MCPWM
chenyananee
MCPWM
Postby chenyananee » Wed Jun 08, 2022 8:33 am
关于在使用esp内部MCPWM模块时,测试发现设置频率位1000,然后读出频率也为1000,但是示波器测出来只有10hz
code:
static void mcu_pwm_gpio_init()
const BA_MCU_HW_CFG *hw = baMcuGetHwInfo();
mcpwm_gpio_init(MOTOR_MCPWM_UNIT, MCPWM1A, 12);
mcpwm_gpio_init(MOTOR_MCPWM_UNIT, MCPWM1B, 13);
// mcpwm_gpio_init(MOTOR_MCPWM_UNIT, MCPWM_CAP_0, hw->motor_cap);
// gpio_pulldown_en(hw->motor_cap); //Enable pull down on CAP0 signal
void mcu_pwm_init()
mcu_pwm_gpio_init();
mcpwm_config_t pwm_config={};
pwm_config.frequency = 1000; //frequency = 15000Hz
pwm_config.cmpr_a = 60.0; //duty cycle of PWMxA = 60.0%
pwm_config.cmpr_b = 30.0;
pwm_config.counter_mode = MCPWM_UP_COUNTER;
pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
mcpwm_init(MOTOR_MCPWM_UNIT, MOTOR_PWM_TIMER, &pwm_config); //Configure PWM0A with above settings
mcpwm_set_frequency(MOTOR_MCPWM_UNIT,MOTOR_PWM_TIMER,1000);
ESP_LOGI("ddddddddddd", "Using rev \"%u\"", mcpwm_get_frequency(MOTOR_MCPWM_UNIT,MOTOR_PWM_TIMER));
// mcpwm_capture_enable(MOTOR_MCPWM_UNIT, MCPWM_SELECT_CAP0, MCPWM_POS_EDGE, 0); //capture signal on rising edge, prescale = 0 i.e. 800,000,000 counts is equal to one second
// //enable interrupt, so each this a rising edge occurs interrupt is triggered
// MCPWM[MOTOR_MCPWM_UNIT]->int_ena.val = CAP0_INT_EN; //Enable interrupt on CAP0, CAP1 and CAP2 signal
// mcpwm_isr_register(MOTOR_MCPWM_UNIT, isr_handler, NULL, ESP_INTR_FLAG_IRAM, NULL); //Set ISR Handler
morris
Re: MCPWM
Postby morris » Wed Jun 08, 2022 8:55 am
I can get the 1KHz waveforms without issue with the following code snippet
 * SPDX-FileCopyrightText: 2010-2022 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: CC0-1.0
#include <stdio.h>
#include "sdkconfig.h"
#include "freertos/task.h"
#include "driver/mcpwm.h"
void app_main(void)
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, 0);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0B, 2);
    mcpwm_config_t pwm_config = {
        .frequency = 1000,
        .cmpr_a = 60,
        .cmpr_b = 30,
        .counter_mode = MCPWM_UP_COUNTER,
        .duty_mode = MCPWM_DUTY_MODE_0,
    mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config);
chenyananee
Re: MCPWM
Postby chenyananee » Wed Jun 08, 2022 9:08 am
thanks,but for the same code,the issue is not fixed yet.
is there any configuration for the time with 'sdkconfig'?
morris
Re: MCPWM
Postby morris » Thu Jun 09, 2022 2:39 am
BTW, I only tested the code on the master branch. The code doesn't need to alter any default configuration from menuconfig.
chenyananee
Re: MCPWM
Postby chenyananee » Thu Jun 16, 2022 2:24 am
the pwm module can't work correctly with our project, but this demo can be run with default sdkconfig.
so, i think is there anything wrong with our configuration.
chenyananee
Re: MCPWM
Postby chenyananee » Thu Jun 16, 2022 2:30 am
this is our project's sdkconfig file, and i don't know what the config can cause this issue.
