Facing issue in provisioning ESP32-C3-DevKitC-02 with BLE/QR code : (55388) wifi:Error!
saikrishnaa
Postby saikrishnaa » Fri Mar 03, 2023 2:35 pm
Hi Team,
I am having ESP32-C3-DevKitC-02 with me and I am trying to run the matter. so I have gone through the following link
https://docs.espressif.com/projects/esp ... ction.html
in which I found the launchpad option which is to test Matter on Espressif devices without any additional setup.
So I tried that with following link :
https://espressif.github.io/esp-launchpad/
there I have selected C3 and application as RainMaker-LedLight (Image), then flashed the pre-built package through browser by selecting the port Image. After that I have installed the rain-maker app in my android-device. when I tried to add device in the app after scanning the QR code or BLE (I didn't got pairing pop up in my phone). I am facing error in the mobile app as "Error! Device disconnected" screenshot is attached ()Image.
in the console I am able to see following error, after that it reboots
W (55388) wifi:Error! Should use default active scan time parameter for WiFi scan when Bluetooth is enabled!!!!!!
Guru Meditation Error: Core 0 panic'ed (Instruction access fault). Exception was unhandled.
Core 0 register dump:
MEPC : 0x0000000c RA : 0x40044ebc SP : 0x3fca4d90 GP : 0x3fc908a4
TP : 0x3fc6b5b4 T0 : 0x30010042 T1 : 0x4038072a T2 : 0x10300100
S0/FP : 0x0000013b S1 : 0x3fcbc86c A0 : 0x3fcbc8fc A1 : 0x3fcaec4c
A2 : 0x00000050 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x0000000c
A6 : 0xffffffa9 A7 : 0x3fcdf860 S2 : 0x3fcdf85c S3 : 0x3fcaea1c
S4 : 0x3fcaec48 S5 : 0x3fcbc8fc S6 : 0x3fcdf86c S7 : 0x00000000
S8 : 0x3fca2cbc S9 : 0x00000050 S10 : 0x00000000 S11 : 0x00000050
T3 : 0xdfffffff T4 : 0xbfffffff T5 : 0x80000000 T6 : 0x08005410
MSTATUS : 0x00001881 MTVEC : 0x40380001 MCAUSE : 0x00000001 MTVAL : 0x0000000c
MHARTID : 0x00000000
Stack memory:
3fca4d90: 0x00000002 0x00000004 0x00000000 0x3fcbc906 0xffffffa9 0x00000000 0x3fce0000 0x3fce0000
3fca4db0: 0x3fca6074 0x00000000 0x3fca6074 0x00000000 0x3fcdf934 0x3fce0000 0x3ff1b000 0x3fce0000
3fca4dd0: 0x3fce0000 0x3fce0000 0x000000f5 0xffffffa9 0x3fcaea1c 0x3fcbc86c 0x3fcbc8fc 0x4038e43e
3fca4df0: 0x3fcdf934 0x3fce0000 0x3ff1b000 0x00000000 0x3fce0000 0x3fce0000 0x000000f5 0x3fce0000
3fca4e10: 0x3fcbc8cc 0x3fce0000 0x3fcbc86c 0x400415ba 0x00000000 0x3fce0000 0x3fce0000 0x3ff1b5a8
3fca4e30: 0x00000000 0x3fcdf918 0x3fce0000 0x40040902 0x00000000 0x00000000 0x00000011 0x00000000
3fca4e50: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
3fca4e70: 0x00000000 0x00000000 0x00000000 0x4038b56c 0x00000000 0x00000000 0x00000000 0x00000000
3fca4e90: 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0x27146414 0x01010107 0x00000001 0x000000ff
3fca4eb0: 0x00000000 0x00000000 0x7f7fffff 0x00000000 0x3fe00000 0x00000000 0x3ff00000 0x00000000
3fca4ed0: 0x40000000 0xffc00000 0x41dfffff 0x94a03595 0x3fdfffff 0x35afe535 0x3fe00000 0x94a03595
3fca4ef0: 0x3fcfffff 0x00000000 0x3fc00000 0x00000000 0x40300000 0x00000000 0x3ff80000 0x636f4361
