unnable to run eth2wifi , need help
ht_main1
Postby ht_main1 » Sat Nov 02, 2019 6:51 am
i am trying to use eth2ap as eth2sta, i modified the given example to eth2sta, i had successfully run eth2ap example and wanted to modify it for STA, i also read the eth2wifi example in IOT-SOlutions, but i couldnt run it on my esp-idf version, hence i had need to modify the give example from eth2ap to eth2sta,
i believe i have done necessary changes rightly still i am unable to get it working,
following is modified code
/* eth2ap (Ethernet to Wi-Fi AP packet forwarding) Example
#include <string.h>
#include <stdlib.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "esp_event.h"
#include "esp_log.h"
#include "esp_eth.h"
#include "esp_wifi.h"
#include "nvs_flash.h"
#include "esp_private/wifi.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
static const char *TAG = "eth_example";
static esp_eth_handle_t s_eth_handle = NULL;
static xQueueHandle flow_control_queue = NULL;
static bool s_sta_is_connected = false;
static bool s_ethernet_is_connected = false;
static uint8_t s_eth_mac[6];
#define FLOW_CONTROL_QUEUE_TIMEOUT_MS (100)
#define FLOW_CONTROL_QUEUE_LENGTH (40)
#define FLOW_CONTROL_WIFI_SEND_TIMEOUT_MS (100)
typedef struct {
    void *packet;
    uint16_t length;
} flow_control_msg_t;
// Forward packets from Wi-Fi to Ethernet
static esp_err_t pkt_wifi2eth(void *buffer, uint16_t len, void *eb)
    if (s_ethernet_is_connected) {
        if (esp_eth_transmit(s_eth_handle, buffer, len) != ESP_OK) {
            ESP_LOGE(TAG, "Ethernet send packet failed");
    esp_wifi_internal_free_rx_buffer(eb);
    return ESP_OK;
// Forward packets from Ethernet to Wi-Fi
// Note that, Ethernet works faster than Wi-Fi on ESP32,
// so we need to add an extra queue to balance their speed difference.
static esp_err_t pkt_eth2wifi(esp_eth_handle_t eth_handle, uint8_t *buffer, uint32_t len)
    esp_err_t ret = ESP_OK;
    flow_control_msg_t msg = {
        .packet = buffer,
        .length = len
    if (xQueueSend(flow_control_queue, &msg, pdMS_TO_TICKS(FLOW_CONTROL_QUEUE_TIMEOUT_MS)) != pdTRUE) {
        ESP_LOGE(TAG, "send flow control message failed or timeout");
        free(buffer);
        ret = ESP_FAIL;
    return ret;
// This task will fetch the packet from the queue, and then send out through Wi-Fi.
// Wi-Fi handles packets slower than Ethernet, we might add some delay between each transmitting.
static void eth2wifi_flow_control_task(void *args)
    flow_control_msg_t msg;
    int res = 0;
    uint32_t timeout = 0;
    while (1) {
        if (xQueueReceive(flow_control_queue, &msg, pdMS_TO_TICKS(FLOW_CONTROL_QUEUE_TIMEOUT_MS)) == pdTRUE) {
            timeout = 0;
            if (s_sta_is_connected && msg.length) {
                do {
                    vTaskDelay(pdMS_TO_TICKS(timeout));
                    timeout += 2;
                    res = esp_wifi_internal_tx(ESP_IF_WIFI_AP, msg.packet, msg.length);
                } while (res && timeout < FLOW_CONTROL_WIFI_SEND_TIMEOUT_MS);
                if (res != ESP_OK) {
                    ESP_LOGE(TAG, "WiFi send packet failed: %d", res);
            free(msg.packet);
    vTaskDelete(NULL);
// Event handler for Ethernet
static void eth_event_handler(void *arg, esp_event_base_t event_base,