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) Project Configuration
CONFIG_IDF_TARGET_ESP32=y
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0000
# SDK tool configuration
CONFIG_SDK_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_SDK_PYTHON="python"
# CONFIG_SDK_MAKE_WARN_UNDEFINED_VARIABLES is not set
CONFIG_APP_COMPILE_TIME_DATE=y
# CONFIG_APP_EXCLUDE_PROJECT_VER_VAR is not set
# CONFIG_APP_EXCLUDE_PROJECT_NAME_VAR is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_NONE is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_ERROR is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_WARN is not set
CONFIG_BOOTLOADER_LOG_LEVEL_INFO=y
# CONFIG_BOOTLOADER_LOG_LEVEL_DEBUG is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_VERBOSE is not set
CONFIG_BOOTLOADER_LOG_LEVEL=3
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
# CONFIG_BOOTLOADER_FACTORY_RESET is not set
# CONFIG_BOOTLOADER_APP_TEST is not set
CONFIG_BOOTLOADER_WDT_ENABLE=y
# CONFIG_BOOTLOADER_WDT_DISABLE_IN_USER_CODE is not set
CONFIG_BOOTLOADER_WDT_TIME_MS=9000
CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE=y
# CONFIG_BOOTLOADER_APP_ANTI_ROLLBACK is not set
CONFIG_SECURE_SIGNED_ON_UPDATE=y
CONFIG_SECURE_SIGNED_APPS=y
CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT=y
# CONFIG_SECURE_SIGNED_ON_BOOT_NO_SECURE_BOOT is not set
CONFIG_SECURE_SIGNED_ON_UPDATE_NO_SECURE_BOOT=y
# CONFIG_SECURE_BOOT_ENABLED is not set
CONFIG_SECURE_BOOT_BUILD_SIGNED_BINARIES=y
CONFIG_SECURE_BOOT_SIGNING_KEY="ba_firmware_sign.pem"
CONFIG_SECURE_FLASH_ENC_ENABLED=y
# CONFIG_SECURE_FLASH_ENCRYPTION_MODE_DEVELOPMENT is not set
CONFIG_SECURE_FLASH_ENCRYPTION_MODE_RELEASE=y
CONFIG_ESPTOOLPY_PORT="/dev/ttyUSB1"
# CONFIG_ESPTOOLPY_BAUD_115200B is not set
# CONFIG_ESPTOOLPY_BAUD_230400B is not set
# CONFIG_ESPTOOLPY_BAUD_921600B is not set
CONFIG_ESPTOOLPY_BAUD_2MB=y
# CONFIG_ESPTOOLPY_BAUD_OTHER is not set
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_BAUD=2000000
CONFIG_ESPTOOLPY_COMPRESSED=y
# CONFIG_ESPTOOLPY_FLASHMODE_QIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE="dio"
CONFIG_ESPTOOLPY_FLASHFREQ_80M=y
# CONFIG_ESPTOOLPY_FLASHFREQ_40M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_26M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_20M is not set
CONFIG_ESPTOOLPY_FLASHFREQ="80m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_2MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_4MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_8MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="8MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
# CONFIG_ESPTOOLPY_MONITOR_BAUD_9600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_57600B is not set
CONFIG_ESPTOOLPY_MONITOR_BAUD_115200B=y
# CONFIG_ESPTOOLPY_MONITOR_BAUD_230400B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_921600B is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_2MB is not set
# CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER is not set
CONFIG_ESPTOOLPY_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
# CONFIG_PARTITION_TABLE_SINGLE_APP is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x9000
CONFIG_PARTITION_TABLE_MD5=y
CONFIG_COMPILER_OPTIMIZATION_LEVEL_DEBUG=y
# CONFIG_COMPILER_OPTIMIZATION_LEVEL_RELEASE is not set
CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE=y
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_DISABLE is not set
# CONFIG_COMPILER_CXX_EXCEPTIONS is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_NONE is not set
CONFIG_COMPILER_STACK_CHECK_MODE_NORM=y
# CONFIG_COMPILER_STACK_CHECK_MODE_STRONG is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_ALL is not set
CONFIG_COMPILER_STACK_CHECK=y
CONFIG_COMPILER_WARN_WRITE_STRINGS=y
# CONFIG_COMPILER_DISABLE_GCC8_WARNINGS is not set
# CONFIG_ESP32_APPTRACE_DEST_TRAX is not set
CONFIG_ESP32_APPTRACE_DEST_NONE=y
# CONFIG_ESP32_APPTRACE_ENABLE is not set
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
CONFIG_BT_ENABLED=y
CONFIG_BTDM_CTRL_MODE_BLE_ONLY=y
# CONFIG_BTDM_CTRL_MODE_BR_EDR_ONLY is not set
# CONFIG_BTDM_CTRL_MODE_BTDM is not set
CONFIG_BTDM_CTRL_BLE_MAX_CONN=3
CONFIG_BTDM_CTRL_BR_EDR_SCO_DATA_PATH_EFF=0
CONFIG_BTDM_CTRL_BLE_MAX_CONN_EFF=3
