = cmd->ack_en;
            I2C[i2c_num]->command[g_cmd_index_use].ack_exp = cmd->ack_exp;
            I2C[i2c_num]->command[g_cmd_index_use].byte_num = cmd->byte_num;
            I2C[i2c_num]->command[g_cmd_index_use].op_code = cmd->op_code;
            ets_delay_us(10);
            readValue = 0;
            readIndex = 0;
                readIndex++;
reading the first segment works, I read the expected value. but for the second, I never receive the I2c_END_DETECT_INT interrupt and it seems that the master sends a STOP when it should not.
After reading segment0, the sda line is not released, and the slave does not send the rest of the data.
what I need to add / correct for the reading to go right?
Thanks for help
houwenxiang
Re: i2c read three segments error
Postby houwenxiang » Wed Jul 31, 2019 9:38 am
Hi, sarah.frei
Each hardware WRITE or READ command should be followed by an EDN command. So the reading code should be like this
RSTART
WRITE
END
READ
END
READ
END
READ
END (This END command can be omitted)
STOP
wookooho
sarah.frei
Postby sarah.frei » Wed Jul 31, 2019 10:56 am
Hi, sarah.frei
RSTART
WRITE
END
READ
END
READ
END
READ
STOP
Thanks for reply,
indeed an END command is sent after each WRITE or READ command.
Before the transmission of the command (I2C[i2c_num]->ctr.trans_start = 1) the following code is used to add the command END:
mohamed.raad
Postby mohamed.raad » Wed Jul 31, 2019 12:01 pm
Hello ESP_houwenxiang
As you can see there is a END command after each Read command in segment 1. Please check the code.
            // Segment 1
            ets_delay_us(10);
            readValue = 0;
            readIndex = 0;
                readIndex++;
As Sarah described, when the master read operation is ongoing the SDA line is held for some reason by ESP32 master.
mohamed.raad
Postby mohamed.raad » Wed Jul 31, 2019 12:06 pm
Hi ESP_houwenxiang,
As you can see in the code, in segment 1 there is always a END command after each read operation.
It is done through " I2C[i2c_num]->command[g_cmd_index_use+1].op_code = I2C_CMD_END; "
What we see is the SDA line behaves erratically during the 2nd read operation of the segment 1.
houwenxiang
Postby houwenxiang » Thu Aug 01, 2019 4:21 am
Can you provide the debug log?
When the EDN command is sent, we should fill in the next command from the first command register.
wookooho
