AT驱动命令编译后指令异常
Moderator: XCGuang
xiaomuzilyc
AT驱动命令编译后指令异常
Postby xiaomuzilyc » Fri Apr 21, 2023 5:42 am
使用AT2.4版本编译,启用CONFIG_AT_DRIVER_COMMAND_SUPPORT编译下载后,发送命令AT+DRVADC=0,0正常响应,发送命令AT+DRVPWMINIT=10000,10,17没有正确回复,回复值为ready
AT+DRVPWMINIT=100
[11:10:10.617]收←◆\0
启动打印信息:
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:6276
load:0x40078000,len:16216
load:0x40080400,len:3632
entry 0x40080664
[0;32mI (27) boot: ESP-IDF v4.3.2-553-g588436db47 2nd stage bootloader[0m
[0;32mI (27) boot: compile time 09:55:26[0m
[0;32mI (27) boot: chip revision: 1[0m
[0;32mI (31) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m
[0;32mI (38) boot.esp32: SPI Speed : 40MHz[0m
[0;32mI (43) boot.esp32: SPI Mode : DIO[0m
[0;32mI (47) boot.esp32: SPI Flash Size : 4MB[0m
[0;32mI (52) boot: Enabling RNG early entropy source...[0m
[0;32mI (57) boot: Partition Table:[0m
[0;32mI (61) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (68) boot: 0 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (76) boot: 1 otadata OTA data 01 00 00010000 00002000[0m
[0;32mI (83) boot: 2 nvs WiFi data 01 02 00012000 0000e000[0m
[0;32mI (90) boot: 3 at_customize unknown 40 00 00020000 000e0000[0m
[0;32mI (98) boot: 4 ota_0 OTA app 00 10 00100000 00180000[0m
[0;32mI (105) boot: 5 ota_1 OTA app 00 11 00280000 00180000[0m
[0;32mI (113) boot: End of partition table[0m
[0;32mI (117) boot_comm: chip revision: 1, min. application chip revision: 0[0m
[0;32mI (124) esp_image: segment 0: paddr=00100020 vaddr=3f400020 size=1e6a8h (124584) map[0m
[0;32mI (178) esp_image: segment 1: paddr=0011e6d0 vaddr=3ffbdb60 size=01948h ( 6472) load[0m
[0;32mI (181) esp_image: segment 2: paddr=00120020 vaddr=400d0020 size=1103e4h (1115108) map[0m
[0;32mI (587) esp_image: segment 3: paddr=0023040c vaddr=3ffbf4a8 size=02318h ( 8984) load[0m
[0;32mI (591) esp_image: segment 4: paddr=0023272c vaddr=40080000 size=1dfe4h (122852) load[0m
[0;32mI (644) esp_image: segment 5: paddr=00250718 vaddr=400c0000 size=00064h ( 100) load[0m
[0;32mI (644) esp_image: segment 6: paddr=00250784 vaddr=50000000 size=00010h ( 16) load[0m
[0;32mI (664) boot: Loaded app from partition at offset 0x100000[0m
[0;32mI (664) boot: Disabling RNG early entropy source...[0m
no external 32k oscillator, disable it now.
module_name:WROOM-32
max tx power=78,ret=0
2.4.1
AT命令发送:
AT+RST
ATE1
AT命令响应:
ready
AT
OK
AT+RST
OK
ready
AT+DRVPWMINIT=100
[11:10:10.617]收←◆\0
Sun
Re: AT驱动命令编译后指令异常
Postby Sun » Thu Apr 27, 2023 2:18 am
请提供下输出日志口(UART0 管脚请参考:https://docs.espressif.com/projects/esp ... n.html#id1)的 log。
xiaomuzilyc
Re: AT驱动命令编译后指令异常
Postby xiaomuzilyc » Fri Apr 28, 2023 1:54 am
[09:50:45.861]收←◆ets Jun 8 2016 00:22:57
entry 0x40080664
[0;32mI (27) boot: compile time 21:00:42[0m
[0;32mI (42) boot.esp32: SPI Mode : DIO[0m
[0;32mI (51) boot: Enabling RNG early entropy source...[0m
[0;32mI (60) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (75) boot: 1 otadata OTA data 01 00 00010000 00002000[0m
[0;32mI (124) esp_image: segment 0: paddr=00100020 vaddr=3f400020 size=2e220h (188960) map[0m
[09:50:46.061]收←◆[0;32mI (201) esp_image: segment 1: paddr=0012e248 vaddr=3ffbdb60 size=01dd0h ( 7632) load[0m
[0;32mI (204) esp_image: segment 2: paddr=00130020 vaddr=400d0020 size=11c224h (1163812) map[0m
[09:50:46.486]收←◆[0;32mI (628) esp_image: segment 3: paddr=0024c24c vaddr=3ffbf930 size=01f68h ( 8040) load[0m
[0;32mI (631) esp_image: segment 4: paddr=0024e1bc vaddr=40080000 size=1e27ch (123516) load[0m
[09:50:46.533]收←◆[0;32mI (685) esp_image: segment 5: paddr=0026c440 vaddr=400c0000 size=00064h ( 100) load[0m
[0;32mI (685) esp_image: segment 6: paddr=0026c4ac vaddr=50000000 size=00010h ( 16) load[0m
[0;32mI (705) boot: Loaded app from partition at offset 0x100000[0m
[0;32mI (705) boot: Disabling RNG early entropy source...[0m
[0;32mI (717) cpu_start: Pro cpu up.[0m
[0;32mI (717) cpu_start: Single core mode[0m
D (717) clk: waiting for 32k oscillator to start up[0m
D (720) efuse: coding scheme 0[0m
D (724) efuse: In EFUSE_BLK0__DATA3_REG is used 1 bits starting with 15 bit[0m