                              int32_t event_id, void *event_data)
    switch (event_id) {
    case ETHERNET_EVENT_CONNECTED:
        ESP_LOGI(TAG, "Ethernet Link Up");
        s_ethernet_is_connected = true;
        esp_eth_ioctl(s_eth_handle, ETH_CMD_G_MAC_ADDR, s_eth_mac);
        esp_wifi_set_mac(WIFI_IF_AP, s_eth_mac);
        ESP_ERROR_CHECK(esp_wifi_start());
    case ETHERNET_EVENT_DISCONNECTED:
        ESP_LOGI(TAG, "Ethernet Link Down");
        ESP_ERROR_CHECK(esp_wifi_stop());
    case ETHERNET_EVENT_START:
        ESP_LOGI(TAG, "Ethernet Started");
    case ETHERNET_EVENT_STOP:
        ESP_LOGI(TAG, "Ethernet Stopped");
    default:
// Event handler for Wi-Fi
static void wifi_event_handler(void *arg, esp_event_base_t event_base,
    switch (event_id) {
    case WIFI_EVENT_AP_STACONNECTED:
        ESP_LOGI(TAG, "Wi-Fi AP got a station connected");
        s_sta_is_connected = true;
        esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_AP, pkt_wifi2eth);
    case WIFI_EVENT_AP_STADISCONNECTED:
        ESP_LOGI(TAG, "Wi-Fi AP got a station disconnected");
        esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_AP, NULL);
    default:
static void initialize_ethernet(void)
    ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ESP_EVENT_ANY_ID, eth_event_handler, NULL));
    eth_mac_config_t mac_config = ETH_MAC_DEFAULT_CONFIG();
    eth_phy_config_t phy_config = ETH_PHY_DEFAULT_CONFIG();
// #if CONFIG_EXAMPLE_USE_INTERNAL_ETHERNET
     esp_eth_mac_t *mac = esp_eth_mac_new_esp32(&mac_config);
// #if CONFIG_EXAMPLE_ETH_PHY_IP101
    // esp_eth_phy_t *phy = esp_eth_phy_new_ip101(&phy_config);
// #elif CONFIG_EXAMPLE_ETH_PHY_RTL8201
    // esp_eth_phy_t *phy = esp_eth_phy_new_rtl8201(&phy_config);
// #elif CONFIG_EXAMPLE_ETH_PHY_LAN8720
    // esp_eth_phy_t *phy = esp_eth_phy_new_lan8720(&phy_config);
// #elif CONFIG_EXAMPLE_ETH_PHY_DP83848
    esp_eth_phy_t *phy = esp_eth_phy_new_dp83848(&phy_config);
// #endif
// #elif CONFIG_EXAMPLE_USE_SPI_ETHERNET
    // gpio_install_isr_service(0);
    // spi_device_handle_t spi_handle = NULL;
    // spi_bus_config_t buscfg = {
        // .miso_io_num = CONFIG_EXAMPLE_ETH_MISO_GPIO,
        // .mosi_io_num = CONFIG_EXAMPLE_ETH_MOSI_GPIO,
        // .sclk_io_num = CONFIG_EXAMPLE_ETH_SCLK_GPIO,
        // .quadwp_io_num = -1,
        // .quadhd_io_num = -1,
    // ESP_ERROR_CHECK(spi_bus_initialize(CONFIG_EXAMPLE_ETH_SPI_HOST, &buscfg, 1));
    // spi_device_interface_config_t devcfg = {
        // .command_bits = 1,
        // .address_bits = 7,
        // .mode = 0,
        // .clock_speed_hz = CONFIG_EXAMPLE_ETH_SPI_CLOCK_MHZ * 1000 * 1000,
        // .spics_io_num = CONFIG_EXAMPLE_ETH_CS_GPIO,
        // .queue_size = 20
    // ESP_ERROR_CHECK(spi_bus_add_device(CONFIG_EXAMPLE_ETH_SPI_HOST, &devcfg, &spi_handle));
    // /* dm9051 ethernet driver is based on spi driver */
    // eth_dm9051_config_t dm9051_config = ETH_DM9051_DEFAULT_CONFIG(spi_handle);
    // esp_eth_mac_t *mac = esp_eth_mac_new_dm9051(&dm9051_config, &mac_config);
    // esp_eth_phy_t *phy = esp_eth_phy_new_dm9051(&phy_config);
// #endif
    esp_eth_config_t config = ETH_DEFAULT_CONFIG(mac, phy);
    config.stack_input = pkt_eth2wifi;
    ESP_ERROR_CHECK(esp_eth_driver_install(&config, &s_eth_handle));
