JTAG debugging guide for ESP32 with debugging example
Postby rudi ;-) » Sat Mar 04, 2017 10:18 am
hi guys,
thanks for the great work on it.
JTAG Debugging for ESP32
V 1.0
2017 March 1
PDF
This document provides a guide to installing OpenOCD for ESP32 and debugging using gdb in a Linux virtual machine.
it comes with a debugging example.
please visit allways espressif ESP32 document resource for newer update or new guide's
imtiaz
Re: JTAG debugging guide for ESP32 with debugging example
Postby imtiaz » Tue Mar 14, 2017 3:22 am
Hi ,
Is there an equivalent guide for windows ?
imtiaz
perryc
Postby perryc » Sun Mar 19, 2017 4:34 pm
Got a TIAO USB JTAG V2 board (http://www.diygadget.com/tiao-usb-multi ... erial.html) running using the Espressif's JTAG Debugging doc under x86_64 Linux.
Here's a few notes:
Install the linux FTDI driver http://www.ftdichip.com/Drivers/D2XX.htm
Do as described in ReadMe.txt but was unable to get a "sudo ./EEPROM/read/read" to work until building and installing the patch described here: http://www.tiaowiki.com/forums/index.ph ... l#msg11408
6 Connections needed: TUMPA JTAG<->WROOM32
1<->3.3v
4<->GND
5<->1012
7<->IO14
9<->IO13
13<->IO15