D (731) efuse: coding scheme 0[0m
D (734) efuse: In EFUSE_BLK0__DATA5_REG is used 1 bits starting with 20 bit[0m
[09:50:46.674]收←◆D (821) clk: waiting for 32k oscillator to start up[0m
D (821) efuse: coding scheme 0[0m
D (821) efuse: In EFUSE_BLK0__DATA3_REG is used 1 bits starting with 15 bit[0m
D (825) efuse: coding scheme 0[0m
D (828) efuse: In EFUSE_BLK0__DATA5_REG is used 1 bits starting with 20 bit[0m
[09:50:46.769]收←◆[0;33mW (916) clk: 32 kHz XTAL not found, switching to internal 150 kHz oscillator[0m
D (923) clk: RTC_SLOW_CLK calibration value: 3470784[0m
[0;32mI (929) cpu_start: Pro cpu start user code[0m
[0;32mI (929) cpu_start: cpu freq: 80000000[0m
[0;32mI (929) cpu_start: Application information:[0m
[0;32mI (933) cpu_start: Project name: esp-at[0m
[0;32mI (938) cpu_start: App version: v2.4.2.0-14-g86962bd[0m
[0;32mI (944) cpu_start: Compile time: Apr 27 2023 21:01:01[0m
[0;32mI (950) cpu_start: ELF file SHA256: 007600f85306ebb4...[0m
[0;32mI (956) cpu_start: ESP-IDF: v4.3.2-553-g588436db47[0m
D (963) memory_layout: Checking 10 reserved memory ranges:[0m
D (968) memory_layout: Reserved memory range 0x3ff80000 - 0x3ff80064[0m
D (975) memory_layout: Reserved memory range 0x3ffae000 - 0x3ffae6e0[0m
D (981) memory_layout: Reserved memory range 0x3ffae6e0 - 0x3ffaff10[0m
D (987) memory_layout: Reserved memory range 0x3ffb0000 - 0x3ffb6388[0m
D (994) memory_layout: Reserved memory range 0x3ffb8000 - 0x3ffb9a20[0m
D (1000) memory_layout: Reserved memory range 0x3ffbdb28 - 0x3ffbdb5c[0m
D (1007) memory_layout: Reserved memory range 0x3ffbdb60 - 0x3ffc9938[0m
D (1013) memory_layout: Reserved memory range 0x3ffe0000 - 0x3ffe0440[0m
D (1020) memory_layout: Reserved memory range 0x40070000 - 0x40078000[0m
D (1026) memory_layout: Reserved memory range 0x40080000 - 0x4009e27c[0m
D (1033) memory_layout: Building list of available memory regions:[0m
D (1039) memory_layout: Available memory region 0x3ff80064 - 0x3ff82000[0m
D (1046) memory_layout: Available memory region 0x3ffaff10 - 0x3ffb0000[0m
D (1053) memory_layout: Available memory region 0x3ffb6388 - 0x3ffb8000[0m
D (1059) memory_layout: Available memory region 0x3ffb9a20 - 0x3ffbdb28[0m
D (1066) memory_layout: Available memory region 0x3ffc9938 - 0x3ffca000[0m
D (1073) memory_layout: Available memory region 0x3ffca000 - 0x3ffcc000[0m
D (1079) memory_layout: Available memory region 0x3ffcc000 - 0x3ffce000[0m
D (1086) memory_layout: Available memory region 0x3ffce000 - 0x3ffd0000[0m
D (1093) memory_layout: Available memory region 0x3ffd0000 - 0x3ffd2000[0m
D (1099) memory_layout: Available memory region 0x3ffd2000 - 0x3ffd4000[0m
D (1106) memory_layout: Available memory region 0x3ffd4000 - 0x3ffd6000[0m
D (1113) memory_layout: Available memory region 0x3ffd6000 - 0x3ffd8000[0m
D (1119) memory_layout: Available memory region 0x3ffd8000 - 0x3ffda000[0m
D (1126) memory_layout: Available memory region 0x3ffda000 - 0x3ffdc000[0m
D (1133) memory_layout: Available memory region 0x3ffdc000 - 0x3ffde000[0m
D (1139) memory_layout: Available memory region 0x3ffde000 - 0x3ffe0000[0m
D (1146) memory_layout: Available memory region 0x3ffe0440 - 0x3ffe4000[0m
D (1153) memory_layout: Available memory region 0x3ffe4000 - 0x3ffe8000[0m
D (1159) memory_layout: Available memory region 0x3ffe8000 - 0x3fff0000[0m
D (1166) memory_layout: Available memory region 0x3fff0000 - 0x3fff8000[0m
D (1173) memory_layout: Available memory region 0x3fff8000 - 0x3fffc000[0m
D (1180) memory_layout: Available memory region 0x3fffc000 - 0x40000000[0m
D (1186) memory_layout: Available memory region 0x40078000 - 0x40080000[0m
D (1193) memory_layout: Available memory region 0x4009e27c - 0x400a0000[0m
[0;32mI (1200) heap_init: Initializing. RAM available for dynamic allocation:[0m
D (1207) heap_init: New heap initialised at 0x3ff80064[0m
[0;32mI (1212) heap_init: At 3FF80064 len 00001F9C (7 KiB): RTCRAM[0m
[0;32mI (1218) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM[0m
