Timers and interrupts not working as expected
Mattgo
Postby Mattgo » Fri Jan 12, 2024 7:34 pm
Hello, I'm facing some unexpected behavior regarding timers and interrupts. I'm hoping to get some insights or suggestions.
My intention is to use the timerWrite(timer, 50); function to set the timer counter to 50, then have it count up to 100, trigger an interrupt, and reset to zero because of the auto-reload feature. However, the behavior I'm observing is different. Once I set timerWrite(timer, 50);, the timer is counting only between 50 and 100 and does not reset to zero. It only resets to zero if I explicitly call timerWrite(timer, 0);.
Here is code for reference:
hw_timer_t * timer = NULL;
void IRAM_ATTR onTimer()
bool state = digitalRead(5);
digitalWrite(5, !state);
  pinMode(5, OUTPUT);
  timer = timerBegin(0, 80, true); // Timer 0, prescaler 80, count up
  timerAttachInterrupt(timer, &onTimer, true);
  timerAlarmWrite(timer, 100, true);
  timerAlarmEnable(timer);
lbernstone
Re: Timers and interrupts not working as expected
Postby lbernstone » Sat Jan 13, 2024 6:06 pm
While it is weird, I think it is correct. Call timerRestart in your alarm function, or have a separate one shot timer that then starts the normal cycle for better precision.
Mattgo
Postby Mattgo » Sun Jan 14, 2024 9:53 am
I found this while rewriting library from AVR to ESP32. Once I figured out what the problem is I sorted it by calling timerWrite(timer, 0).
It is just make no sense to me because timerWrite is supposed to change just actual value of counter. If I would change the setup permanently I will call timerAlarmWrite and change alarm value. For AVR it is working as expected. This seems like bug or poorly documented feature
lbernstone
Postby lbernstone » Wed Jan 17, 2024 12:26 pm
If you believe this does not match the Arduino standard, then open an issue at https://github.com/espressif/arduino-esp32/issues
Users browsing this forum: Barkrowler and 2 guests
