Static task works, dynamic not - Not enough memory?
mateo_
Postby mateo_ » Mon Apr 11, 2022 8:46 am
I have running code but for some time now adding new line of code (e.g. MDF_LOGI or watchdog) causes problem with initialization of program when I load wifi configuration, ... etc. from NVS.
I needed to add watchdogs to both tasks.
I guess its a problem with memory because I changed one task from dynamic to static and it works fine again.
So I have 3 cases:
1. Adding watchdog to one task - WORKS
xTaskCreate(communication_task, "communication_task", 4 * 1024, NULL, 6, NULL);
xTaskCreate(VL53L0X_task, "VL53L0X_task", 4 * 1024, NULL, 4, &xHandle_VL53L0X);
MDF_ERROR_ASSERT( esp_task_wdt_init(100,1) );
MDF_ERROR_ASSERT( esp_task_wdt_add(xHandle_VL53L0X) );
2. Adding watchdog to second task - DOESN'T WORK (compiles but fails during initialization from NVS)
xTaskCreate(communication_task, "communication_task", 2 * 1024, NULL, 6, &xHandle_communication);
MDF_ERROR_ASSERT( esp_task_wdt_add(xHandle_communication) );
3. Adding watchdog to second task and changing it to static- WORKS AGAIN (compiles but fails during initialization from NVS)
xHandle_communication = xTaskCreateStatic(
                communication_task,
                4 * 1024,
                ( void * ) 1,
                6,
                xStack,
                &xTaskBuffer );
Is it a problem with memory? If so which memory is responislble for that and how can I check it?
Thanks in advance and best regards,
Mateusz
Re: Static task works, dynamic not - Not enough memory?
Postby Sprite » Tue Apr 12, 2022 7:56 am
1. How does it fail?
2. 4K is a very low amount of stack you're allocating. Try to increase that, see if it fixes things.
mateo_
Postby mateo_ » Tue Apr 12, 2022 10:16 am
1. Those are logs from monitor, the error is in wifi initialization function. But during debuging, the error appeard on earlier stage of program, so I guess it isn't the cause
error msg.png (704.74 KiB) Viewed 2312 times
Main function wifi initialization is befor starting my tasks.
void app_main()
    esp_chip_info_t chip_info;
    esp_chip_info(&chip_info);
    MDF_LOGI("This is %s chip with %d CPU core(s), WiFi%s%s, ",
            CONFIG_IDF_TARGET,
            chip_info.cores,
            (chip_info.features & CHIP_FEATURE_BT) ? "/BT" : "",
            (chip_info.features & CHIP_FEATURE_BLE) ? "/BLE" : "");
    MDF_LOGI("silicon revision %d, ", chip_info.revision);
    initialisation();
    mwifi_init_config_t cfg   = MWIFI_INIT_CONFIG_DEFAULT();
    MDF_LOGI("Lantern enabled");
    mwifi_config_t config;
    MDF_LOGI("INITIALIZED CHANNEL NUMBER: %d", config.channel);
    uint8_t channel = 0;
    config.channel = channel;
    size_t required_size;
    esp_err_t err = nvs_flash_init();
    if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) {
    ESP_ERROR_CHECK( err );
    nvs_handle_t handle;
    err = nvs_open("storage", NVS_READWRITE, &handle);
    if (err != ESP_OK)
        MDF_LOGE("Error (%s) opening NVS handle! ESP will restart in 5 seconds", esp_err_to_name(err));
        vTaskDelay(pdMS_TO_TICKS(5000));
        esp_restart();
    else
        MDF_LOGI("NVS initialised");
        err = nvs_get_u8(handle, "edge_configured", &edge_configured);
        switch (err)
            case ESP_OK:
                MDF_LOGI("edge_configured = %d", edge_configured);
            case ESP_ERR_NVS_NOT_FOUND:
                MDF_LOGW("edge_configured is not initialized yet!");
            default :
                MDF_LOGE("Error (%s) reading edge_configured!", esp_err_to_name(err));
        if ( edge_configured )
            nvs_get_str(handle, "edge_ip", NULL, &required_size);
            edge_ip = (char*) malloc(required_size);
            err = nvs_get_str(handle, "edge_ip", edge_ip, &required_size);
            switch (err)
                case ESP_OK:
                    MDF_LOGI("edge_ip = %s", edge_ip);
                    MDF_LOGW("edge_ip is not initialized yet!");
                default :
                    MDF_LOGE("Error (%s) reading edge_ip!", esp_err_to_name(err));
            err = nvs_get_u16(handle, "edge_port", &edge_port);
            switch (err)
                case ESP_OK:
                    MDF_LOGI("edge_port = %d", edge_port);
                    MDF_LOGW("edge_port is not initialized yet!");