D (1225) heap_init: New heap initialised at 0x3ffb6388[0m
[0;32mI (1230) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM[0m
D (1236) heap_init: New heap initialised at 0x3ffb9a20[0m
[0;32mI (1241) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM[0m
D (1247) heap_init: New heap initialised at 0x3ffc9938[0m
[0;32mI (1253) heap_init: At 3FFC9938 len 000166C8 (89 KiB): DRAM[0m
[0;32mI (1259) heap_init: At 3FFE0440 len 0001FBC0 (126 KiB): D/IRAM[0m
D (1265) heap_init: New heap initialised at 0x40078000[0m
[0;32mI (1271) heap_init: At 40078000 len 00008000 (32 KiB): IRAM[0m
D (1277) heap_init: New heap initialised at 0x4009e27c[0m
[0;32mI (1282) heap_init: At 4009E27C len 00001D84 (7 KiB): IRAM[0m
D (1289) intr_alloc: Connected src 46 to int 2 (cpu 0)[0m
D (1294) cpu_start: calling init function: 0x401de5b4[0m
D (1299) cpu_start: calling init function: 0x400924f0[0m
D (1304) cpu_start: calling init function: 0x400d5390[0m
D (1309) cpu_start: calling init function: 0x400d257c[0m
D (1314) intr_alloc: Connected src 17 to int 3 (cpu 0)[0m
[0;32mI (1330) sleep: Configure to isolate all GPIO pins in sleep state[0m
D (1332) intr_alloc: Connected src 24 to int 9 (cpu 0)[0m
[0;32mI (1333) cpu_start: Starting scheduler on PRO CPU.[0m
D (1339) heap_init: New heap initialised at 0x3ffe0440[0m
D (1343) intr_alloc: Connected src 16 to int 12 (cpu 0)[0m
D (1349) efuse: coding scheme 0[0m
D (1352) efuse: In EFUSE_BLK0__DATA3_REG is used 1 bits starting with 15 bit[0m
D (1359) efuse: coding scheme 0[0m
D (1362) efuse: In EFUSE_BLK0__DATA5_REG is used 1 bits starting with 20 bit[0m
D (1373) partition: Loading the partition table[0m
D (1398) event: running task for loop 0x3ffb7ea4[0m
D (1398) event: created task for loop 0x3ffb7ea4[0m
D (1398) event: created event loop 0x3ffb7ea4[0m
D (1402) esp_netif_lwip: LwIP stack has been initialized[0m
D (1406) esp_netif_lwip: esp-netif has been successfully initialized[0m
D (1413) esp_netif_objects: esp_netif_add_to_list 0x3ffbd2dc[0m
D (1418) esp_netif_objects: esp_netif_add_to_list netif added successfully (total netifs: 1)[0m
D (1428) esp_netif_objects: esp_netif_add_to_list 0x3ffbd6a8[0m
D (1432) esp_netif_objects: esp_netif_add_to_list netif added successfully (total netifs: 2)[0m
D (1441) nvs: nvs_open_from_partition misc 1[0m
I (1447) wifi:wifi driver task: 3ffcbe30, prio:23, stack:6144, core=0
[09:50:47.324]收←◆[0;32mI (1452) system_api: Base MAC address is not set[0m
[0;32mI (1457) system_api: read default base MAC address from EFUSE[0m
D (1463) efuse: coding scheme 0[0m
D (1466) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 8 bit[0m
D (1473) efuse: coding scheme 0[0m
D (1476) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 0 bit[0m
D (1483) efuse: coding scheme 0[0m
D (1486) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 24 bit[0m
D (1493) efuse: coding scheme 0[0m
D (1497) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 16 bit[0m
D (1504) efuse: coding scheme 0[0m
D (1507) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 8 bit[0m
D (1514) efuse: coding scheme 0[0m
D (1517) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 0 bit[0m
D (1524) efuse: coding scheme 0[0m
D (1527) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 16 bit[0m
D (1535) nvs: nvs_open_from_partition nvs.net80211 1[0m
D (1540) nvs: nvs_get opmode 1[0m
D (1543) nvs: nvs_get_str_or_blob sta.ssid[0m
D (1547) nvs: nvs_get sta.authmode 1[0m
D (1550) nvs: nvs_get_str_or_blob sta.pswd[0m
D (1554) nvs: nvs_get_str_or_blob sta.pmk[0m
D (1559) nvs: nvs_get sta.chan 1[0m
D (1562) nvs: nvs_get auto.conn 1[0m
D (1565) nvs: nvs_get bssid.set 1[0m
D (1569) nvs: nvs_get_str_or_blob sta.bssid[0m
D (1573) nvs: nvs_get sta.lis_intval 2[0m
D (1577) nvs: nvs_get sta.phym 1[0m
D (1580) nvs: nvs_get sta.phybw 1[0m
D (1583) nvs: nvs_get_str_or_blob sta.apsw[0m
D (1587) nvs: nvs_get_str_or_blob sta.apinfo[0m
D (1592) nvs: nvs_get sta.scan_method 1[0m
D (1596) nvs: nvs_get sta.sort_method 1[0m
D (1599) nvs: nvs_get sta.minrssi 1[0m