CONFIG_BTDM_CTRL_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CTRL_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CTRL_PINNED_TO_CORE_0=y
# CONFIG_BTDM_CTRL_PINNED_TO_CORE_1 is not set
CONFIG_BTDM_CTRL_PINNED_TO_CORE=0
CONFIG_BTDM_CTRL_HCI_MODE_VHCI=y
# CONFIG_BTDM_CTRL_HCI_MODE_UART_H4 is not set
CONFIG_BTDM_MODEM_SLEEP=y
CONFIG_BTDM_MODEM_SLEEP_MODE_ORIG=y
# CONFIG_BTDM_MODEM_SLEEP_MODE_EVED is not set
CONFIG_BTDM_LPCLK_SEL_MAIN_XTAL=y
CONFIG_BTDM_BLE_DEFAULT_SCA_250PPM=y
CONFIG_BTDM_BLE_SLEEP_CLOCK_ACCURACY_INDEX_EFF=1
CONFIG_BTDM_BLE_SCAN_DUPL=y
CONFIG_BTDM_SCAN_DUPL_TYPE_DEVICE=y
# CONFIG_BTDM_SCAN_DUPL_TYPE_DATA is not set
# CONFIG_BTDM_SCAN_DUPL_TYPE_DATA_DEVICE is not set
CONFIG_BTDM_SCAN_DUPL_TYPE=0
CONFIG_BTDM_SCAN_DUPL_CACHE_SIZE=200
# CONFIG_BTDM_BLE_MESH_SCAN_DUPL_EN is not set
# CONFIG_BTDM_CTRL_FULL_SCAN_SUPPORTED is not set
CONFIG_BTDM_BLE_ADV_REPORT_FLOW_CTRL_SUPP=y
CONFIG_BTDM_BLE_ADV_REPORT_FLOW_CTRL_NUM=100
CONFIG_BTDM_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
# CONFIG_BTDM_COEX_BT_OPTIONS is not set
# CONFIG_BT_BLUEDROID_ENABLED is not set
CONFIG_BT_NIMBLE_ENABLED=y
# CONFIG_BT_CONTROLLER_ONLY is not set
CONFIG_BT_RESERVE_DRAM=0xdb5c
CONFIG_BT_NIMBLE_MAX_CONNECTIONS=3
CONFIG_BT_NIMBLE_MAX_BONDS=3
CONFIG_BT_NIMBLE_MAX_CCCDS=8
CONFIG_BT_NIMBLE_L2CAP_COC_MAX_NUM=0
CONFIG_BT_NIMBLE_PINNED_TO_CORE_0=y
# CONFIG_BT_NIMBLE_PINNED_TO_CORE_1 is not set
CONFIG_BT_NIMBLE_PINNED_TO_CORE=0
CONFIG_BT_NIMBLE_TASK_STACK_SIZE=6144
CONFIG_BT_NIMBLE_ROLE_CENTRAL=y
CONFIG_BT_NIMBLE_ROLE_PERIPHERAL=y
CONFIG_BT_NIMBLE_ROLE_BROADCASTER=y
CONFIG_BT_NIMBLE_ROLE_OBSERVER=y
CONFIG_BT_NIMBLE_NVS_PERSIST=y
CONFIG_BT_NIMBLE_SM_LEGACY=y
CONFIG_BT_NIMBLE_SM_SC=y
# CONFIG_BT_NIMBLE_DEBUG is not set
# CONFIG_BT_NIMBLE_SM_SC_DEBUG_KEYS is not set
CONFIG_BT_NIMBLE_SVC_GAP_DEVICE_NAME="nimble"
CONFIG_BT_NIMBLE_GAP_DEVICE_NAME_MAX_LEN=31
CONFIG_BT_NIMBLE_ATT_PREFERRED_MTU=256
CONFIG_BT_NIMBLE_SVC_GAP_APPEARANCE=0
CONFIG_BT_NIMBLE_ACL_BUF_COUNT=12
CONFIG_BT_NIMBLE_ACL_BUF_SIZE=255
CONFIG_BT_NIMBLE_HCI_EVT_BUF_SIZE=70
CONFIG_BT_NIMBLE_HCI_EVT_HI_BUF_COUNT=30
CONFIG_BT_NIMBLE_HCI_EVT_LO_BUF_COUNT=8
# CONFIG_BT_NIMBLE_MESH is not set
CONFIG_BT_NIMBLE_CRYPTO_STACK_MBEDTLS=y
# CONFIG_BLE_MESH is not set
CONFIG_ADC_FORCE_XPD_FSM=y
CONFIG_ADC_DISABLE_DAC=y
# CONFIG_SPI_MASTER_IN_IRAM is not set
# CONFIG_SPI_MASTER_ISR_IN_IRAM is not set
# CONFIG_SPI_SLAVE_IN_IRAM is not set
# CONFIG_SPI_SLAVE_ISR_IN_IRAM is not set
# CONFIG_EFUSE_CUSTOM_TABLE is not set
# CONFIG_EFUSE_VIRTUAL is not set
CONFIG_EFUSE_CODE_SCHEME_COMPAT_NONE=y
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_3_4 is not set
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_REPEAT is not set
CONFIG_EFUSE_MAX_BLK_LEN=256
CONFIG_AWS_IOT_MQTT_HOST=""
CONFIG_AWS_IOT_MQTT_PORT=8883
CONFIG_AWS_IOT_MQTT_TX_BUF_LEN=10240
CONFIG_AWS_IOT_MQTT_RX_BUF_LEN=10240
CONFIG_AWS_IOT_MQTT_NUM_SUBSCRIBE_HANDLERS=20
CONFIG_AWS_IOT_MQTT_MIN_RECONNECT_WAIT_INTERVAL=5000
CONFIG_AWS_IOT_MQTT_MAX_RECONNECT_WAIT_INTERVAL=128000
CONFIG_AWS_IOT_OVERRIDE_THING_SHADOW_RX_BUFFER=y
CONFIG_AWS_IOT_SHADOW_MAX_SIZE_OF_RX_BUFFER=5120
CONFIG_AWS_IOT_SHADOW_MAX_SIZE_OF_UNIQUE_CLIENT_ID_BYTES=80
CONFIG_AWS_IOT_SHADOW_MAX_SIMULTANEOUS_ACKS=10
CONFIG_AWS_IOT_SHADOW_MAX_SIMULTANEOUS_THINGNAMES=10
CONFIG_AWS_IOT_SHADOW_MAX_JSON_TOKEN_EXPECTED=200
CONFIG_AWS_IOT_SHADOW_MAX_SHADOW_TOPIC_LENGTH_WITHOUT_THINGNAME=60
CONFIG_AWS_IOT_SHADOW_MAX_SIZE_OF_THING_NAME=60
CONFIG_ESP_TLS_SERVER=y
# CONFIG_ESP32_REV_MIN_0 is not set
CONFIG_ESP32_REV_MIN_1=y
# CONFIG_ESP32_REV_MIN_2 is not set
# CONFIG_ESP32_REV_MIN_3 is not set
CONFIG_ESP32_REV_MIN=1
CONFIG_ESP32_DPORT_WORKAROUND=y
# CONFIG_ESP32_DEFAULT_CPU_FREQ_80 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_160=y
# CONFIG_ESP32_DEFAULT_CPU_FREQ_240 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=160
CONFIG_ESP32_SPIRAM_SUPPORT=y
CONFIG_SPIRAM_BOOT_INIT=y
# CONFIG_SPIRAM_USE_MEMMAP is not set
# CONFIG_SPIRAM_USE_CAPS_ALLOC is not set
CONFIG_SPIRAM_USE_MALLOC=y
CONFIG_SPIRAM_TYPE_AUTO=y
# CONFIG_SPIRAM_TYPE_ESPPSRAM32 is not set
# CONFIG_SPIRAM_TYPE_ESPPSRAM64 is not set
CONFIG_SPIRAM_SIZE=-1
# CONFIG_SPIRAM_SPEED_40M is not set
CONFIG_SPIRAM_SPEED_80M=y
CONFIG_SPIRAM_MEMTEST=y
CONFIG_SPIRAM_CACHE_WORKAROUND=y