    esp_eth_ioctl(s_eth_handle, ETH_CMD_S_PROMISCUOUS, (void *)true);
static void initialize_wifi(void)
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, wifi_event_handler, NULL));
    ESP_ERROR_CHECK(tcpip_adapter_clear_default_wifi_handlers());
    ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
    wifi_config_t wifi_config = {
        .ap = {
            .ssid = CONFIG_EXAMPLE_WIFI_SSID,
            .ssid_len = strlen(CONFIG_EXAMPLE_WIFI_SSID),
            .password = CONFIG_EXAMPLE_WIFI_PASSWORD,
            .max_connection = CONFIG_EXAMPLE_MAX_STA_CONN,
            .authmode = WIFI_AUTH_WPA_WPA2_PSK
    if (strlen(CONFIG_EXAMPLE_WIFI_PASSWORD) == 0) {
        wifi_config.ap.authmode = WIFI_AUTH_OPEN;
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
static esp_err_t initialize_flow_control(void)
    flow_control_queue = xQueueCreate(FLOW_CONTROL_QUEUE_LENGTH, sizeof(flow_control_msg_t));
    if (!flow_control_queue) {
        ESP_LOGE(TAG, "create flow control queue failed");
        return ESP_FAIL;
    BaseType_t ret = xTaskCreate(eth2wifi_flow_control_task, "flow_ctl", 2048, NULL, (tskIDLE_PRIORITY + 2), NULL);
    if (ret != pdTRUE) {
        ESP_LOGE(TAG, "create flow control task failed");
        return ESP_FAIL;
    return ESP_OK;
void app_main(void)
	int tmp=0;
    ESP_ERROR_CHECK(ret);
    ESP_ERROR_CHECK(initialize_flow_control());
	gpio_pad_select_gpio(GPIO_NUM_14);
    gpio_pad_select_gpio(GPIO_NUM_2);
    gpio_pad_select_gpio(GPIO_NUM_16);
	gpio_set_direction(GPIO_NUM_16 , GPIO_MODE_OUTPUT );
	gpio_set_direction(GPIO_NUM_2 , GPIO_MODE_OUTPUT );
	gpio_set_direction(GPIO_NUM_14 , GPIO_MODE_OUTPUT );
    vTaskDelay(10 / portTICK_RATE_MS);
	printf("Set OSC EN  = 1");
	tmp = 1;
	while(++tmp < 10){
		printf("init GPIO\n\r");
		gpio_set_level(GPIO_NUM_14, 1);
		gpio_set_level(GPIO_NUM_16, 0);
		gpio_set_level(GPIO_NUM_2, 1);
		vTaskDelay(100 / portTICK_RATE_MS);
		gpio_set_level(GPIO_NUM_2, 0);
		gpio_set_level(GPIO_NUM_16, 1);
		printf("get gpio14 %d\n\r", gpio_get_level(GPIO_NUM_14));
    initialize_ethernet();
    initialize_wifi();
also i have attached event log,
[0;32mI (13) boot: ESP-IDF v4.1-dev-369-g4dac7c7df-dirty 2nd stage bootloader[0m
[0;32mI (13) boot: compile time 17:25:48[0m
[0;32mI (13) boot: Enabling RNG early entropy source...[0m
[0;32mI (18) boot: SPI Speed : 40MHz[0m
[0;32mI (23) boot: SPI Mode : DIO[0m
[0;32mI (27) boot: SPI Flash Size : 4MB[0m
[0;32mI (31) boot: Partition Table:[0m
[0;32mI (34) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (42) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m
[0;32mI (49) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (56) boot: 2 factory factory app 00 00 00010000 00100000[0m
[0;32mI (64) boot: End of partition table[0m
[0;32mI (68) boot_comm: mismatch chip revision, expect 1, found 0[0m
[0;32mI (74) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x162f4 ( 90868) map[0m
[0;32mI (116) esp_image: segment 1: paddr=0x0002631c vaddr=0x3ffb0000 size=0x031e4 ( 12772) load[0m
[0;32mI (121) esp_image: segment 2: paddr=0x00029508 vaddr=0x40080000 size=0x00400 ( 1024) load[0m
[0;32mI (123) esp_image: segment 3: paddr=0x00029910 vaddr=0x40080400 size=0x06700 ( 26368) load[0m
