Hi there,
I have designed a custom PCB (my first one) with an ESP32, UART Bridge and some sensors.
I am able to connect it, and even to upload some code (with pushing the boot button).
However u don’t get any signal feedback on the serial.monitor. I tried different settings in Arduino IDE and Platform.IO.
Do you have any Tipp where I should looking at? I am really tying hard but can’t find the issue.
According to the BOM we have an ESP32-S3-WROOM-1-N8
ESP32 custom Board w/ UART - no serial feedback
- SCH_SSCL_Rev000_1-Sheet_1_2024-02-28.png (1.37 MiB) Viewed 5452 times
- Unknown.pdf
- (1.22 MiB) Downloaded 344 times
Re: ESP32 custom Board w/ UART - no serial feedback
How do you know you are able to load the code?
Maybe its an issue with the way you generate rts/cts signals. I would try to use directly internal USB/JTAG i/f on pins 19/20. If i understood correctly your schematic, it just need a small rework.
This way you eliminate usb/uart bridge and be sure esp32 is booting properly.
I setup the Arduino IDE as shown in the screenshot + the build and upload was successful at least according to the screenshot.
I tried to keep the code as clean as possible.
however I also tried it with Serial-println in the loop.
Regarding your tip. I need to cut a USB cable, attach the data cable to GPIO19 and 20 and try the same right? or which setting is required for this?
thank you very much!
Serial.println("Hello World");
- Bild 29.02.24 um 17.11.jpeg (177.58 KiB) Viewed 5309 times
- Bild 29.02.24 um 17.11.jpeg (460.13 KiB) Viewed 5309 times
Looks OK!
Not sure if you have a Serial.begin(); in your setup code.
If you have it and still not working, then try the usb cable.
Either you cut it and solder directly D+/D- and GND wires, or let it as it is, remove R46, R47 and place R18, R19 and plug it in the connector.
Hi Ves011,
it looks like this was a good hint. Once I have connected GPIO 19 (white USB cable) and GPIO20 (green USB cable) I was immediately getting a serial output. I used the USB-C in parallel to "power" the PCB.
Learn so far:
- The former upload was successful as I can see the old program running
- The serial output is only working via GPIO 19 and 20.
Do you have any hint what can be the cause here?
Thank you very much!
Learn so far:
Users browsing this forum: Bytespider, Qwantbot and 5 guests