D (1603) nvs: nvs_get sta.minauth 1[0m
D (1606) nvs: nvs_get sta.pmf_e 1[0m
D (1610) nvs: nvs_get sta.pmf_r 1[0m
D (1613) nvs: nvs_get sta.btm_e 1[0m
D (1617) nvs: nvs_get sta.rrm_e 1[0m
D (1620) nvs: nvs_get_str_or_blob ap.ssid[0m
D (1624) nvs: nvs_get_str_or_blob ap.passwd[0m
D (1628) nvs: nvs_get_str_or_blob ap.pmk[0m
D (1632) nvs: nvs_get ap.chan 1[0m
D (1635) nvs: nvs_get ap.authmode 1[0m
D (1639) nvs: nvs_get ap.hidden 1[0m
D (1642) nvs: nvs_get ap.max.conn 1[0m
D (1646) nvs: nvs_get bcn.interval 2[0m
D (1649) nvs: nvs_get ap.phym 1[0m
D (1653) nvs: nvs_get ap.phybw 1[0m
D (1656) nvs: nvs_get ap.sndchan 1[0m
D (1660) nvs: nvs_get ap.pmf_e 1[0m
D (1663) nvs: nvs_get ap.pmf_r 1[0m
D (1666) nvs: nvs_get ap.p_cipher 1[0m
D (1669) nvs: nvs_get lorate 1[0m
D (1673) nvs: nvs_get_str_or_blob country[0m
D (1677) nvs: nvs_get ap.ftm_r 1[0m
D (1680) nvs: nvs_set ap.sndchan 1 1[0m
I (1684) wifi:wifi firmware version: 41824c0
I (1687) wifi:wifi certification version: v7.0
I (1692) wifi:config NVS flash: enabled
I (1695) wifi:config nano formating: enabled
I (1699) wifi:Init data frame dynamic rx buffer num: 32
I (1704) wifi:Init management frame dynamic rx buffer num: 32
I (1709) wifi:Init management short buffer num: 32
I (1714) wifi:Init dynamic tx buffer num: 32
I (1718) wifi:Init static rx buffer size: 1600
I (1722) wifi:Init static rx buffer num: 10
I (1726) wifi:Init dynamic rx buffer num: 32
[0;32mI (1731) wifi_init: rx ba win: 6[0m
[0;32mI (1734) wifi_init: tcpip mbox: 32[0m
[0;32mI (1738) wifi_init: udp mbox: 6[0m
[0;32mI (1742) wifi_init: tcp mbox: 6[0m
[0;32mI (1745) wifi_init: tcp tx win: 5760[0m
[0;32mI (1750) wifi_init: tcp rx win: 5760[0m
[0;32mI (1754) wifi_init: tcp mss: 1440[0m
[0;32mI (1758) wifi_init: WiFi IRAM OP enabled[0m
[0;32mI (1762) wifi_init: WiFi RX IRAM OP enabled[0m
D (1767) ADC: Wi-Fi takes adc2 lock.[0m
[0;32mI (1771) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07[0m
[0;32mI (1778) phy_init: loading embedded multiple PHY init data[0m
[0;32mI (1784) phy_init: Support multiple PHY init data bins[0m
D (1789) phy_init: PHY data partition validated[0m
D (1794) nvs: nvs_open_from_partition phy 0[0m
D (1798) nvs: nvs_get cal_version 4[0m
D (1802) nvs: nvs_get_str_or_blob cal_mac[0m
D (1806) efuse: coding scheme 0[0m
D (1809) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 8 bit[0m
D (1816) efuse: coding scheme 0[0m
D (1819) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 0 bit[0m
D (1826) efuse: coding scheme 0[0m
D (1829) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 24 bit[0m
D (1836) efuse: coding scheme 0[0m
D (1839) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 16 bit[0m
D (1847) efuse: coding scheme 0[0m
D (1850) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 8 bit[0m
D (1857) efuse: coding scheme 0[0m
D (1860) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 0 bit[0m
D (1867) efuse: coding scheme 0[0m
D (1870) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 16 bit[0m
D (1877) nvs: nvs_get_str_or_blob cal_data[0m
D (1884) nvs: nvs_close 3[0m
D (1884) efuse: coding scheme 0[0m
D (1887) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 8 bit[0m
D (1894) efuse: coding scheme 0[0m
D (1897) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 0 bit[0m
D (1904) efuse: coding scheme 0[0m
D (1908) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 24 bit[0m
D (1915) efuse: coding scheme 0[0m
D (1918) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 16 bit[0m
D (1925) efuse: coding scheme 0[0m
D (1928) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 8 bit[0m
D (1935) efuse: coding scheme 0[0m
D (1938) efuse: In EFUSE_BLK0__DATA1_REG is used 8 bits starting with 0 bit[0m
D (1945) efuse: coding scheme 0[0m
D (1948) efuse: In EFUSE_BLK0__DATA2_REG is used 8 bits starting with 16 bit[0m
[09:50:47.901]收←◆I (2053) wifi:mode : softAP (34:94:54:2a:18:ad)
I (2055) wifi:Total power save buffer number: 16
I (2055) wifi:Init max length of beacon: 752/752