[0;32mI (143) esp_image: segment 4: paddr=0x00030018 vaddr=0x400d0018 size=0x67584 (423300) map[0m
[0;32mI (294) esp_image: segment 5: paddr=0x000975a4 vaddr=0x40086b00 size=0x0a208 ( 41480) load[0m
[0;32mI (322) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (323) boot: Disabling RNG early entropy source...[0m
[0;32mI (323) cpu_start: Pro cpu up.[0m
[0;32mI (327) cpu_start: Application information:[0m
[0;32mI (331) cpu_start: Project name: eth2ap[0m
[0;32mI (336) cpu_start: App version: 1[0m
[0;32mI (341) cpu_start: Compile time: Nov 1 2019 17:44:06[0m
[0;32mI (347) cpu_start: ELF file SHA256: 62b21cc0512767cf...[0m
[0;32mI (353) cpu_start: ESP-IDF: v4.1-dev-369-g4dac7c7df-dirty[0m
[0;32mI (360) cpu_start: Starting app cpu, entry point is 0x4008117c[0m
[0;32mI (0) cpu_start: App cpu up.[0m
[0;32mI (370) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (377) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m
[0;32mI (383) heap_init: At 3FFB8858 len 000277A8 (157 KiB): DRAM[0m
[0;32mI (389) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[0m
[0;32mI (396) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (402) heap_init: At 40090D08 len 0000F2F8 (60 KiB): IRAM[0m
[0;32mI (408) cpu_start: Pro cpu start user code[0m
[0;32mI (427) spi_flash: detected chip: generic[0m
[0;32mI (427) spi_flash: flash io: dio[0m
[0;32mI (427) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (0) cpu_start: Starting scheduler on APP CPU.[0m
[0;32mI (3712) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
[0;32mI (3722) eth_example: Ethernet Started[0m
I (3732) wifi: wifi driver task: 3ffc34e4, prio:23, stack:3584, core=0
[0;32mI (3732) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[0m
I (3762) wifi: wifi firmware version: c01c829
I (3762) wifi: config NVS flash: enabled
I (3762) wifi: config nano formating: disabled
I (3762) wifi: Init dynamic tx buffer num: 32
I (3762) wifi: Init data frame dynamic rx buffer num: 32
I (3772) wifi: Init management frame dynamic rx buffer num: 32
I (3772) wifi: Init management short buffer num: 32
I (3782) wifi: Init static rx buffer size: 1600
I (3782) wifi: Init static rx buffer num: 10
I (3792) wifi: Init dynamic rx buffer num: 32
[0;32mI (9692) eth_example: Ethernet Link Up[0m
[0;32mI (9782) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0[0m
I (9782) wifi: mode : sta (24:0a:c4:24:fa:ff)
SYSTEM_EVENT_STA_START
I (9902) wifi: new:<6,0>, old:<1,0>, ap:<255,255>, sta:<6,0>, prof:1
I (10442) wifi: state: init -> auth (b0)
I (10442) wifi: state: auth -> assoc (0)
I (10462) wifi: state: assoc -> run (10)
I (10742) wifi: connected with heaptronix, channel 6, BW20, bssid = 78:cd:8e:8b:6b:3e
I (10742) wifi: pm start, type: 1
SYSTEM_EVENT_STA_CONNECTED
kindly let me know any mistake in code, looking forward for guidance,
regards
sushant
ht_main1
Re: unnable to run eth2wifi , need help
Postby ht_main1 » Sun Nov 03, 2019 7:07 am
 // macffr.pmode = EMAC_PROMISCUOUS_DISABLE;
	macffr.pmode = EMAC_PROMISCUOUS_ENABLE;
as recommended in this post, i tried enabling the promiscuous mode in file,
but its still not working
ht_main1
Postby ht_main1 » Sun Nov 03, 2019 10:48 am
the post is not helpful as
the same enables promiscuous mode
WiFive
Postby WiFive » Sun Nov 03, 2019 10:50 am
The code you posted does not even set sta mode
ht_main1
