Can GPIO affect WiFi ?
GeorgeFlorian1
Postby GeorgeFlorian1 » Thu Jul 08, 2021 2:26 pm
Board: ESP32 Wrover-B DevKit v4
I am struggling to connect to an ESP32-Wrover-B's softAP.
I have PIN 17 and PIN 19 acting as TX, respectively as RX. They are connected to a CubeOrange flight controller as I am trying to establish a serial communication.
And whenever they are connected, the softAP won't assign an IP address to the device that I am trying to connect with.
But, it works properly when I do not have any GPIO connections.
The drone Serial Port has 3v3 signals: https://github.com/ArduPilot/ardupilot/ ... /CubeBlack
I am using PIN17 and PIN19 as they are labeled on the board.
In code they are written as GPIO_NUM_17 and GPIO_NUM_19.
First question: are they the same on the Wrover ? Is PIN17 the same as GPIO17 ? The same with 19.
I am asking this because I have tried using PIN16(as labeled on the board) as GPIO_NUM_16 an it did not work.
Second question: can the GPIOs state affect WiFi in some way ?
softAP starts and then stops without giving the device that I am trying to connect with an IP address.
I (112188) wifi: new:<1,0>, old:<1,0>, ap:<1,0>, sta:<255,255>, prof:1
I (112188) wifi: station: 2e:fa:09:ac:34:43 join, AID=1, b, 20
␛[0;32mI (112268) DB_ESP32: Wifi AP started!␛[0m
I (130488) wifi: station: 2e:fa:09:ac:34:43 leave, AID = 1, bss_flags is 131121, bss:0x3ffc935c
I (130488) wifi: new:<1,0>, old:<1,0>, ap:<1,0>, sta:<255,255>, prof:1
␛[0;32mI (130488) DB_ESP32: Wifi AP stopped!␛[0m
I am trying to implement this project: https://github.com/DroneBridge/ESP32.
It is not my code.
static void wifi_event_handler(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data)
    wifi_event_ap_staconnected_t *event;
    wifi_event_ap_stadisconnected_t* evente;
    switch (event_id) {
        case SYSTEM_EVENT_AP_START:
            ESP_LOGI(TAG, "Wifi AP started!");
            xEventGroupSetBits(wifi_event_group, BIT2);
        case SYSTEM_EVENT_AP_STOP:
            ESP_LOGI(TAG, "Wifi AP stopped!");
        case SYSTEM_EVENT_AP_STACONNECTED:
            event = (wifi_event_ap_staconnected_t *) event_data;
            ESP_LOGI(TAG, "Client connected - station:"MACSTR", AID=%d", MAC2STR(event->mac), event->aid);
        case SYSTEM_EVENT_AP_STADISCONNECTED:
            evente = (wifi_event_ap_stadisconnected_t*) event_data;
            ESP_LOGI(TAG, "Client disconnected - station:"MACSTR", AID=%d",
                     MAC2STR(evente->mac), evente->aid);
        default:
void start_mdns_service()
    xEventGroupWaitBits(wifi_event_group, BIT2, false, true, portMAX_DELAY);
    //initialize mDNS service
    esp_err_t err = mdns_init();
    if (err) {
        printf("MDNS Init failed: %d\n", err);
        return;
    ESP_ERROR_CHECK(mdns_hostname_set("dronebridge"));
    ESP_ERROR_CHECK(mdns_instance_name_set("DroneBridge for ESP32"));
    ESP_ERROR_CHECK(mdns_service_add(NULL, "_http", "_tcp", 80, NULL, 0));
    ESP_ERROR_CHECK(mdns_service_add(NULL, "_db_proxy", "_tcp", APP_PORT_PROXY, NULL, 0));
    ESP_ERROR_CHECK(mdns_service_add(NULL, "_db_comm", "_tcp", APP_PORT_COMM, NULL, 0));
    ESP_ERROR_CHECK(mdns_service_instance_name_set("_http", "_tcp", "DroneBridge for ESP32"));
void init_wifi(){