# CONFIG_SPIRAM_BANKSWITCH_ENABLE is not set
CONFIG_SPIRAM_MALLOC_ALWAYSINTERNAL=512
CONFIG_SPIRAM_TRY_ALLOCATE_WIFI_LWIP=y
CONFIG_SPIRAM_MALLOC_RESERVE_INTERNAL=32768
CONFIG_SPIRAM_ALLOW_STACK_EXTERNAL_MEMORY=y
CONFIG_SPIRAM_ALLOW_BSS_SEG_EXTERNAL_MEMORY=y
CONFIG_SPIRAM_OCCUPY_HSPI_HOST=y
# CONFIG_SPIRAM_OCCUPY_VSPI_HOST is not set
# CONFIG_SPIRAM_OCCUPY_NO_HOST is not set
CONFIG_D0WD_PSRAM_CLK_IO=17
CONFIG_D0WD_PSRAM_CS_IO=16
CONFIG_D2WD_PSRAM_CLK_IO=9
CONFIG_D2WD_PSRAM_CS_IO=10
CONFIG_PICO_PSRAM_CS_IO=10
CONFIG_SPIRAM_SPIWP_SD3_PIN=7
# CONFIG_ESP32_MEMMAP_TRACEMEM is not set
# CONFIG_ESP32_MEMMAP_TRACEMEM_TWOBANKS is not set
# CONFIG_ESP32_TRAX is not set
CONFIG_ESP32_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_TWO is not set
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_FOUR=y
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES=4
# CONFIG_ESP32_ULP_COPROC_ENABLED is not set
CONFIG_ESP32_ULP_COPROC_RESERVE_MEM=0
# CONFIG_ESP32_PANIC_PRINT_HALT is not set
CONFIG_ESP32_PANIC_PRINT_REBOOT=y
# CONFIG_ESP32_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP32_PANIC_GDBSTUB is not set
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_ESP32_DEBUG_STUBS_ENABLE=y
CONFIG_ESP32_BROWNOUT_DET=y
CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_ESP32_BROWNOUT_DET_LVL=0
CONFIG_ESP32_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
# CONFIG_ESP32_TIME_SYSCALL_USE_RTC is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_FRC1 is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_NONE is not set
CONFIG_ESP32_RTC_CLK_SRC_INT_RC=y
# CONFIG_ESP32_RTC_CLK_SRC_EXT_CRYS is not set
# CONFIG_ESP32_RTC_CLK_SRC_EXT_OSC is not set
# CONFIG_ESP32_RTC_CLK_SRC_INT_8MD256 is not set
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=2000
CONFIG_ESP32_XTAL_FREQ_40=y
# CONFIG_ESP32_XTAL_FREQ_26 is not set
# CONFIG_ESP32_XTAL_FREQ_AUTO is not set
CONFIG_ESP32_XTAL_FREQ=40
# CONFIG_ESP32_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_ESP32_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
# CONFIG_ESP32_USE_FIXED_STATIC_RAM_SIZE is not set
CONFIG_ESP32_DPORT_DIS_INTERRUPT_LVL=5
CONFIG_PM_ENABLE=y
CONFIG_PM_DFS_INIT_AUTO=y
CONFIG_PM_USE_RTC_TIMER_REF=y
# CONFIG_PM_PROFILING is not set
# CONFIG_PM_TRACE is not set
CONFIG_ADC_CAL_EFUSE_TP_ENABLE=y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CAL_LUT_ENABLE=y
# CONFIG_ESP_TIMER_PROFILING is not set
CONFIG_ESP_ERR_TO_NAME_LOOKUP=y
CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE=64
CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE=4096
CONFIG_ESP_MAIN_TASK_STACK_SIZE=4096
CONFIG_ESP_IPC_TASK_STACK_SIZE=2048
CONFIG_ESP_TIMER_TASK_STACK_SIZE=3584
CONFIG_ESP_CONSOLE_UART_DEFAULT=y
# CONFIG_ESP_CONSOLE_UART_CUSTOM is not set
# CONFIG_ESP_CONSOLE_UART_NONE is not set
CONFIG_ESP_CONSOLE_UART_NUM=0
CONFIG_ESP_CONSOLE_UART_BAUDRATE=115200
CONFIG_ESP_INT_WDT=y
CONFIG_ESP_INT_WDT_TIMEOUT_MS=3000
CONFIG_ESP_INT_WDT_CHECK_CPU1=y
CONFIG_ESP_TASK_WDT=y
CONFIG_ESP_TASK_WDT_PANIC=y
CONFIG_ESP_TASK_WDT_TIMEOUT_S=30
CONFIG_ESP_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_ESP_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
# CONFIG_ETH_USE_ESP32_EMAC is not set
# CONFIG_ETH_USE_SPI_ETHERNET is not set
# CONFIG_ESP_EVENT_LOOP_PROFILING is not set
CONFIG_ESP_EVENT_POST_FROM_ISR=y
CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR=y
CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS=y
CONFIG_ESP_HTTP_CLIENT_ENABLE_BASIC_AUTH=y
CONFIG_HTTPD_MAX_REQ_HDR_LEN=5120
CONFIG_HTTPD_MAX_URI_LEN=512
CONFIG_HTTPD_ERR_RESP_NO_DELAY=y
CONFIG_HTTPD_PURGE_BUF_LEN=32
CONFIG_HTTPD_LOG_PURGE_DATA=y
# CONFIG_OTA_ALLOW_HTTP is not set
CONFIG_ESP_HTTPS_SERVER_ENABLE=y
CONFIG_ESP32_WIFI_SW_COEXIST_ENABLE=y
# CONFIG_ESP32_WIFI_SW_COEXIST_PREFERENCE_WIFI is not set
# CONFIG_ESP32_WIFI_SW_COEXIST_PREFERENCE_BT is not set
CONFIG_ESP32_WIFI_SW_COEXIST_PREFERENCE_BALANCE=y
CONFIG_ESP32_WIFI_SW_COEXIST_PREFERENCE_VALUE=2
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=128
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=0
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER_NUM=6
# CONFIG_ESP32_WIFI_CSI_ENABLED is not set
# CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED is not set
# CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED is not set
CONFIG_ESP32_WIFI_NVS_ENABLED=y
# CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0 is not set
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_1=y
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
# CONFIG_ESP32_WIFI_DEBUG_LOG_ENABLE is not set
# CONFIG_ESP32_WIFI_IRAM_OPT is not set
# CONFIG_ESP32_WIFI_RX_IRAM_OPT is not set
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_UART is not set
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
# CONFIG_ESP32_ENABLE_COREDUMP is not set
# CONFIG_FATFS_CODEPAGE_DYNAMIC is not set
CONFIG_FATFS_CODEPAGE_437=y
# CONFIG_FATFS_CODEPAGE_720 is not set
# CONFIG_FATFS_CODEPAGE_737 is not set
# CONFIG_FATFS_CODEPAGE_771 is not set
# CONFIG_FATFS_CODEPAGE_775 is not set
# CONFIG_FATFS_CODEPAGE_850 is not set
# CONFIG_FATFS_CODEPAGE_852 is not set
# CONFIG_FATFS_CODEPAGE_855 is not set
# CONFIG_FATFS_CODEPAGE_857 is not set
# CONFIG_FATFS_CODEPAGE_860 is not set
# CONFIG_FATFS_CODEPAGE_861 is not set
# CONFIG_FATFS_CODEPAGE_862 is not set
# CONFIG_FATFS_CODEPAGE_863 is not set
# CONFIG_FATFS_CODEPAGE_864 is not set
# CONFIG_FATFS_CODEPAGE_865 is not set
# CONFIG_FATFS_CODEPAGE_866 is not set
# CONFIG_FATFS_CODEPAGE_869 is not set
# CONFIG_FATFS_CODEPAGE_932 is not set
# CONFIG_FATFS_CODEPAGE_936 is not set
# CONFIG_FATFS_CODEPAGE_949 is not set
# CONFIG_FATFS_CODEPAGE_950 is not set
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_LFN_NONE=y
# CONFIG_FATFS_LFN_HEAP is not set
# CONFIG_FATFS_LFN_STACK is not set
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
CONFIG_FATFS_ALLOC_PREFER_EXTRAM=y
# CONFIG_FREERTOS_UNICORE is not set
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_CORETIMER_0=y
# CONFIG_FREERTOS_CORETIMER_1 is not set
CONFIG_FREERTOS_HZ=200
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=y
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE is not set
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL is not set
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
# CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK is not set
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
# CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE is not set
# CONFIG_FREERTOS_ASSERT_DISABLE is not set
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1536
CONFIG_FREERTOS_ISR_STACKSIZE=1536
# CONFIG_FREERTOS_LEGACY_HOOKS is not set
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION=y
# CONFIG_FREERTOS_ENABLE_STATIC_TASK_CLEAN_UP is not set
CONFIG_FREERTOS_TIMER_TASK_PRIORITY=1
CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH=2560
CONFIG_FREERTOS_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
CONFIG_FREERTOS_USE_TRACE_FACILITY=y
CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS=y
# CONFIG_FREERTOS_VTASKLIST_INCLUDE_COREID is not set
# CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS is not set
# CONFIG_FREERTOS_USE_TICKLESS_IDLE is not set
# CONFIG_FREERTOS_DEBUG_INTERNALS is not set
CONFIG_FREERTOS_TASK_FUNCTION_WRAPPER=y
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
# CONFIG_FREERTOS_CHECK_PORT_CRITICAL_COMPLIANCE is not set
# CONFIG_HEAP_POISONING_DISABLED is not set
# CONFIG_HEAP_POISONING_LIGHT is not set
CONFIG_HEAP_POISONING_COMPREHENSIVE=y
CONFIG_HEAP_TRACING_OFF=y
# CONFIG_HEAP_TRACING_STANDALONE is not set
# CONFIG_HEAP_TRACING_TOHOST is not set
# CONFIG_HEAP_TRACING is not set
# CONFIG_HEAP_TASK_TRACKING is not set
CONFIG_LIBSODIUM_USE_MBEDTLS_SHA=y
# CONFIG_LOG_DEFAULT_LEVEL_NONE is not set
# CONFIG_LOG_DEFAULT_LEVEL_ERROR is not set
# CONFIG_LOG_DEFAULT_LEVEL_WARN is not set
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
# CONFIG_LOG_DEFAULT_LEVEL_DEBUG is not set
# CONFIG_LOG_DEFAULT_LEVEL_VERBOSE is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_COLORS=y
CONFIG_LWIP_LOCAL_HOSTNAME="espressif"
CONFIG_LWIP_L2_TO_L3_COPY=y
# CONFIG_LWIP_IRAM_OPTIMIZATION is not set
CONFIG_LWIP_TIMERS_ONDEMAND=y
CONFIG_LWIP_MAX_SOCKETS=16
CONFIG_LWIP_USE_ONLY_LWIP_SELECT=y
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
CONFIG_LWIP_SO_RCVBUF=y
CONFIG_LWIP_IP_FRAG=y
CONFIG_LWIP_IP_REASSEMBLY=y
CONFIG_LWIP_STATS=y
# CONFIG_LWIP_ETHARP_TRUST_IP_MAC is not set
CONFIG_LWIP_ESP_GRATUITOUS_ARP=y
