pulldown enable blocks
oliverbru
Postby oliverbru » Fri Sep 27, 2019 2:37 pm
Sorry to ask basic things but, I tried this code:
/* Hello World Example
#include "freertos/task.h"
#include "esp_system.h"
#include "driver/gpio.h"
#include "esp_log.h"
#include "sdkconfig.h"
#define BLINK_GPIO_GREEN 25
#define BUTTON GPIO_NUM_12
#define ESP_INTR_FLAG_DEFAULT 0
 int BUTTON_PRESSED;
void blink_task(void *pvParameter)
    while (1)
        BUTTON_PRESSED = gpio_get_level(BUTTON);
        ESP_LOGI("test", "BUTTON STATE : %d", BUTTON_PRESSED);
        gpio_set_level(BLINK_GPIO_GREEN, BUTTON_PRESSED);
static void IRAM_ATTR gpio_isr_handler()
    ets_printf("Button state : %d\n", BUTTON_PRESSED);
void app_main()
    gpio_pad_select_gpio(BLINK_GPIO_GREEN);
    gpio_set_direction(BLINK_GPIO_GREEN, GPIO_MODE_OUTPUT);
    gpio_config_t btn_config;
    btn_config.intr_type = GPIO_INTR_ANYEDGE ;
    btn_config.mode = GPIO_MODE_INPUT;               //Set as Input
    btn_config.pin_bit_mask = (1ULL << BUTTON); //Bitmask
    btn_config.pull_up_en = GPIO_PULLUP_DISABLE;     //Disable pullup
    btn_config.pull_down_en = GPIO_PULLDOWN_ENABLE; //Enable pulldown
    gpio_config(&btn_config);
    //install gpio isr service
    gpio_install_isr_service(ESP_INTR_FLAG_DEFAULT);
    //hook isr handler for specific gpio pin
    gpio_isr_handler_add(BUTTON, gpio_isr_handler, NULL);
    xTaskCreate(&blink_task, "blink_task", 1024*4, NULL, 1, NULL);
If I set GPIO_PULLDOWN_DISABLE, I have bounces.
Since I set GPIO_PULLDOWN_ENABLE, the interruption is not called and the button does not work.
I do not understand.
Regards,
mikemoy
Re: pulldown enable blocks
Postby mikemoy » Fri Sep 27, 2019 5:32 pm
How is your button wired up ?
oliverbru
Postby oliverbru » Fri Sep 27, 2019 11:00 pm
I attached the image.
mikemoy
Postby mikemoy » Sat Sep 28, 2019 1:24 am
Thanks, however there is no way i can tell by the photo. Does your button have a pullup resistor? It does not look like it.,
WiFive
Postby WiFive » Sat Sep 28, 2019 7:53 am
The button is connected to ground and the pulldown is connected to ground so all you will get is ground
Users browsing this forum: Amazon [Bot], Google [Bot], meta-externalagent, Semrush [Bot] and 5 guests