I (2056) wifi:Init max length of beacon: 752/752
D (2060) phy_init: Current country is CN, PHY init data type is SRRC
[0m
[0;32mI (2067) phy_init: load embedded multi phy init data[0m
[0;32mI (2073) phy_init: PHY init data type updated from DEFAULT to SRRC[0m
D (2079) event: running post WIFI_EVENT:12 with handler 0x40168014 and context 0x3ffbd614 on loop 0x3ffb7ea4[0m
D (2089) wifi_init_default: wifi_start esp-netif:0x3ffbd6a8 event-id12[0m
D (2095) wifi_init_default: WIFI mac address: 34 94 54 2a 18 ad[0m
D (2102) esp_netif_handlers: esp_netif action has started with netif0x3ffbd6a8 from event_id=12[0m
D (2110) esp_netif_lwip: check: remote, if=0x3ffbd6a8 fn=0x40158aa4
[0m
D (2117) esp_netif_lwip: esp_netif_start_api 0x3ffbd6a8[0m
D (2122) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3ffbd6a8[0m
D (2128) esp_netif_lwip: esp_netif_start_api Setting the lwip netif0x3ffbd728 UP[0m
D (2137) esp_netif_lwip: DHCP server started successfully[0m
D (2141) esp_netif_lwip: check: local, if=0x3ffbd6a8 fn=0x40159680
[0m
D (2147) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3ffbd6a8[0m
D (2154) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2162) nvs: nvs_open_from_partition UART 0[0m
D (2164) nvs: nvs_get rate 4[0m
D (2167) nvs: nvs_get databits 1[0m
D (2170) nvs: nvs_get stopbits 1[0m
D (2174) nvs: nvs_get parity 1[0m
D (2177) nvs: nvs_get flow_ctrl 1[0m
D (2180) nvs: nvs_close 4[0m
[0;32mI (2184) uart: queue free spaces: 30[0m
D (2187) intr_alloc: Connected src 35 to int 13 (cpu 0)[0m
I (2196) wifi:set country: cc=CN\0 schan=1 nchan=13 policy=1
2.4.1
D (2202) nvs: nvs_open_from_partition NVM_020 0[0m
D (2207) nvs: nvs_open_from_partition NVM_020 0[0m
D (2211) nvs: nvs_open_from_partition NVM_020 0[0m
D (2216) nvs: nvs_open_from_partition NVM_020 0[0m
D (2221) nvs: nvs_open_from_partition NVM_020 0[0m
D (2226) nvs: nvs_open_from_partition NVM_012 0[0m
I (2231) wifi:mode : sta (34:94:54:2a:18:ac) + softAP (34:94:54:2a:18:ad)
I (2236) wifi:enable tsf
D (2239) event: running post WIFI_EVENT:2 with handler 0x4016802c and context 0x3ffbd554 on loop 0x3ffb7ea4[0m
D (2248) wifi_init_default: wifi_start esp-netif:0x3ffbd2dc event-id2[0m
D (2255) wifi_init_default: WIFI mac address: 34 94 54 2a 18 ac[0m
D (2261) esp_netif_handlers: esp_netif action has started with netif0x3ffbd2dc from event_id=2[0m
D (2269) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158aa4
[0m
D (2276) esp_netif_lwip: esp_netif_start_api 0x3ffbd2dc[0m
D (2281) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3ffbd2dc[0m
D (2288) esp_netif_lwip: check: local, if=0x3ffbd2dc fn=0x40159680
[0m
D (2294) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3ffbd2dc[0m
D (2300) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2306) nvs: nvs_open_from_partition NVM_004 0[0m
D (2311) nvs: nvs_open_from_partition NVM_003 0[0m
D (2315) nvs: nvs_open_from_partition NVM_017 0[0m
D (2320) nvs: nvs_open_from_partition NVM_022 1[0m
D (2324) nvs: nvs_get wac 1[0m
D (2327) nvs: nvs_close 5[0m
D (2330) nvs: nvs_open_from_partition NVM_013 0[0m
D (2334) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158474
[0m
D (2341) esp_netif_lwip: esp_netif_dhcpc_stop_api esp_netif:0x3ffbd2dc[0m
D (2347) esp_netif_lwip: dhcp client stop successfully[0m
D (2353) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2358) esp_netif_lwip: check: remote, if=0x3ffbd6a8 fn=0x40158320
[0m
D (2365) esp_netif_lwip: esp_netif_dhcps_stop_api esp_netif:0x3ffbd6a8[0m
D (2371) esp_netif_lwip: dhcp server stop successfully[0m
D (2376) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2382) nvs: nvs_open_from_partition NVM_002 0[0m
D (2387) nvs: nvs_open_from_partition NVM_021 0[0m
D (2391) nvs: nvs_open_from_partition NVM_001 0[0m
D (2396) nvs: nvs_open_from_partition NVM_007 0[0m
D (2400) nvs: nvs_open_from_partition NVM_006 0[0m
D (2405) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x4015853c
[0m
D (2412) esp_netif_lwip: esp_netif_dhcpc_start_api esp_netif:0x3ffbd2dc[0m
D (2418) esp_netif_lwip: dhcp client re init[0m