CONFIG_LWIP_GARP_TMR_INTERVAL=60
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=y
CONFIG_LWIP_DHCP_RESTORE_LAST_IP=y
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
# CONFIG_LWIP_AUTOIP is not set
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=16
CONFIG_LWIP_MAX_ACTIVE_TCP=32
CONFIG_LWIP_MAX_LISTENING_TCP=32
CONFIG_LWIP_TCP_MAXRTX=12
CONFIG_LWIP_TCP_SYNMAXRTX=12
CONFIG_LWIP_TCP_MSS=1436
CONFIG_LWIP_TCP_MSL=60000
CONFIG_LWIP_TCP_SND_BUF_DEFAULT=5744
CONFIG_LWIP_TCP_WND_DEFAULT=5744
CONFIG_LWIP_TCP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCP_QUEUE_OOSEQ=y
# CONFIG_LWIP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_LWIP_TCP_OVERSIZE_MSS=y
# CONFIG_LWIP_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_LWIP_TCP_OVERSIZE_DISABLE is not set
# CONFIG_LWIP_WND_SCALE is not set
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_LWIP_UDP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCPIP_TASK_STACK_SIZE=3072
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY is not set
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU0 is not set
CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU1=y
CONFIG_LWIP_TCPIP_TASK_AFFINITY=0x1
# CONFIG_LWIP_PPP_SUPPORT is not set
# CONFIG_LWIP_MULTICAST_PING is not set
# CONFIG_LWIP_BROADCAST_PING is not set
CONFIG_LWIP_MAX_RAW_PCBS=16
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
# CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC is not set
CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC=y
# CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set
# CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
# CONFIG_MBEDTLS_DEBUG is not set
CONFIG_MBEDTLS_ECP_RESTARTABLE=y
CONFIG_MBEDTLS_CMAC_C=y
# CONFIG_MBEDTLS_HARDWARE_AES is not set
# CONFIG_MBEDTLS_HARDWARE_MPI is not set
# CONFIG_MBEDTLS_HARDWARE_SHA is not set
# CONFIG_MBEDTLS_HAVE_TIME is not set
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
# CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set
# CONFIG_MBEDTLS_TLS_CLIENT_ONLY is not set
# CONFIG_MBEDTLS_TLS_DISABLED is not set
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
CONFIG_MBEDTLS_PSK_MODES=y
CONFIG_MBEDTLS_KEY_EXCHANGE_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_PSK=y
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
# CONFIG_MBEDTLS_SSL_PROTO_SSL3 is not set
# CONFIG_MBEDTLS_SSL_PROTO_TLS1 is not set
# CONFIG_MBEDTLS_SSL_PROTO_TLS1_1 is not set
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_AES_C=y
CONFIG_MBEDTLS_CAMELLIA_C=y
CONFIG_MBEDTLS_DES_C=y
CONFIG_MBEDTLS_RC4_DISABLED=y
# CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT is not set
# CONFIG_MBEDTLS_RC4_ENABLED is not set
# CONFIG_MBEDTLS_BLOWFISH_C is not set
CONFIG_MBEDTLS_XTEA_C=y
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
# CONFIG_MBEDTLS_RIPEMD160_C is not set
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
CONFIG_MDNS_MAX_SERVICES=10
CONFIG_MQTT_PROTOCOL_311=y
CONFIG_MQTT_TRANSPORT_SSL=y
# CONFIG_MQTT_TRANSPORT_WEBSOCKET is not set
# CONFIG_MQTT_USE_CUSTOM_CONFIG is not set
# CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED is not set
# CONFIG_MQTT_CUSTOM_OUTBOX is not set
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF is not set
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_LF is not set
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
# CONFIG_NEWLIB_NANO_FORMAT is not set
CONFIG_NVS_ENCRYPTION=y
CONFIG_OPENSSL_DEBUG=y
CONFIG_OPENSSL_DEBUG_LEVEL=0
# CONFIG_OPENSSL_LOWLEVEL_DEBUG is not set
CONFIG_OPENSSL_ASSERT_DO_NOTHING=y
# CONFIG_OPENSSL_ASSERT_EXIT is not set
# CONFIG_OPENSSL_ASSERT_DEBUG is not set
# CONFIG_OPENSSL_ASSERT_DEBUG_EXIT is not set
# CONFIG_OPENSSL_ASSERT_DEBUG_BLOCK is not set
CONFIG_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_PTHREAD_STACK_MIN=768
# CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY is not set
# CONFIG_PTHREAD_DEFAULT_CORE_0 is not set
CONFIG_PTHREAD_DEFAULT_CORE_1=y
CONFIG_PTHREAD_TASK_CORE_DEFAULT=1
CONFIG_PTHREAD_TASK_NAME_DEFAULT="pthread"
# CONFIG_SPI_FLASH_VERIFY_WRITE is not set
# CONFIG_SPI_FLASH_ENABLE_COUNTERS is not set
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS=y