                default :
                    MDF_LOGE("Error (%s) reading edge_port!", esp_err_to_name(err));
            nvs_get_str(handle, "conf_wifi", NULL, &required_size);
            configured_wifi = (char*) malloc(required_size);
            err = nvs_get_str(handle, "conf_wifi", configured_wifi, &required_size);
            switch (err)
                case ESP_OK:
                    MDF_LOGI("conf_wifi = %s", configured_wifi);
                    MDF_LOGW("conf_wifi is not initialized yet!");
                default :
                    MDF_LOGE("Error (%s) reading conf_wifi!", esp_err_to_name(err));
            nvs_get_str(handle, "conf_wifi_pass", NULL, &required_size);
            configured_wifi_password = (char*) malloc(required_size);
            err = nvs_get_str(handle, "conf_wifi_pass", configured_wifi_password, &required_size);
            switch (err)
                case ESP_OK:
                    MDF_LOGI("conf_wifi_pass = %s", configured_wifi_password);
                    MDF_LOGW("conf_wifi_pass is not initialized yet!");
                default :
                    MDF_LOGE("Error (%s) reading conf_wifi_pass!", esp_err_to_name(err));
            nvs_get_str(handle, "conf_mesh_id", NULL, &required_size);
            configured_mesh_id = (char*) malloc(required_size);
            err = nvs_get_str(handle, "conf_mesh_id", configured_mesh_id, &required_size);
            switch (err)
                case ESP_OK:
                    MDF_LOGI("conf_mesh_id = %s", configured_mesh_id);
                    MDF_LOGW("conf_mesh_id is not initialized yet!");
                default :
                    MDF_LOGE("Error (%s) reading conf_mesh_id!", esp_err_to_name(err));
            strcpy(config.router_ssid, configured_wifi);
            strcpy(config.router_password, configured_wifi_password);
            memcpy(config.mesh_id, configured_mesh_id, sizeof(config.mesh_id));
            strcpy(config.mesh_password, CONFIG_MESH_PASSWORD);
            MDF_LOGI("CHANNEL NUMBER: %d", config.channel);
            nvs_close(handle);
        else
            //set default values
            MDF_LOGI("Setting default values");
            strcpy(config.router_ssid, CONFIG_ROUTER_SSID);
            strcpy(config.router_password, CONFIG_ROUTER_PASSWORD);
            memcpy(config.mesh_id, CONFIG_MESH_ID, sizeof(config.mesh_id));
    esp_log_level_set("*", ESP_LOG_INFO);
    esp_log_level_set(TAG, ESP_LOG_DEBUG);
    MDF_ERROR_ASSERT(mdf_event_loop_init(event_loop_cb));
    MDF_ERROR_ASSERT(wifi_init());		///////////PROGRAM FAILES SOMEWHERE HERE
    MDF_ERROR_ASSERT(mwifi_init(&cfg));
    MDF_ERROR_ASSERT(mwifi_set_config(&config));
    MDF_ERROR_ASSERT(mwifi_start());
    initialize_sntp();
    uint8_t sta_mac[MWIFI_ADDR_LEN] = {0};
    esp_wifi_get_mac(WIFI_IF_STA, sta_mac);
    asprintf(&mac_address, MACSTR, MAC2STR(sta_mac));
    if( get_time_ms() > 10000000000)
        sales_measurment = 1;
    MDF_LOGW("Starting Tasks");
    TaskHandle_t xHandle_VL53L0X = NULL;
    TaskHandle_t xHandle_communication = NULL;
    //xTaskCreate(VL53L0X_task, "VL53L0X_task", 4 * 1024, NULL, 4, NULL);
    //xTaskCreate(communication_task, "communication_task", 2 * 1024, NULL, 6, &xHandle_communication);
                communication_task,
                4 * 1024,
                ( void * ) 1,
                6,
                xStack,
                &xTaskBuffer );*/
    xTaskCreate(input_voltage_adc_task, "input_voltage_adc_task", 4 * 1024, NULL, 2, NULL);
    //xTaskCreate(RTC_task, "RTC_task", 4 * 1024, NULL, 1, NULL);
    //MDF_ERROR_ASSERT( esp_task_wdt_add(xHandle_communication) );
    TimerHandle_t system_info_timer = xTimerCreate("print_system_info", 5000 / portTICK_RATE_MS,
                                        true, NULL, print_system_info_timercb);
    xTimerStart(system_info_timer, 0);
        TimerHandle_t additional_info_timer = xTimerCreate("print_additional_info", 15000 / portTICK_RATE_MS,
                                        true, NULL, print_additional_info_timercb);
        xTimerStart(additional_info_timer, 0);
2. I guess I tried to increase the stack before. Tomorrow I will have access to the device and will try again.
main.cpp
(8.28 KiB) Downloaded 321 times
Users browsing this forum: Google [Bot], YisouSpider and 4 guests
