ESP32 crash can bus communication with Arduino
Beubeu
Postby Beubeu » Thu Feb 09, 2023 9:37 am
Hello everyone,
I need to establish a Can bus link between an ESP32 and an Arduino Uno but my ESP32 crashes when launching the code.
The program uploads correctly but once in the monitor, it never reaches the loop and continuously redoes the setup.
Has anyone had this problem or knows how to fix it?
My code below:
#define CAN_25KBPS          4
#define CAN_50KBPS          8
#define CAN_125KBPS         13
#define CAN_500KBPS         16
#define CAN_1000KBPS        18
#define CAN_STDID          (0x00)
#define CAN_EXTID          (0x01)
#define CAN_STDID_REMOTE   (0x02)
#define CAN_EXTID_REMOTE   (0x03)
#include <Wire.h>
#include "Longan_I2C_CAN_Arduino.h"
#define I2C_1_SDA 41
#define I2C_1_SCL 40
I2C_CAN CAN(0x25);
void setup()
    Wire.begin(I2C_1_SDA, I2C_1_SCL);
    while (CAN_OK != CAN.begin(CAN_50KBPS))
        Serial.println("CAN BUS FAIL!");
        delay(100);
    Serial.println("CAN BUS OK!");
unsigned char buf[8] = {0, 1, 2, 3, 4, 5, 6, 0};
int incr = 0;
void loop()
    buf[7] = incr;
    incr = incr + 10;
    if(incr > 100)
        incr = 0;
    CAN.sendMsgBuf(0x01, CAN_STDID, 8, buf); // <- main suspect for the esp32 crash
    delay(100);
// END FILE
The monitor view
Capture d’écran 2023-02-09 à 10.35.14.png (230.3 KiB) Viewed 1622 times
Beubeu
Re: ESP32 crash can bus communication with Arduino
Postby Beubeu » Fri Feb 10, 2023 2:56 pm
Ok in the library, there was just missing a "return 0;" :D
My code is all good but the
Code: Untitled.c Select all
sendMsgBuf
was wrong...
Never missed the return 0; if your function is not a void for ESP32 :p
Users browsing this forum: Google [Bot] and 6 guests