    wifi_event_group = xEventGroupCreate();
    tcpip_adapter_init();
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &wifi_event_handler, NULL));
    ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
    wifi_config_t ap_config = {
            .ap = {
                    .ssid = "Init DroneBridge ESP32",
                    .ssid_len = 0,
                    .authmode = WIFI_AUTH_WPA_PSK,
                    .channel = DEFAULT_CHANNEL,
                    .ssid_hidden = 0,
                    .beacon_interval = 100,
                    .max_connection = 10
    xthal_memcpy(ap_config.ap.ssid, DEFAULT_SSID, 32);
    xthal_memcpy(ap_config.ap.password, DEFAULT_PWD, 64);
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_AP));
    ESP_ERROR_CHECK(esp_wifi_set_protocol(ESP_IF_WIFI_AP, WIFI_PROTOCOL_11B));
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_AP, &ap_config));
    wifi_country_t wifi_country = {.cc = "XX", .schan = 1, .nchan = 13, .policy = WIFI_COUNTRY_POLICY_MANUAL};
    ESP_ERROR_CHECK(esp_wifi_set_country(&wifi_country));
    ESP_ERROR_CHECK(esp_wifi_start());
    ESP_ERROR_CHECK(tcpip_adapter_set_hostname(TCPIP_ADAPTER_IF_AP, "DBESP32"));
    ESP_ERROR_CHECK(tcpip_adapter_dhcps_stop(TCPIP_ADAPTER_IF_AP));
    tcpip_adapter_ip_info_t ip_info;
    IP4_ADDR(&ip_info.ip, 192,168,2,1);
    IP4_ADDR(&ip_info.gw, 192,168,2,1);
    IP4_ADDR(&ip_info.netmask, 255,255,255,0);
    ESP_ERROR_CHECK(tcpip_adapter_set_ip_info(TCPIP_ADAPTER_IF_AP, &ip_info));
    ESP_ERROR_CHECK(tcpip_adapter_dhcps_start(TCPIP_ADAPTER_IF_AP));
felmue
Re: Can GPIO affect WiFi ?
Postby felmue » Thu Jul 08, 2021 3:38 pm
Hello @GeorgeFlorian1
the ESP32 Wrover-B module has PSRAM, which requires GPIO 16 and 17 so you cannot use those for anything else.
Felix
GeorgeFlorian1
Postby GeorgeFlorian1 » Mon Jul 12, 2021 11:52 am
Felix
I've moved to GPIO 18 and 19. These are connected to the drones RX and TX pins respectively. The measured voltages on these pins is 3v3.
I am powering the ESP using the USB from the PC.
Whenever I power up the drone, the ESP won't assign an IP to the device that's trying to connect to the softAP.
felmue
Postby felmue » Mon Jul 12, 2021 12:43 pm
hmm, not sure what's happening here.
Are there any errors in the log? Have you tried another power source, like an USB adapter or power bank?
Felix
GeorgeFlorian1
Postby GeorgeFlorian1 » Tue Jul 13, 2021 11:35 am
Felix
I don't have other power sources.
I can power up the ESP using an USB cable or using a 5V from the Flight Controller.
I got advised against powering up the ESP using 5V, so that leaves only the USB cable from the PC.
Whenever I have the GPIOs (18,19,21,22) acting as RX and TX and connected to the Flight Controller the ESP doesn't assign IP Addresses.
I have enabled Verbose logs and I've posted them here: https://github.com/espressif/esp-idf/issues/7268
There doesn't appear to be any errors. On the other hand, I am not skilled in reading them.
Postby Sprite » Wed Jul 14, 2021 12:59 am
I'm idly wondering if the flight controller possibly outputs EMC on these lines, interfering with the ESP32s WiFi capability... Could you e.g. add a small capacitor (2.2pF or so) to ground on these lines, see if that makes a difference?