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_FAILS is not set
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_ALLOWED is not set
# CONFIG_SPI_FLASH_USE_LEGACY_IMPL is not set
CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_GD_CHIP=y
CONFIG_SPIFFS_MAX_PARTITIONS=1
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
# CONFIG_SPIFFS_CACHE_STATS is not set
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
# CONFIG_SPIFFS_GC_STATS is not set
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
# CONFIG_SPIFFS_DBG is not set
# CONFIG_SPIFFS_API_DBG is not set
# CONFIG_SPIFFS_GC_DBG is not set
# CONFIG_SPIFFS_CACHE_DBG is not set
# CONFIG_SPIFFS_CHECK_DBG is not set
# CONFIG_SPIFFS_TEST_VISUALISATION is not set
CONFIG_NETIF_IP_LOST_TIMER_INTERVAL=120
CONFIG_TCPIP_LWIP=y
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
# CONFIG_UNITY_ENABLE_COLOR is not set
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
# CONFIG_UNITY_ENABLE_FIXTURE is not set
# CONFIG_UNITY_ENABLE_BACKTRACE_ON_FAIL is not set
CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_VFS_SUPPORT_TERMIOS=y
CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS=1
CONFIG_SEMIHOSTFS_HOST_PATH_MAX_LEN=128
# CONFIG_WL_SECTOR_SIZE_512 is not set
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=8
CONFIG_WPA_MBEDTLS_CRYPTO=y
# CONFIG_LEGACY_INCLUDE_COMMON_HEADERS is not set
# Deprecated options for backward compatibility
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_PYTHON="python"
# CONFIG_MAKE_WARN_UNDEFINED_VARIABLES is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_NONE is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_ERROR is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_WARN is not set
CONFIG_LOG_BOOTLOADER_LEVEL_INFO=y
# CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE is not set
CONFIG_LOG_BOOTLOADER_LEVEL=3
CONFIG_APP_ROLLBACK_ENABLE=y
# CONFIG_APP_ANTI_ROLLBACK is not set
CONFIG_FLASH_ENCRYPTION_ENABLED=y
# CONFIG_FLASH_ENCRYPTION_INSECURE is not set
# CONFIG_FLASHMODE_QIO is not set
# CONFIG_FLASHMODE_QOUT is not set
CONFIG_FLASHMODE_DIO=y
# CONFIG_FLASHMODE_DOUT is not set
# CONFIG_MONITOR_BAUD_9600B is not set
# CONFIG_MONITOR_BAUD_57600B is not set
CONFIG_MONITOR_BAUD_115200B=y
# CONFIG_MONITOR_BAUD_230400B is not set
# CONFIG_MONITOR_BAUD_921600B is not set
# CONFIG_MONITOR_BAUD_2MB is not set
# CONFIG_MONITOR_BAUD_OTHER is not set
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
CONFIG_OPTIMIZATION_LEVEL_DEBUG=y
# CONFIG_OPTIMIZATION_LEVEL_RELEASE is not set
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
# CONFIG_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED is not set
# CONFIG_CXX_EXCEPTIONS is not set
# CONFIG_STACK_CHECK_NONE is not set
CONFIG_STACK_CHECK_NORM=y
# CONFIG_STACK_CHECK_STRONG is not set
# CONFIG_STACK_CHECK_ALL is not set
CONFIG_STACK_CHECK=y
CONFIG_WARN_WRITE_STRINGS=y
# CONFIG_DISABLE_GCC8_WARNINGS is not set
CONFIG_BTDM_CONTROLLER_MODE_BLE_ONLY=y
# CONFIG_BTDM_CONTROLLER_MODE_BR_EDR_ONLY is not set
# CONFIG_BTDM_CONTROLLER_MODE_BTDM is not set
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN=3
CONFIG_BTDM_CONTROLLER_BLE_MAX_CONN_EFF=3
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_ACL_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_BR_EDR_MAX_SYNC_CONN_EFF=0
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y
# CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4 is not set
CONFIG_BTDM_CONTROLLER_MODEM_SLEEP=y
CONFIG_BLE_SCAN_DUPLICATE=y
CONFIG_SCAN_DUPLICATE_BY_DEVICE_ADDR=y
# CONFIG_SCAN_DUPLICATE_BY_ADV_DATA is not set
# CONFIG_SCAN_DUPLICATE_BY_ADV_DATA_AND_DEVICE_ADDR is not set
CONFIG_SCAN_DUPLICATE_TYPE=0
CONFIG_DUPLICATE_SCAN_CACHE_SIZE=200
# CONFIG_BLE_MESH_SCAN_DUPLICATE_EN is not set
# CONFIG_BTDM_CONTROLLER_FULL_SCAN_SUPPORTED is not set
CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_SUPPORTED=y
CONFIG_BLE_ADV_REPORT_FLOW_CONTROL_NUM=100
CONFIG_BLE_ADV_REPORT_DISCARD_THRSHOLD=20
# CONFIG_BLUEDROID_ENABLED is not set
CONFIG_ADC2_DISABLE_DAC=y
CONFIG_SPIRAM_SUPPORT=y
CONFIG_WIFI_LWIP_ALLOCATION_FROM_SPIRAM_FIRST=y
# CONFIG_MEMMAP_TRACEMEM is not set
# CONFIG_MEMMAP_TRACEMEM_TWOBANKS is not set
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_TWO_UNIVERSAL_MAC_ADDRESS is not set