D (2422) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2428) esp_netif_lwip: check: remote, if=0x3ffbd6a8 fn=0x40157eb8
[0m
D (2435) esp_netif_lwip: esp_netif_dhcps_start_api esp_netif:0x3ffbd6a8[0m
D (2441) esp_netif_lwip: DHCP server started successfully[0m
D (2447) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
I (2453) wifi:mode : softAP (34:94:54:2a:18:ad)
D (2457) event: running post WIFI_EVENT:3 with handler 0x40167ef8 and context 0x3ffbd584 on loop 0x3ffb7ea4[0m
D (2466) esp_netif_handlers: esp_netif action stopped with netif0x3ffbd2dc from event_id=3[0m
D (2475) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158c24
[0m
D (2481) esp_netif_lwip: call api in lwip: ret=0x5002, give sem[0m
D (2488) nvs: nvs_open_from_partition NVM_008 1[0m
D (2492) nvs: nvs_get dns_ser0 4[0m
D (2495) nvs: nvs_get dns_ser1 4[0m
D (2498) nvs: nvs_get dns_ser2 4[0m
D (2501) nvs: nvs_get_str_or_blob dns_svr0[0m
D (2506) nvs: nvs_close 6[0m
D (2508) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158870
[0m
D (2515) esp_netif_lwip: esp_netif_set_dns_info_api esp_netif:0x3ffbd2dc[0m
D (2521) esp_netif_lwip: set dns if=0x3ffbd2dc type=0 dns=dede43d0[0m
D (2528) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2533) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158870
[0m
D (2540) esp_netif_lwip: esp_netif_set_dns_info_api esp_netif:0x3ffbd2dc[0m
D (2547) esp_netif_lwip: set dns if=0x3ffbd2dc type=2 dns=8080808[0m
D (2553) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2558) nvs: nvs_open_from_partition NVM_009 1[0m
D (2563) nvs: nvs_get maxlink 1[0m
D (2566) nvs: nvs_open_from_partition NVM_009 0[0m
D (2571) nvs: nvs_get auth0 1[0m
D (2574) nvs: nvs_open_from_partition NVM_009 0[0m
D (2578) nvs: nvs_get auth1 1[0m
D (2581) nvs: nvs_open_from_partition NVM_009 0[0m
D (2586) nvs: nvs_get auth2 1[0m
D (2589) nvs: nvs_open_from_partition NVM_009 0[0m
D (2594) nvs: nvs_get auth3 1[0m
D (2597) nvs: nvs_open_from_partition NVM_009 0[0m
D (2601) nvs: nvs_get auth4 1[0m
D (2604) nvs: nvs_open_from_partition NVM_018 0[0m
D (2609) nvs: nvs_open_from_partition NVM_005 1[0m
D (2613) nvs: nvs_get enable 1[0m
D (2616) nvs: nvs_get type 1[0m
D (2619) nvs: nvs_get_str_or_blob r_ip[0m
D (2623) nvs: nvs_get r_port 4[0m
D (2626) nvs: nvs_get l_port 4[0m
D (2629) nvs: nvs_get change_mode 1[0m
D (2633) nvs: nvs_get keep_alive 2[0m
D (2636) nvs: nvs_close 13[0m
D (2642) nvs: nvs_open_from_partition NVM_015 0[0m
D (2644) nvs: nvs_open_from_partition NVM_023 0[0m
D (2648) nvs: nvs_open_from_partition NVM_019 0[0m
D (2653) BTDM_INIT: Release DRAM [0x3ffb2730] - [0x3ffb6388][0m
[09:50:49.128]收←◆D (3280) event: running post WIFI_EVENT:13 with handler 0x40167ee0 and context 0x3ffbd644 on loop 0x3ffb7ea4[0m
D (3280) esp_netif_handlers: esp_netif action stopped with netif0x3ffbd6a8 from event_id=13[0m
D (3287) esp_netif_lwip: check: remote, if=0x3ffbd6a8 fn=0x40158c24
[0m
D (3294) esp_netif_lwip: check: local, if=0x3ffbd6a8 fn=0x40159680
[0m
D (3300) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3ffbd6a8[0m
D (3307) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (3312) event: running post WIFI_EVENT:13 with handler 0x400f986c and context 0x3ffb2db0 on loop 0x3ffb7ea4[0m
I (3322) wifi:flush txq
I (3324) wifi:stop sw txq
I (3327) wifi:lmac stop hw txq
D (3329) ADC: Wi-Fi returns adc2 lock.[0m
entry 0x40080664
[09:50:49.394]收←◆[0;32mI (201) esp_image: segment 1: paddr=0012e248 vaddr=3ffbdb60 size=01dd0h ( 7632) load[0m
[0;32mI (205) esp_image: segment 2: paddr=00130020 vaddr=400d0020 size=11c224h (1163812) map[0m
[09:50:49.835]收←◆[0;32mI (628) esp_image: segment 3: paddr=0024c24c vaddr=3ffbf930 size=01f68h ( 8040) load[0m
[0;32mI (632) esp_image: segment 4: paddr=0024e1bc vaddr=40080000 size=1e27ch (123516) load[0m
[09:50:49.882]收←◆[0;32mI (685) esp_image: segment 5: paddr=0026c440 vaddr=400c0000 size=00064h ( 100) load[0m
D (721) efuse: coding scheme 0[0m
[09:50:50.023]收←◆D (822) clk: waiting for 32k oscillator to start up[0m