3fca4f10: 0x3fd287a7 0x8b60c8b3 0x3fc68a28 0x509f79fb 0x3fd34413 0x00000000 0x40240000 0x00000000
3fca4f30: 0x401c0000 0x00000000 0x40140000 0x00000000 0x43500000 0x00000000 0x7ff80000 0x7fc00000
3fca4f50: 0xa5a5a5a5 0x00000154 0x3fca4d60 0x3fc9ad34 0x3fc95b84 0x3fc95b84 0x3fca4f58 0x3fc95b7c
3fca4f70: 0x00000002 0x3fca2e90 0x3fca2e90 0x3fca4f58 0x00000000 0x00000017 0x3fca3554 0x69666977
3fca4f90: 0xe26fff00 0x8612a341 0x004b834c 0x00000000 0x3fca4f50 0x00000017 0x00000000 0x00000000
3fca4fb0: 0x00000000 0x00000000 0x3fc9b54c 0x3fc9b5b4 0x3fc9b61c 0x00000000 0x00000000 0x00000001
3fca4fd0: 0x00000000 0x00000000 0x00000000 0x420e33c4 0x00000000 0x00000000 0x00000000 0x00000000
3fca4ff0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
3fca5010: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
3fca5030: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
3fca5050: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
3fca5070: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
3fca5090: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x3fca0000 0x00000054
3fca50b0: 0x3fca50b0 0x3fca50b0 0x3fca50b0 0x3fca50b0 0x00000000 0x3fca50c8 0xffffffff 0x3fca50c8
3fca50d0: 0x3fca50c8 0x00000000 0x3fca50dc 0xffffffff 0x3fca50dc 0x3fca50dc 0x00000000 0x00000001
3fca50f0: 0x00000000 0x9400ffff 0x00000000 0xfd5ba7a7 0x3fca50a8 0x00000054 0x00000000 0x3fca5108
3fca5110: 0x00000000 0x00000000 0x00000000 0x3fca5120 0xffffffff 0x3fca5120 0x3fca5120 0x00000000
3fca5130: 0x3fca5134 0xffffffff 0x3fca5134 0x3fca5134 0x00000001 0x00000001 0x00000000 0x0c00ffff
3fca5150: 0x00000000 0xc55d58fa 0x3fca5100 0x000007b8 0x6f6d706f 0x00006564 0x2e617473 0x64697373
3fca5170: 0x00000000 0x2e617473 0x68747561 0x65646f6d 0x00010000 0x00000000 0x00000003 0x00000002
ELF file SHA256: 55af42c4ad14898f
Rebooting...
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
I am providing the detailed log below
detail-log
esptool.js v0.1-dev
Serial port WebSerial VendorID 0x10c4 ProductID 0xea60
Connecting.......
Detecting chip type... ESP32-C3
Chip is ESP32-C3 (revision 3)
Features: Wi-Fi
Crystal is 40MHz
MAC: 58:cf:79:1e:b2:88
Uploading stub...
Running stub...
Stub running...
Changing baudrate to 921600
Changed
Not changing the image
Compressed 1502464 bytes to 765494...
I (908) wifi:set rx active PTI: 0, rx ack PTI: 12, and default PTI: 1
I (908) wifi:mode : sta (58:cf:79:1e:b2:88)
I (908) wifi:enable tsf
W (908) BTDM_INIT: esp_bt_controller_mem_release not implemented, return OK
I (918) BTDM_INIT: BT controller compile version [ae5cf49]
I (928) coexist: coexist rom version 9387209
I (928) BTDM_INIT: Bluetooth MAC: 58:cf:79:1e:b2:89
I (938) protocomm_nimble: BLE Host Task Started
GAP procedure initiated: stop advertising.
GAP procedure initiated: advertise; disc_mode=2 adv_channel_map=0 own_addr_type=0 adv_filter_policy=0 adv_itvl_min=256 adv_itvl_max=256
I (958) wifi_prov_mgr: Provisioning started with service name : PROV_9e8708
I (958) app_wifi: Provisioning started
I (968) esp_rmaker_local: Event 1
I (968) app_wifi: Scan this QR code from the ESP RainMaker phone app for Provisioning.
