Can these pins be used as two separate inputs?
Code: Untitled.c Select all
int pinTest1 = 36;
int pinTest2 = 39;
Serial.begin(9600);
pinMode(pinTest1, INPUT_PULLUP);
pinMode(pinTest2, INPUT_PULLUP);
byte lastState1 = 0;
byte lastState2 = 0;
byte statePin1 = digitalRead(pinTest1);
if(lastState1 != statePin1){
Serial.print(" Pin "); Serial.print(pinTest1); Serial.print(" = "); Serial.println(statePin1);
if(statePin1 == HIGH) Serial.println();
lastState1 = statePin1;
byte statePin2 = digitalRead(pinTest2);
if(lastState2 != statePin2){
Serial.print(" Pin "); Serial.print(pinTest2); Serial.print(" = "); Serial.println(statePin2);
if(statePin2 == HIGH) Serial.println();
lastState2 = statePin2;