Postby ht_main1 » Sun Nov 03, 2019 11:37 am
thanks for giving your time and inputs
Sorry for inconvenience i had 2 files opened at same instance,
following is code for STA
#include <string.h>
#include <stdlib.h>
static bool wifi_is_connected = false; // for STA
typedef struct {
    void *packet;
    uint16_t length;
void printHEX(char *buffer, int n)
	for (int i = 0; i < n; i++)
		printf("%02X", buffer[i]);
	printf("\n[i]\n");
	ESP_LOGI(TAG, "wifi-2-eth");
		printf("[Wi-Fi to Ethernet]\n\r");
		printHEX(buffer, len);
    return ESP_OK;
        .packet = buffer,
        .length = len
        ESP_LOGI(TAG, "send flow control message failed or timeout");
        free(buffer);
        ret = ESP_FAIL;
    return ret;
    int res = 0;
    while (1) {
            timeout = 0;
            if ((wifi_is_connected || s_sta_is_connected )&& msg.length) {
				ESP_LOGI(TAG, "wifi is conneceted");
                do {
                    timeout += 2;
					printf("[Ethernet 2 Wi-Fi.]\n\r");
					printHEX(msg.packet, msg.length);
                    res = esp_wifi_internal_tx(ESP_IF_WIFI_STA, msg.packet, msg.length);
                    ESP_LOGI(TAG, "WiFi send packet failed: %d", res);
            free(msg.packet);
    vTaskDelete(NULL);
    switch (event_id) {
        esp_wifi_set_mac(WIFI_IF_STA, s_eth_mac);
        ESP_LOGI(TAG, "ETH_MAC:%X:%X:%X:%X:%X:%X", s_eth_mac[0],s_eth_mac[1],s_eth_mac[2],s_eth_mac[3],s_eth_mac[4],s_eth_mac[5]);
		esp_wifi_connect();
    default:
    switch (event_id) {
	case SYSTEM_EVENT_STA_START:
		printf("SYSTEM_EVENT_STA_START\r\n");
	case SYSTEM_EVENT_STA_CONNECTED:
		printf("SYSTEM_EVENT_STA_CONNECTED\r\n");
		wifi_is_connected = true;
		esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_STA, (wifi_rxcb_t)pkt_wifi2eth);
	case SYSTEM_EVENT_STA_GOT_IP:
		printf("SYSTEM_EVENT_STA_GOT_IP\r\n");
	case SYSTEM_EVENT_STA_DISCONNECTED:
		printf("SlYSTEM_EVENT_STA_DISCONNECTED\r\n");
		esp_wifi_internal_reg_rxcb(ESP_IF_WIFI_STA, NULL);
		esp_wifi_connect();
    default:
// #endif
        // .mode = 0,
        // .queue_size = 20
// #endif
        .sta = {
            .ssid = "Guren Mark 3",
            .password = "sush2019",
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
    ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config));
	//ESP_ERROR_CHECK(esp_wifi_start());
	//esp_wifi_connect();
        return ESP_FAIL;
        return ESP_FAIL;
    return ESP_OK;
void app_main(void)
	int tmp=0;
	tmp = 1;
	while(++tmp < 10){
    initialize_wifi();
ht_main1
Postby ht_main1 » Mon Nov 04, 2019 6:22 am
anyone ?
ht_main1
Postby ht_main1 » Tue Nov 05, 2019 6:18 am
can anybody explain why we have to MAC address for AP, and how will it work in STA mode ?
ht_main1
Postby ht_main1 » Wed Nov 06, 2019 5:51 am
anyone who can help ?
ht_main1
Postby ht_main1 » Thu Nov 07, 2019 7:21 am
top
makischu
Postby makischu » Sat Sep 11, 2021 11:58 am
It may be late for you, but I also tried to run eth2wifi, failed first, and finally was successful. I had to make same changes to the ESP-IDF code to get it running on version 4.3. Here I wrote down details:
https://github.com/makischu/ESP_eth2wifi
Hope this is helpful for people in the same situation.
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User, Semrush [Bot] and 2 guests
