Hello, I just installed Arduino IDE for Windows 7 and newer (using windows 10). I installed support for the ESP32, selected DOIT ESP32 DEVKIT V1 and selected the ESP32 BLE Arduino EXAMPLE: BLE_write. It compiled the first time but when I went to upload I got an error:
Error compiling for board DOIT ESP32 DEVKIT V1
Can you help me figure out what is going wrong?
Thank you
Arduino IDE new install Compile Error with unaltered example
- Untitled4.png (120.31 KiB) Viewed 3539 times
lbernstone
Re: Arduino IDE new install Compile Error with unaltered example
See where it says "Copy error messages"? Hit that button and paste it into Notepad. I'll bet it has a lot more information about why it failed. You can also scroll down there, or expand the lower section with the errors.
When I push, Copy error messages, I get:
Arduino: 1.8.19 (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\e729128\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\e729128\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\e729128\OneDrive - Honeywell\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\e729128\AppData\Local\Temp\arduino_build_744136 -warnings=none -build-cache C:\Users\e729128\AppData\Local\Temp\arduino_cache_950042 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -verbose C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\BLE_write.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\e729128\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\e729128\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\e729128\OneDrive - Honeywell\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\e729128\AppData\Local\Temp\arduino_build_744136 -warnings=none -build-cache C:\Users\e729128\AppData\Local\Temp\arduino_cache_950042 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -verbose C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\BLE_write.ino
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3
Using core 'esp32' from platform in folder: C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3
cmd /c if exist "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\libraries\\BLE\\examples\\BLE_write\\partitions.csv" COPY /y "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\libraries\\BLE\\examples\\BLE_write\\partitions.csv" "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\partitions.csv"
cmd /c if not exist "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\partitions.csv" if exist "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\doitESP32devkitV1\\partitions.csv" COPY "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\doitESP32devkitV1\\partitions.csv" "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\partitions.csv"
cmd /c if not exist "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\partitions.csv" COPY "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\tools\\partitions\\default.csv" "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\libraries\\BLE\\examples\\BLE_write\\bootloader.bin" ( COPY /y "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\libraries\\BLE\\examples\\BLE_write\\bootloader.bin" "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\BLE_write.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\doitESP32devkitV1\\bootloader.bin" ( COPY "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\variants\\doitESP32devkitV1\\bootloader.bin" "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\BLE_write.ino.bootloader.bin" ) ELSE ( COPY /y "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\tools\\sdk\\esp32\\bin\\bootloader_dio_80m.bin" "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\BLE_write.ino.bootloader.bin" ) )
1 file(s) copied.
cmd /c if exist "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\libraries\\BLE\\examples\\BLE_write\\build_opt.h" COPY /y "C:\\Users\\e729128\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.3\\libraries\\BLE\\examples\\BLE_write\\build_opt.h" "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\build_opt.h"
cmd /c if not exist "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\build_opt.h" type nul > "C:\\Users\\e729128\\AppData\\Local\\Temp\\arduino_build_744136\\build_opt.h"
Detecting libraries used...
Error compiling for board DOIT ESP32 DEVKIT V1.
1 file(s) copied.
what thoughts or suggestions do you have?
lbernstone
Put your sketch folder somewhere other than OneDrive. There are limits on the filepath lengths, and spaces never help in filenames.
Users browsing this forum: Applebot, Barkrowler, PerplexityBot and 4 guests