I (1168) app_wifi: If QR code is not visible, copy paste the below URL in a browser.
https://rainmaker.espressif.com/qrcode. ... port":"ble"}
______ _____ _____ _____ _____ _ _ __ __ _ ________ _____
| ____|/ ____| __ \ | __ \ /\ |_ _| \ | | \/ | /\ | |/ / ____| __ \
| |__ | (___ | |__) | | |__) | / \ | | | \| | \ / | / \ | ' /| |__ | |__) |
| __| \___ \| ___/ | _ / / /\ \ | | | . ` | |\/| | / /\ \ | < | __| | _ /
| |____ ____) | | | | \ \ / ____ \ _| |_| |\ | | | |/ ____ \| . \| |____| | \ \
|______|_____/|_| |_| \_\/_/ \_\_____|_| \_|_| |_/_/ \_\_|\_\______|_| \_\
Welcome to ESP RainMaker led_light demo application!
Follow these steps to get started:
1. Download the ESP RainMaker phone app by visiting this link from your phone's browser:
http://bit.ly/esp-rmaker
2. Sign up and follow the steps on screen to add the device to your Wi-Fi network.
3. You are now ready to use the device and control it locally as well as remotely.
You can also use the Boot button on the board to control your device.
If you want to reset Wi-Fi credentials, or reset to factory, press and hold the Boot button.
This application uses ESP RainMaker, which is based on ESP IDF.
Check out the source code for this application here:
https://github.com/espressif/esp-rainma ... /led_light
Please visit https://rainmaker.espressif.com for additional information.
I (1318) app_wifi: Provisioning Started. Name : PROV_9e8708, POP : 61d2f180
Stack memory:
Rebooting...
Build:Feb 7 2021
rst:0xc (RTC_SW_CPU_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x403840c6
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x17a8
load:0x403ce000,len:0x894
load:0x403d0000,len:0x2bf8
entry 0x403ce000
I (57) boot: ESP-IDF v4.3-beta2-2-g9a2d251912 2nd stage bootloader
I (57) boot: compile time 19:26:26
I (57) boot: chip revision: 3
I (60) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (68) boot.esp32c3: SPI Speed : 80MHz
I (72) boot.esp32c3: SPI Mode : DIO
I (77) boot.esp32c3: SPI Flash Size : 4MB
I (82) boot: Enabling RNG early entropy source...
I (87) boot: Partition Table:
I (91) boot: ## Label Usage Type ST Offset Length
I (98) boot: 0 sec_cert unknown 3f 00 0000d000 00003000
I (106) boot: 1 nvs WiFi data 01 02 00010000 00006000
I (113) boot: 2 otadata OTA data 01 00 00016000 00002000
I (121) boot: 3 phy_init RF data 01 01 00018000 00001000
I (128) boot: 4 ota_0 OTA app 00 10 00020000 00190000
I (136) boot: 5 ota_1 OTA app 00 11 001b0000 00190000
I (143) boot: 6 fctry WiFi data 01 02 00340000 00006000
I (151) boot: 7 coredump Unknown data 01 03 00350000 00010000
I (158) boot: End of partition table
I (163) boot_comm: chip revision: 3, min. application chip revision: 0
I (170) esp_image: segment 0: paddr=00020020 vaddr=3c110020 size=3999ch (235932) map
I (215) esp_image: segment 1: paddr=000599c4 vaddr=3fc90000 size=03f00h ( 16128) load
I (218) esp_image: segment 2: paddr=0005d8cc vaddr=40380000 size=0274ch ( 10060) load
I (223) esp_image: segment 3: paddr=00060020 vaddr=42000020 size=104070h (1065072) map
I (396) esp_image: segment 4: paddr=00164098 vaddr=4038274c size=0d70ch ( 55052) load
I (412) boot: Loaded app from partition at offset 0x20000
I (413) boot: Disabling RNG early entropy source...
I (424) cpu_start: Pro cpu up.
I (481) cpu_start: Pro cpu start user code
I (481) cpu_start: cpu freq: 160000000
I (481) cpu_start: Application information:
I (484) cpu_start: Project name: led_light
I (489) cpu_start: App version: 1.1
I (493) cpu_start: Compile time: Apr 9 2021 19:28:05
I (499) cpu_start: ELF file SHA256: 55af42c4ad14898f...
