EN pin, prevent floating, RC delay, reset button & power switch?
ruckus
Postby ruckus » Tue Feb 21, 2023 11:28 pm
I would like to attach a slide power toggle switch, reset button, RC delay & prevent floating on the EN pin.
This is what I've come up with:
Is this schematic viable?
I'm concerned about the value of the pull down resistor (R7).. If I go any lower resistance the voltage on the EN pin will drop to much. Will a 100K resistor reliably pull EN down and prevent floating?
According to a circuit simulator I use, it should be 3V on the EN pin.
Am I going about this all the wrong way? I'm learning as I go along, so I'm not sure this is the best way to go about this.
I understand that traditionally a pull up resistor would have been used.. switch attached to ground.. yada yada.
I really want to use my slide switch as I plan to use it elsewhere in the project (SP3T).
LJH
Re: EN pin, prevent floating, RC delay, reset button & power switch?
Postby LJH » Thu Feb 23, 2023 6:58 am
Sorry but I could not get the point why you need a pull-down? A pull-up also could prevent EN from floating, right?
Anyway, 100K should be OK, since EN value is about 3 V, it is still high enough to enable chip.
boarchuz
Postby boarchuz » Thu Feb 23, 2023 10:19 am
It's unclear from the schematic but your slide switch almost certainly has 3 pins, allowing you to define the level for both positions. Connect one to GND for "Off", and the other to 3V3 through a 10k resistor for "On". You can do away with R7 then, and arguably the reset button too.