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
# CONFIG_ULP_COPROC_ENABLED is not set
CONFIG_ULP_COPROC_RESERVE_MEM=0
CONFIG_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_BROWNOUT_DET_LVL=0
CONFIG_REDUCE_PHY_TX_POWER=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_OSC is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_8MD256 is not set
# CONFIG_DISABLE_BASIC_ROM_CONSOLE is not set
# CONFIG_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=64
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=4096
CONFIG_MAIN_TASK_STACK_SIZE=4096
CONFIG_IPC_TASK_STACK_SIZE=2048
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_CONSOLE_UART_DEFAULT=y
# CONFIG_CONSOLE_UART_CUSTOM is not set
# CONFIG_CONSOLE_UART_NONE is not set
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=3000
CONFIG_INT_WDT_CHECK_CPU1=y
CONFIG_TASK_WDT=y
CONFIG_TASK_WDT_PANIC=y
CONFIG_TASK_WDT_TIMEOUT_S=30
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
# CONFIG_EVENT_LOOP_PROFILING is not set
CONFIG_POST_EVENTS_FROM_ISR=y
CONFIG_POST_EVENTS_FROM_IRAM_ISR=y
CONFIG_SW_COEXIST_ENABLE=y
# CONFIG_SW_COEXIST_PREFERENCE_WIFI is not set
# CONFIG_SW_COEXIST_PREFERENCE_BT is not set
CONFIG_SW_COEXIST_PREFERENCE_BALANCE=y
CONFIG_SW_COEXIST_PREFERENCE_VALUE=2
CONFIG_SUPPORT_STATIC_ALLOCATION=y
# CONFIG_ENABLE_STATIC_TASK_CLEAN_UP_HOOK is not set
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2560
CONFIG_TIMER_QUEUE_LENGTH=10
CONFIG_L2_TO_L3_COPY=y
CONFIG_USE_ONLY_LWIP_SELECT=y
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=12
CONFIG_TCP_MSS=1436
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
# CONFIG_ESP_TCP_KEEP_CONNECTION_WHEN_IP_CHANGES is not set
CONFIG_TCP_OVERSIZE_MSS=y
# CONFIG_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_TCP_OVERSIZE_DISABLE is not set
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=3072
# CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY is not set
# CONFIG_TCPIP_TASK_AFFINITY_CPU0 is not set
CONFIG_TCPIP_TASK_AFFINITY_CPU1=y
CONFIG_TCPIP_TASK_AFFINITY=0x1
# CONFIG_PPP_SUPPORT is not set
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
CONFIG_ESP32_PTHREAD_STACK_MIN=768
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY is not set
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_0 is not set
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_1=y
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS is not set
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED is not set
CONFIG_IP_LOST_TIMER_INTERVAL=120
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
# End of deprecated options
chenyananee
Re: MCPWM
Postby chenyananee » Thu Jun 16, 2022 7:49 am
maybe i have found the reason.
for the same environment, the same code, the same idf version, if i enable the PM CONFIG the board will work wrong.
such like the picture, the left can work correctly and the right can't.
i want to know why the PM module can cause the issue.
morris
Re: MCPWM
Postby morris » Fri Jun 17, 2022 3:47 am
Nice catch! You got the point. In fact the MCPWM's clock source is from an internal PLL, which is 160MHz by default. But when you enabled the Power Management, the clock frequency will be reduced to save the power if the following conditions are met:
1. CPU goes into IDLE task
2. There's no power management lock that is required by others
See https://docs.espressif.com/projects/esp ... ement.html for more information.
chenyananee
Re: MCPWM
Postby chenyananee » Sun Jun 19, 2022 9:25 am
thanks for your comments.
is it means that i can't enable the PM if i want to use the mcpwm module?
or i can sellect the other clock for the mcpwm module?
is there any way for us to don't modify the congfiguration and let the mcpwm module work fine.
our product use the ESP32-WROVER-E module, and this product can work Stably for market. so we don't want to modify the configuration if we have other way.
chenyananee
Re: MCPWM
Postby chenyananee » Sun Jun 19, 2022 9:35 am
i have saw that the mcpwm module can't perceive the DFS.
i need to call the function of esp_pm_lock_acquire(ESP_PM_APB_FREQ_MAX) when i use the mcpwm module, and need to call the function of esp_pm_lock_release(ESP_PM_APB_FREQ_MAX) when i stop the pwm.
is it right?