D (822) efuse: coding scheme 0[0m
D (822) efuse: In EFUSE_BLK0__DATA3_REG is used 1 bits starting with 15 bit[0m
D (829) efuse: In EFUSE_BLK0__DATA5_REG is used 1 bits starting with 20 bit[0m
[09:50:50.117]收←◆[0;33mW (916) clk: 32 kHz XTAL not found, switching to internal 150 kHz oscillator[0m
D (923) clk: RTC_SLOW_CLK calibration value: 3477619[0m
[0;32mI (934) cpu_start: Project name: esp-at[0m
[0;32mI (939) cpu_start: App version: v2.4.2.0-14-g86962bd[0m
[0;32mI (945) cpu_start: Compile time: Apr 27 2023 21:01:01[0m
[0;32mI (951) cpu_start: ELF file SHA256: 007600f85306ebb4...[0m
[0;32mI (957) cpu_start: ESP-IDF: v4.3.2-553-g588436db47[0m
D (969) memory_layout: Reserved memory range 0x3ff80000 - 0x3ff80064[0m
D (988) memory_layout: Reserved memory range 0x3ffb0000 - 0x3ffb6388[0m
D (1001) memory_layout: Reserved memory range 0x3ffbdb28 - 0x3ffbdb5c[0m
[09:50:50.230]收←◆Reserved memory range 0x3ffbdb60 - 0x3ffc9938[0m
D (1014) memory_layout: Reserved memory range 0x3ffe0000 - 0x3ffe0440[0m
D (1027) memory_layout: Reserved memory range 0x40080000 - 0x4009e27c[0m
D (1040) memory_layout: Available memory region 0x3ff80064 - 0x3ff82000[0m
D (1060) memory_layout: Available memory region 0x3ffb9a20 - 0x3ffbdb28[0m
D (1080) memory_layout: Available memory region 0x3ffcc000 - 0x3ffce000[0m
D (1100) memory_layout: Available memory region 0x3ffd2000 - 0x3ffd4000[0m
D (1120) memory_layout: Available memory region 0x3ffd8000 - 0x3ffda000[0m
D (1140) memory_layout: Available memory region 0x3ffde000 - 0x3ffe0000[0m
D (1160) memory_layout: Available memory region 0x3ffe8000 - 0x3fff0000[0m
D (1187) memory_layout: Available memory region 0x40078000 - 0x40080000[0m
[0;32mI (1212)
[09:50:50.432]收←◆heap_init: At 3FF80064 len 00001F9C (7 KiB): RTCRAM[0m
[0;32mI (1219) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM[0m
D (1248) heap_init: New heap initialised at 0x3ffc9938[0m
D (1266) heap_init: New heap initialised at 0x40078000[0m
[0;32mI (1331) sleep: Configure to isolate all GPIO pins in sleep state[0m
[0;32mI (1334) cpu_start: Starting scheduler on PRO CPU.[0m
[09:50:51.250]收←◆I (2054) wifi:mode : softAP (34:94:54:2a:18:ad)
I (2057) wifi:Init max length of beacon: 752/752
D (2061) phy_init: Current country is CN, PHY init data type is SRRC
[0m
D (2080) event: running post WIFI_EVENT:12 with handler 0x40168014 and context 0x3ffbd614 on loop 0x3ffb7ea4[0m
D (2096) wifi_init_default: WIFI mac address: 34 94 54 2a 18 ad[0m
D (2103) esp_netif_handlers: esp_netif action has started with netif0x3ffbd6a8 from event_id=12[0m
D (2111) esp_netif_lwip: check: remote, if=0x3ffbd6a8 fn=0x40158aa4
[0m
D (2123) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3ffbd6a8[0m
D (2129) esp_netif_lwip: esp_netif_start_api Setting the lwip netif0x3ffbd728 UP[0m
D (2138) esp_netif_lwip: DHCP server started successfully[0m
D (2142) esp_netif_lwip: check: local, if=0x3ffbd6a8 fn=0x40159680
[0m
D (2148) esp_netif_lwip: esp_netif_update_default_netif_lwip 0x3ffbd6a8[0m
D (2155) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2163) nvs: nvs_open_from_partition UART 0[0m
D (2165) nvs: nvs_get rate 4[0m
D (2168) nvs: nvs_get databits 1[0m
D (2171) nvs: nvs_get stopbits 1[0m
D (2181) nvs: nvs_close 4[0m
[0;32mI (2185) uart: queue free spaces: 30[0m
D (2188) intr_alloc: Connected src 35 to int 13 (cpu 0)[0m
I (2197) wifi:set country: cc=CN\0 schan=1 nchan=13 policy=1
2.4.1
D (2203) nvs: nvs_open_from_partition NVM_020 0[0m
D (2208) nvs: nvs_open_from_partition NVM_020 0[0m
D (2212) nvs: nvs_open_from_partition NVM_020 0[0m
D (2217) nvs: nvs_open_from_partition NVM_020 0[0m
I (2237) wifi:enable tsf
D (2240) event: running post WIFI_EVENT:2 with handler 0x4016802c and context 0x3ffbd554 on loop 0x3ffb7ea4[0m
D (2249) wifi_init_default: wifi_start esp-netif:0x3ffbd2dc event-id2[0m
D (2270) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158aa4
[0m
D (2277) esp_netif_lwip: esp_netif_start_api 0x3ffbd2dc[0m
D (2282) esp_netif_lwip: esp_netif_get_hostname esp_netif:0x3ffbd2dc[0m