I (505) cpu_start: ESP-IDF: v4.3-beta2-2-g9a2d251912
I (512) heap_init: Initializing. RAM available for dynamic allocation:
I (519) heap_init: At 3FC9AD20 len 000252E0 (148 KiB): DRAM
I (525) heap_init: At 3FCC0000 len 0001F060 (124 KiB): STACK/DRAM
I (532) heap_init: At 50000000 len 00002000 (8 KiB): FAKEDRAM
I (539) spi_flash: detected chip: generic
I (543) spi_flash: flash io: dio
I (548) cpu_start: Starting scheduler.
I (553) gpio: GPIO[9]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
I (573) coexist: coexist rom version 9387209
I (573) pp: pp rom version: 9387209
I (573) net80211: net80211 rom version: 9387209
I (593) wifi:wifi driver task: 3fca4f58, prio:23, stack:6656, core=0
I (593) system_api: Base MAC address is not set
I (593) system_api: read default base MAC address from EFUSE
I (603) wifi:wifi firmware version: bb5a818
I (603) wifi:wifi certification version: v7.0
I (603) wifi:config NVS flash: enabled
I (613) wifi:config nano formating: disabled
I (613) wifi:Init data frame dynamic rx buffer num: 32
I (623) wifi:Init management frame dynamic rx buffer num: 32
I (623) wifi:Init management short buffer num: 32
I (633) wifi:Init dynamic tx buffer num: 32
I (633) wifi:Init static tx FG buffer num: 2
I (633) wifi:Init static rx buffer size: 1600
I (643) wifi:Init static rx buffer num: 10
I (643) wifi:Init dynamic rx buffer num: 32
I (653) wifi_init: rx ba win: 6
I (653) wifi_init: tcpip mbox: 32
I (653) wifi_init: udp mbox: 6
I (663) wifi_init: tcp mbox: 6
I (663) wifi_init: tcp tx win: 5744
I (663) wifi_init: tcp rx win: 5744
I (673) wifi_init: tcp mss: 1440
I (673) wifi_init: WiFi IRAM OP enabled
I (683) wifi_init: WiFi RX IRAM OP enabled
I (693) esp_rmaker_work_queue: Work Queue created.
I (693) esp_mqtt_glue: Initialising MQTT
I (693) esp_rmaker_node: Node ID ----- Xsd95TroWnvoRrrvmsEaTJ
I (703) esp_rmaker_ota: OTA state = 2
I (703) esp_rmaker_ota_using_topics: OTA enabled with Topics
I (713) esp_rmaker_time_service: Time service enabled
I (713) esp_rmaker_time: Initializing SNTP. Using the SNTP server: pool.ntp.org
I (723) esp_rmaker_core: Starting RainMaker Work Queue task
I (733) esp_rmaker_work_queue: RainMaker Work Queue task started.
W (743) BTDM_INIT: esp_bt_mem_release not implemented, return OK
I (743) wifi_prov_scheme_ble: BT memory released
I (753) app_wifi: Starting provisioning
I (753) phy_init: phy_version 300,77edb9b,Feb 25 2021,11:36:08
I (933) wifi:set rx active PTI: 0, rx ack PTI: 12, and default PTI: 1
I (933) wifi:mode : sta (58:cf:79:1e:b2:88)
I (933) wifi:enable tsf
W (933) BTDM_INIT: esp_bt_controller_mem_release not implemented, return OK
I (943) BTDM_INIT: BT controller compile version [ae5cf49]
I (953) coexist: coexist rom version 9387209
I (953) BTDM_INIT: Bluetooth MAC: 58:cf:79:1e:b2:89
I (963) protocomm_nimble: BLE Host Task Started
I (983) wifi_prov_mgr: Provisioning started with service name : PROV_9e8708
I (993) app_wifi: Provisioning started
I (993) esp_rmaker_local: Event 1
I (993) app_wifi: Scan this QR code from the ESP RainMaker phone app for Provisioning.
I (1193) app_wifi: If QR code is not visible, copy paste the below URL in a browser.
I (1343) app_wifi: Provisioning Started. Name : PROV_9e8708, POP : 61d2f180
Can anyone suggest that how to fix this issue. how should I provision and how to fix this issue.
Regards,
Sai Krishna