[0m
D (2301) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2307) nvs: nvs_open_from_partition NVM_004 0[0m
D (2316) nvs: nvs_open_from_partition NVM_017 0[0m
D (2325) nvs: nvs_get wac 1[0m
D (2328) nvs: nvs_close 5[0m
D (2331) nvs: nvs_open_from_partition NVM_013 0[0m
D (2335) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158474
[0m
D (2342) esp_netif_lwip: esp_netif_dhcpc_stop_api esp_netif:0x3ffbd2dc[0m
D (2348) esp_netif_lwip: dhcp client stop successfully[0m
D (2359) esp_netif_lwip: check: remote, if=0x3ffbd6a8 fn=0x40158320
[0m
D (2366) esp_netif_lwip: esp_netif_dhcps_stop_api esp_netif:0x3ffbd6a8[0m
D (2372) esp_netif_lwip: dhcp server stop successfully[0m
D (2377) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2383) nvs: nvs_open_from_partition NVM_002 0[0m
D (2388) nvs: nvs_open_from_partition NVM_021 0[0m
D (2392) nvs: nvs_open_from_partition NVM_001 0[0m
D (2397) nvs: nvs_open_from_partition NVM_007 0[0m
D (2401) nvs: nvs_open_from_partition NVM_006 0[0m
D (2406) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x4015853c
[0m
D (2419) esp_netif_lwip: dhcp client re init[0m
D (2423) esp_netif_lwip: call api in lwip: ret=0x0, give sem[0m
D (2429) esp_netif_lwip: check: remote, if=0x3ffbd6a8 fn=0x40157eb8
[0m
D (2442) esp_netif_lwip: DHCP server started successfully[0m
I (2454) wifi:mode : softAP (34:94:54:2a:18:ad)
D (2458) event: running post WIFI_EVENT:3 with handler 0x40167ef8 and context 0x3ffbd584 on loop 0x3ffb7ea4[0m
D (2467) esp_netif_handlers: esp_netif action stopped with netif0x3ffbd2dc from event_id=3[0m
[0m
D (2482) esp_netif_lwip: call api in lwip: ret=0x5002, give sem[0m
D (2489) nvs: nvs_open_from_partition NVM_008 1[0m
D (2493) nvs: nvs_get dns_ser0 4[0m
D (2496) nvs: nvs_get dns_ser1 4[0m
D (2499) nvs: nvs_get dns_ser2 4[0m
D (2502) nvs: nvs_get_str_or_blob dns_svr0[0m
D (2509) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158870
[0m
D (2516) esp_netif_lwip: esp_netif_set_dns_info_api esp_netif:0x3ffbd2dc[0m
D (2522) esp_netif_lwip: set dns if=0x3ffbd2dc type=0 dns=dede43d0[0m
D (2534) esp_netif_lwip: check: remote, if=0x3ffbd2dc fn=0x40158870
[0m
D (2541) esp_netif_lwip: esp_netif_set_dns_info_api esp_netif:0x3ffbd2dc[0m
D (2559) nvs: nvs_open_from_partition NVM_009 1[0m
D (2564) nvs: nvs_get maxlink 1[0m
D (2567) nvs: nvs_open_from_partition NVM_009 0[0m
D (2572) nvs: nvs_get auth0 1[0m
D (2579) nvs: nvs_get auth1 1[0m
D (2582) nvs: nvs_open_from_partition NVM_009 0[0m
D (2587) nvs: nvs_get auth2 1[0m
D (2590) nvs: nvs_open_from_partition NVM_009 0[0m
D (2602) nvs: nvs_get auth4 1[0m
D (2605) nvs: nvs_open_from_partition NVM_018 0[0m
D (2614) nvs: nvs_get enable 1[0m
D (2617) nvs: nvs_get type 1[0m
D (2620) nvs: nvs_get_str_or_blob r_ip[0m
D (2624) nvs: nvs_get r_port 4[0m
D (2627) nvs: nvs_get l_port 4[0m
D (2630) nvs: nvs_get change_mode 1[0m
D (2634) nvs: nvs_get keep_alive 2[0m
D (2637) nvs: nvs_close 13[0m
D (2649) nvs: nvs_open_from_partition NVM_019 0[0m
D (2654) BTDM_INIT: Release DRAM [0x3ffb2730] - [0x3ffb6388][0m
[09:50:51.910]收←◆D (2705) ledc: LEDC_PWM CHANNEL 0|GPIO 17|Duty 0000|Time 1[0m
[09:51:21.912]收←◆D (32705) ledc: LEDC_PWM CHANNEL 0|GPIO 17|Duty 0000|Time 1[0m
[09:51:51.910]收←◆D (62705) ledc: LEDC_PWM CHANNEL 0|GPIO 17|Duty 0000|Time 1[0m
yake827
Re: AT驱动命令编译后指令异常
Postby yake827 » Fri Apr 28, 2023 7:14 am
你的异常是指没有返回 OK 还是出现了 ready 。ready一般说明系统出现了复位,但是我看你的LOG,没看到复位的LOG。
另外,PWM 这块我们建议你们也可以使用我们的 LEDC 自定义命令来做,这样做出来的命令更灵活。
Sun
Re: AT驱动命令编译后指令异常
Postby Sun » Fri Apr 28, 2023 7:25 am
可以参考 ESP-IDF 工程下的 LEDC demo: https://github.com/espressif/esp-idf/tr ... ledc_basic
AT 如何自定义命令:https://docs.espressif.com/projects/esp ... ds.html#at
xiaomuzilyc
Re: AT驱动命令编译后指令异常
Postby xiaomuzilyc » Fri Apr 28, 2023 8:52 am
AT+DRVPWMINIT=100
xiaomuzilyc
Re: AT驱动命令编译后指令异常
Postby xiaomuzilyc » Fri Apr 28, 2023 8:57 am
AT+DRVPWMINIT=100
这个是命令返回值,没有返回OK,也没有返回ERROR,而且我命令是关闭回显的。
你们测试可以正常使用这个命令吗。
我的AT工程只是在配置的时候有选择AT_DEV,然后编译。
我现在需要的只是驱动一个LED指示联网状态。
或者你们这边可以提供一个开启这部分命令的.bin文件给我验证一下吗
